The issue with the QEMU seems to be not setting the CPU type to 'host', this will have to be changed on the node in the templates. Any client machines will have to be manually edited and then hard shutdown / restart for the QEMU changes to take effect.
You'll also save a bunch of cpu cycles for hardware offload and more efficient usage of compute extensions.
Edit: This is an incredibly easy mistake to make if you goof a line of code while building templates.
Review time:
-Debian 10 template does not work
-Debian 11 template is better than Debian 12 in terms of CPU flags (see my previous post)~ so it's better to use 11 and then upgrade to 12.
-don't use Debian 12 template
-AlmaLinux 9 template is OK
-Ubuntu 20 template is OK
-Ubuntu 22 template is OK
@rm_ said: But we do not know the login username to use (and the password?)
I was already a customer (from 2018!) so I had the username from my side already, the password is/was the one you enter before completing the order (which is/was actually the root password in the form happened to be the SolusVM password). If you do not have your username, I don't know how you can retrieve it though....
🤡 "The tags provided to users are worthless permanent labels~ accept them or leave!" 🤡
Are the cores dedicated? Cannot see any mention of fair-share.
Can I upgrade to a bigger plan at the same promotional rate?
They mentioned on OGF that yes it can be upgraded with the promotional rate
Nice. Now whay about fair use policy for cores...
@hostsailor I'm wondering about the same thing because I'm tempted to get one of the heftier packages, but core utilization policy is important to know.
thankyou for feeding my addiction
Welcome to the club.. its hard to get out tho..
ServerStatus , slackvpn
Recommended Providers: AlphaVPS(aff) | HostBRR(aff) | HostDare(aff) | KuroIT(aff)
That's what we call dual stack here.
★ 80–85% ↓↓ – NVMe(NL) from 1c EPYC/1G/30G/1T – $12/y (ref), codes: LETMINI80, LETSAILOR80 respectively / SSD(US) from 1c/2x256M/2x10G/256G – $5.4/y (ref), ×2 upg. via ticket, codes: SPECIALMINI85, LETSAILOR85, SEAMANSSD85
I think those templates comes directly from SolusVM and they fucked it up there. Not a first time we see it.
Install Alma 9 to have flag enabled, reinstall to Debian to not have flag disabled. PROFIT.
Review time:
In fact as above re-installing Deb 12 after a dummy install of Alma 9 does indeed result in CPU passthrough with Deb 12.
which payment method to use for credit card?
2 USD per IP per month
WHMCS isn't sending any emails, cant verify account and after payment not receiving panel login details
I only got the email for my first order, not the subsequent ones (it does not bother me)... maybe you can double-check here:
https://clients.hostsailor.com/clientarea.php?action=emails
SolusVM is available here:
https://vps.hostsailor.com/
Got the same issue, no activation mails and no panel access. Ticket #AA420289
Empty on mine.
Can you please open a ticket to our support department.
rootpassword in the form happened to be the SolusVM password). If you do not have your username, I don't know how you can retrieve it though....🤡 "The tags provided to users are worthless permanent labels~ accept them or leave!" 🤡
Emails are not being delivered to customers since a few hours. Ticket response will not be notified either.
This ship has sank in the deadpool.
May all the sailors rest in peace 🫡
Quota ran out for emails?
@hostsailor
Can you provide 2 hour trial? @hostsailor
https://microlxc.net/
Getting 403 on the website
Yeah about that, couldn't find anything on their website. That what makes me hesitate ...
got my emails fixed
Now waiting for 403 to be fixed
no activation mails and no panel access. Ticket #AD640795
Resolved.thx!
Anyone else get a non-requested password reset email just now?
