HostSailor - 12.12 Mega Deal: Get Your KVM VPS NVMe at 90% Recurring Discount – Forever!
2456
  • @emperor said:
    @bdl said: Is the $6/year one the best one to get?
    I got the 2nd one.. its double everything which i dont need it but why not ? :D
    thankyou for feeding my addiction :lol:
    Thanked by (1)emperor
  • [root@vps117141 ~]# curl -sL https://yabs.sh | bash -s -- -4
    #                     v2024-06-09                    #
    Wed Dec 11 17:05:30 EST 2024
    Uptime     : 0 days, 0 hours, 14 minutes
    CPU cores  : 1 @ 2449.996 MHz
    AES-NI     : ❌ Disabled
    VM-x/AMD-V : ❌ Disabled
    RAM        : 990.9 MiB
    Swap       : 1024.0 MiB
    Disk       : 28.5 GiB
    Distro     : CentOS Linux 7 (Core)
    Kernel     : 3.10.0-1062.18.1.el7.x86_64
    ISP        : HostSailor
    ASN        : AS60117 Host Sailor Ltd
    Host       : HostSailor RO Services
    Country    : Romania
    Read       | 248.94 MB/s  (62.2k) | 438.04 MB/s   (6.8k)
    Write      | 249.60 MB/s  (62.4k) | 440.34 MB/s   (6.8k)
    Total      | 498.54 MB/s (124.6k) | 878.38 MB/s  (13.7k)
    Read       | 559.08 MB/s   (1.0k) | 591.53 MB/s    (577)
    Write      | 588.78 MB/s   (1.1k) | 630.93 MB/s    (616)
    Total      | 1.14 GB/s     (2.2k) | 1.22 GB/s     (1.1k)
    Clouvider       | London, UK (10G)          | 658 Mbits/sec   | 1.45 Gbits/sec  | 8.92 ms
    Eranium         | Amsterdam, NL (100G)      | busy            | 3.08 Gbits/sec  | 0.616 ms
    Uztelecom       | Tashkent, UZ (10G)        | busy            | 783 Mbits/sec   | 90.0 ms
    Leaseweb        | Singapore, SG (10G)       | busy            | 975 Mbits/sec   | 179 ms
    Clouvider       | Los Angeles, CA, US (10G) | 579 Mbits/sec   | busy            | 139 ms
    Leaseweb        | NYC, NY, US (10G)         | 614 Mbits/sec   | 1.80 Gbits/sec  | 77.0 ms
    Edgoo           | Sao Paulo, BR (1G)        | 540 Mbits/sec   | 652 Mbits/sec   | 185 ms
    Geekbench 4 Benchmark Test:
    Single Core     | 5915
    Multi Core      | 5054
    Full Test       | https://browser.geekbench.com/v4/cpu/18353285
    YABS completed in 6 min 9 sec
  • @bdl said: thankyou for feeding my addiction
    Welcome to the club.. its hard to get out tho..
    Thanked by (2)bdl vyas
  • @cmeerw said:
    @DataRecovery said:
    @cmeerw said:
    but what is VSwap anyway? we are talking about KVM, aren't we?
    The VPS is KVM, but VSwap runs on OpenVZ.
    Aehh, what does that mean then?
    That's what we call dual stack here.
    80–85% ↓↓ – NVMe(NL) from 1c EPYC/1G/30G/1T – $12/y (ref), codes: LETMINI80, LETSAILOR80 respectively / SSD(US) from 1c/2x256M/2x10G/256G – $5.4/y (ref), ×2 upg. via ticket, codes: SPECIALMINI85, LETSAILOR85, SEAMANSSD85
    edited December 2024
    The issue with the QEMU seems to be not setting the CPU type to 'host', this will have to be changed on the node in the templates. Any client machines will have to be manually edited and then hard shutdown / restart for the QEMU changes to take effect.
    You'll also save a bunch of cpu cycles for hardware offload and more efficient usage of compute extensions.
    Edit: This is an incredibly easy mistake to make if you goof a line of code while building templates.
    Thanked by (3)jcn50 yoursunny wankel
  • @ZizzyDizzyMC said: Edit: This is an incredibly easy mistake to make if you goof a line of code while building templates.
    I think those templates comes directly from SolusVM and they fucked it up there. Not a first time we see it.
    Install Alma 9 to have flag enabled, reinstall to Debian to not have flag disabled. PROFIT.
  • edited December 2024
    Review time:
    -Debian 10 template does not work :s
    -Debian 11 template is better than Debian 12 in terms of CPU flags (see my previous post)~ so it's better to use 11 and then upgrade to 12.
    -don't use Debian 12 template
    -AlmaLinux 9 template is OK
    -Ubuntu 20 template is OK
    -Ubuntu 22 template is OK
    Thanked by (1)huginn
    🤡 "The tags provided to users are worthless permanent labels~ accept them or leave!" 🤡
  • @jcn50 said:
    Review time:
    In fact as above re-installing Deb 12 after a dummy install of Alma 9 does indeed result in CPU passthrough with Deb 12.
  • which payment method to use for credit card?
  • hostsailorhostsailor Hosting ProviderOG
    @jcn50 said:
    @hostsailor how much is an additional IPv4 please?
    2 USD per IP per month
    Thanked by (2)jcn50 admax
    WHMCS isn't sending any emails, cant verify account and after payment not receiving panel login details
    Thanked by (1)TrendyJack
    I only got the email for my first order, not the subsequent ones (it does not bother me)... maybe you can double-check here:
    https://clients.hostsailor.com/clientarea.php?action=emails
    SolusVM is available here:
    https://vps.hostsailor.com/
  • rm_rm_
    @jcn50 said: SolusVM is available here:
    But we do not know the login username to use (and the password?)
    Got the same issue, no activation mails and no panel access. Ticket #AA420289
    Empty on mine.
    Can you please open a ticket to our support department.
  • @rm_ said: But we do not know the login username to use (and the password?)
    I was already a customer (from 2018!) so I had the username from my side already, the password is/was the one you enter before completing the order (which is/was actually the root password in the form happened to be the SolusVM password). If you do not have your username, I don't know how you can retrieve it though....
    Emails are not being delivered to customers since a few hours. Ticket response will not be notified either.
    This ship has sank in the deadpool.
    May all the sailors rest in peace 🫡
    Thanked by (2)admax yoursunny
  • Quota ran out for emails? =)
    Thanked by (2)FrankZ bdl
  • @hostsailor
    • Are the cores dedicated? Cannot see any mention of fair-share.
    • Can I upgrade to a bigger plan at the same promotional rate?
    Thanked by (2)user123 Khalequzzaman
  • Can you provide 2 hour trial? @hostsailor
  • Getting 403 on the website
  • @localhost said:
    @hostsailor
    They mentioned on OGF that yes it can be upgraded with the promotional rate
  • @curiouswanderer said:
    @localhost said:
    @hostsailor
    Nice. Now whay about fair use policy for cores...
    Thanked by (1)user123
    @localhost said:
    @hostsailor
    Yeah about that, couldn't find anything on their website. That what makes me hesitate ...
    got my emails fixed
    Thanked by (2)zgato hostsailor
  • @cybertech said:
    got my emails fixed
    Now waiting for 403 to be fixed
  • no activation mails and no panel access. Ticket #AD640795
    Resolved.thx!
    Thanked by (1)hostsailor
  • Anyone else get a non-requested password reset email just now?
    @localhost said:
    @hostsailor
    @hostsailor I'm wondering about the same thing because I'm tempted to get one of the heftier packages, but core utilization policy is important to know.
