1323324326328329417
  • @skorous said:
    @mockingbird said:
    Consider yourself fortunate... I got a transfer from a user for a provider called 'Silvercreek/Terabit" over at LET... The service never worked and they kept responding to my tickets saying "it's working". To make a long story short, I went on their Discord channel and called their tech retarded, but I put up a pretty good fight on my LET thread and people will see who they are if they're smart enough to search before ordering their services...
    I wouldn't be proud of that story.
    Hey what can anyone here do to me? This took place over at LET, this is LES...
  • @blackeye said:
    Guys, why i can’t remove my cc on virmach ?
    Really nobody help ? @VirMach
    Never said anyone could/would do anything to you. I said you're trash and that I wouldn't be proud of that. You do you though.
    Thanked by (2)AlwaysSkint adly
  • Any idea why IPs in SJC appear as coming from IRAN?
    91.186.21x.xxx
    edited December 2024
    91.186.21x.xxx
    New VirMach location. /j
    Not updated geolocation I expect. The IPs are leased. This was probably their last location.
    Thanked by (2)CMunroe Wonder_Woman
    I may be trash, but his technicians are definitely retarded if there are three responses to a ticket and they can't figure out what's flying.
    @mockingbird said: I may be trash
    Keyboard warrior, here. One wonders whether a real address was entered and three technicians might pay someone a visit. One sore pus (Scot.) later. :|
    On that happy note.. "time for bed, said Zebedee".
    [P.S. Yes @Chievo, had a tooth pulled this week, so it's me with the sore pus, in actual fact.]
    Lets take it down a notch. We are all friends here.
    @mockingbird the takeaway from my point of view is don't buy from new providers on LET unless you want to be disappointed.
    It is true that I should keep a civil tongue and for not doing that I can sincerely apologize.
    Thanked by (1)mockingbird
  • @VirMach said:
    @Fritz said:
    @adly said:
    @Neoon said:
    TOS clearly states only 1 account is allowed.
    It's not like we don't have a thread like this every six months or so when this happens to someone who also can't follow the rules. Had to know it was going to be a problem sooner or later.
    I'm not one to defend breaking the TOS, and it was clearly broken here with multiple accounts...
    However, by the looks of it this person has been a customer since at least 2018 and presumably has not been an issue until this was raised. I'm not sure I can see the logic in immediately jumping to terminating the relationship with them if things are as stated. 🤷‍♂️
    This can happen to anyone including me, thus I'm holding my chance to grab those VPS.Blackfriday.
    @VirMach can easily ditch anyone to free up space.
    I don't even know where to start with this one, it's not like my response would change anyone's mind. I guess you can say anything and make it appear however you want based on your personal feelings about it.
    It's definitely beyond stretching the truth to look at this case and go "this can happen to anyone, including me." Sure, if you check off several boxes, and then specifically respond asking us to make an exception which is clearly labeled as having us look into very specific breaches of our terms of service since the migration is related to that problem.
    I don't have a single problem with your service since it's just for my hobby.
    I don't care few boxes down/not responding since I don't use it either, I just like to donate to you and keep those boxes idling.
    I knew this would happen sooner or later thus I lower my expectation and this help me control my mind.
    I've been one of your customers since 2017 with more than 10 idling boxes.
    will San Jose remain or planned move to LAX?
    VirMach mentioned earlier that he had 20 nodes in San Jose and had no plans to decommission that location.
    Thanked by (1)cybertech
    Only LAX and EWR are safe.
    All other locations could be closed at the drop of a hat.
    I hope Miami/Atlanta survive
    cool it has decent network as well.
    Yes, I always like that location's network. Worked real well for me.
  • @emperor said:
    @Crab said: network slowness in Chicago
    MIA is almost the same :D
    QuadraNet. What do you expect.
  • I hope they replace QN with better upstream
    QN simply sucks these days
  • Considering network issues, the nodes in NJ are >20ms to NY via HE. It’s currently less to Toronto. That said for what I paid, I’m not complaining. =)
  • edited December 2024
    @VirMach Control Panel / Web Mail for Web Hosting appears to be down for LAX2Z017 (https://lax2z017.virm.ac) .
  • @Brayvin said:
    @VirMach Control Panel for Web Hosting appears to be down for LAX2Z017.
    works for me.
    Thanked by (1)Brayvin
    @Jab said:
    works for me.
    Hmm. I'm getting "took too long to respond" timeouts (as accessed from Texas).
  • @Brayvin said:
    @Jab said:
    works for me.
    Maybe you temp banned because too many connections or something? :(
    https://www.uptimia.com/website-availability-test/522b5e45
    It needed a restart (WHM), it was being weird.
  • @VirMach
    AMSD026 - NoVNC has been down for a couple weeks. Could you take a look?
    Failed to connect to the server (code: 1011 reason: failed to connect to downstream server
    Error loading VNC. Please make sure the VPS is powered on.
    Then try:
    1. Using the "Reset" button to remove any mounted ISO and reboot.
    2. Check the network status page for any posted issues.
    3. See if your service is still accessible via SSH or RDP.
    @localhost said:
    @VirMach
    Then try:
    Number one solution for this, usually, is the customer disabled their VNC and forgot. Can you double check this, and if that's not the case, then open a ticket?
  • @Jab said:
    @Brayvin said:
    @Jab said:
    works for me.
    Not sure how long that would be. After the restart, it still didn't work, but it does now. Thanks all.
    Thanked by (1)sh97
  • JabJab Senpai
    Clearly bought reviews - no one posts so nicely and with such good english!
    also pages 2+ are fun - botting went wrong :D
    Is Chicago network improving at all? It's going pretty much how I expected, they just got confused, blamed us for something, but they came back a day later and said "some bandwidth issues have been resolved" -- whatever that means.
    @Jab said: also pages 2+ are fun - botting went wrong
    I was cleaning those up at some point in time then got busy. It's actually pretty smart for the guy to make it look as if we're lazily giving ourselves 5 star reviews or something.
