Music player script
Tired from youtube and soundcloud. Looking for a way to make my own music player. What I'am searching for:
- PHP. Ideally single file drop and go;
- Script should scan X folder(s) and add tracks automatically to the playlist;
- Some sort of web gui, nothing fancy;
- Continues play. Once I press play, music player should play music until there is no un-played tracks;
- Major formats support or conversion on the fly with ffmpeg;
There is a lot of script on the net, to many to test them all. I need simple, performant one.
Apart from the servers like subsonic etc, there's also this: https://github.com/koel/koel still actively maintained for quite a while.
piximg image hosting
Not to sound obvious, but maybe one of these
https://github.com/awesome-selfhosted/awesome-selfhosted?tab=readme-ov-file#media-streaming---audio-streaming
or
something from
https://apps.yunohost.org/catalog?category=multimedia
On a separate note: I found Podverse, a good open source podcast app for embedding in my own blog/ podcast site, btw.. while looking up the options)
blog | exploring visually |
Way back, in the old days, when I did Shoutcast radio, I had a PHP script listing all available music for the listeners to queue.
To bad I didn't save all those scripts... would probably have solved your question
Edited: I think 5 or 6 yrs ago on OGF someone had offered shoutcast accounts. I remember having one
That are low amounts of storage, maybe max 5GB. For some music lovers TBs are relevant.
