HostSailor - 12.12 Mega Deal: Get Your KVM VPS NVMe at 90% Recurring Discount – Forever!
1246
  • edited December 2024
    Answer from support about rDNS/PTR:
    As of now, rDNS setup is not available, it will be ready in a few days and you will be able to do it from the VPS control panel once ready.
    Thanked by (2)rm_ cmeerw
    🤡 "The tags provided to users are worthless permanent labels~ accept them or leave!" 🤡
  • It's over: The promotion code entered has expired
    Why do you need rDNS? Email is blocked.
    @Fritz said: Why do you need rDNS? Email is blocked.
    Outgoing TCP port 25 is working fine for me~
    Outgoing TCP ***** is working fine for me~
    Ssshhhhh ;)
    Thanked by (1)jcn50
  • @rm_ said:
    The network is still bad. It was perfect at first, but now 15-30% packet loss for over 5 hours.
    Now 24 hours. My ping-based uptime monitors give uptime as around 70%. Put bluntly, network sucks.
    On mine it is mostly good by now.
    Nevermind the higher latency part in the middle, that specific one was due to my ISP.
    But the blue and purple line which was packet loss due to this provider DC or node, has returned to green even before that.
    That ping is smoky B)
    P.S.
    I believe it's also worth mentioning the node, as the situation differs among the fleet.
    Black Friday StorageAMD EPYC VDS (ref), up to 4TB NVMe / NVMe + big HDD VPS (ref) from $2.29/TB/mo / Storage/GPU dedis (ref)
  • code expired :(
    We hitting 4 8s with this one.
    Thanked by (1)user123
  • I have the same problem with the response time on mine: going up & down.. Can something be down about this? Shall I open a ticket?
  • seems better than me, got no traffic out or in. Can only use vnc to login. Cant even ping dns server. Even reinstall from centos 9 to debian 12. I'm open ticket cause didnt know other solution.
  • @rizkiv1 are you on node #6?
    Thanked by (1)rizkiv1
    Many are on the infamous node #6.
  • Don't know how to tell the node that I'm on. But here is my YABS ("Sailor" product):
    #                     v2024-06-09                    #
    Sat 14 Dec 22:32:32 GMT 2024
    Uptime     : 0 days, 0 hours, 2 minutes
    CPU cores  : 2 @ 2449.996 MHz
    AES-NI     : ❌ Disabled
    VM-x/AMD-V : ❌ Disabled
    RAM        : 1.9 GiB
    Swap       : 2.0 GiB
    Disk       : 47.1 GiB
    Kernel     : 6.1.0-28-amd64
    ISP        : HostSailor
    ASN        : AS60117 Host Sailor Ltd
    Host       : HostSailor RO Services
    Country    : Romania
    Read       | 240.62 MB/s  (60.1k) | 486.76 MB/s   (7.6k)
    Write      | 241.25 MB/s  (60.3k) | 489.33 MB/s   (7.6k)
    Total      | 481.88 MB/s (120.4k) | 976.10 MB/s  (15.2k)
    Read       | 556.33 MB/s   (1.0k) | 612.23 MB/s    (597)
    Write      | 585.89 MB/s   (1.1k) | 653.01 MB/s    (637)
    Total      | 1.14 GB/s     (2.2k) | 1.26 GB/s     (1.2k)
    Clouvider       | London, UK (10G)          | 799 Mbits/sec   | 2.23 Gbits/sec  | 9.33 ms
    Eranium         | Amsterdam, NL (100G)      | 936 Mbits/sec   | 2.68 Gbits/sec  | 0.655 ms
    Uztelecom       | Tashkent, UZ (10G)        | 875 Mbits/sec   | 733 Mbits/sec   | 90.1 ms
    Leaseweb        | Singapore, SG (10G)       | 465 Mbits/sec   | 964 Mbits/sec   | 177 ms
    Clouvider       | Los Angeles, CA, US (10G) | 771 Mbits/sec   | 251 Mbits/sec   | 137 ms
    Leaseweb        | NYC, NY, US (10G)         | 785 Mbits/sec   | 760 Mbits/sec   | 76.7 ms
    Edgoo           | Sao Paulo, BR (1G)        | 755 Mbits/sec   | 547 Mbits/sec   | 186 ms
    Single Core     | 853
    Multi Core      | 1569
    Full Test       | https://browser.geekbench.com/v6/cpu/9429585
    YABS completed in 14 min 21 sec
    @SocksAreComfortable you need to look into SolusVM: https://vps.hostsailor.com then once you open your server look for the the "Node" row~
    #                     v2024-06-09                    #
    AES-NI     : ❌ Disabled
    RAM        : 1.9 GiB
    Swap       : 2.0 GiB
    Disk       : 47.1 GiB
    ISP        : HostSailor
    Country    : Romania
    Single Core     | 853
    Multi Core      | 1569
    You should do the trick to enable CPU passthrough and nested virtualization. Install Almalinux 9, then run YABS to verify, then you can reinstall Debian 12
    Here's my YABS on node 6
    #                     v2024-06-09                    #
    Sat Dec 14 19:34:10 EST 2024
    Uptime     : 1 days, 18 hours, 0 minutes
    Processor  : AMD EPYC 9534 64-Core Processor
    CPU cores  : 4 @ 2449.996 MHz
    RAM        : 3.8 GiB
    Swap       : 4.0 GiB
    Disk       : 74.7 GiB
    Distro     : AlmaLinux 9.5 (Teal Serval)
    Kernel     : 5.14.0-503.15.1.el9_5.x86_64
    ISP        : Host Sailor Ltd
    Host       : Host Sailor Ltd
    Country    : The Netherlands
    Read       | 201.11 MB/s  (50.2k) | 310.28 MB/s   (4.8k)
    Write      | 201.64 MB/s  (50.4k) | 311.92 MB/s   (4.8k)
    Total      | 402.75 MB/s (100.6k) | 622.20 MB/s   (9.7k)
    Read       | 441.22 MB/s    (861) | 582.70 MB/s    (569)
    Write      | 464.67 MB/s    (907) | 621.51 MB/s    (606)
    Total      | 905.89 MB/s   (1.7k) | 1.20 GB/s     (1.1k)
    Clouvider       | London, UK (10G)          | 1.46 Gbits/sec  | 2.58 Gbits/sec  | 9.55 ms
    Eranium         | Amsterdam, NL (100G)      | 1.56 Gbits/sec  | 2.84 Gbits/sec  | 0.560 ms
    Uztelecom       | Tashkent, UZ (10G)        | busy            | 1.07 Gbits/sec  | 85.6 ms
    Leaseweb        | Singapore, SG (10G)       | 943 Mbits/sec   | 1.35 Gbits/sec  | 180 ms
    Clouvider       | Los Angeles, CA, US (10G) | 1.18 Gbits/sec  | 741 Mbits/sec   | 144 ms
    Leaseweb        | NYC, NY, US (10G)         | 1.41 Gbits/sec  | 2.12 Gbits/sec  | 75.5 ms
    Edgoo           | Sao Paulo, BR (1G)        | 936 Mbits/sec   | 784 Mbits/sec   | 185 ms
    Single Core     | 1875
    Multi Core      | 5608
    Full Test       | https://browser.geekbench.com/v6/cpu/9430852
    YABS completed in 10 min 5 sec
    Thanked by (1)SocksAreComfortable
    Ah, seems I'm on node 4 then! kvmnvme04.hostsailor.com
    Thank you, didn't know that trick! Never installed Alma so didn't know what I was doing when I loaded into it, but when I re-installed Debian it seems to have worked:
    #                     v2024-06-09                    #
    Sun 15 Dec 01:04:20 GMT 2024
    RAM        : 1.9 GiB
    Swap       : 2.0 GiB
    Disk       : 47.1 GiB
    ISP        : HostSailor
    Country    : Romania
    Read       | 224.19 MB/s  (56.0k) | 495.18 MB/s   (7.7k)
    Write      | 224.78 MB/s  (56.1k) | 497.78 MB/s   (7.7k)
    Total      | 448.97 MB/s (112.2k) | 992.96 MB/s  (15.5k)
    Read       | 594.20 MB/s   (1.1k) | 655.96 MB/s    (640)
    Write      | 625.77 MB/s   (1.2k) | 699.65 MB/s    (683)
    Total      | 1.21 GB/s     (2.3k) | 1.35 GB/s     (1.3k)
    Clouvider       | London, UK (10G)          | 755 Mbits/sec   | 2.12 Gbits/sec  | 9.22 ms
    Eranium         | Amsterdam, NL (100G)      | 890 Mbits/sec   | 2.51 Gbits/sec  | 0.564 ms
    Uztelecom       | Tashkent, UZ (10G)        | 827 Mbits/sec   | 800 Mbits/sec   | 89.3 ms
    Leaseweb        | Singapore, SG (10G)       | 696 Mbits/sec   | 960 Mbits/sec   | 185 ms
    Clouvider       | Los Angeles, CA, US (10G) | 712 Mbits/sec   | 525 Mbits/sec   | 136 ms
    Leaseweb        | NYC, NY, US (10G)         | 794 Mbits/sec   | 1.11 Gbits/sec  | 75.2 ms
    Edgoo           | Sao Paulo, BR (1G)        | 677 Mbits/sec   | 548 Mbits/sec   | 186 ms
    Single Core     | 1676
    Multi Core      | 3263
    Full Test       | https://browser.geekbench.com/v6/cpu/9431162
    YABS completed in 10 min 21 sec
    @SocksAreComfortable change network to Virtio in solusvm
    Done and rebooted. Not entirely sure why, but given the benefits from the last change, I'll take it whatever it does, lol.
    try iperf test again
    Had a feeling that might be relevant, so I had one running.
    Clouvider       | London, UK (10G)          | 8.35 Gbits/sec  | 5.92 Gbits/sec  | 20.4 ms
    Eranium         | Amsterdam, NL (100G)      | 9.08 Gbits/sec  | 8.83 Gbits/sec  | 0.589 ms
    Uztelecom       | Tashkent, UZ (10G)        | 2.24 Gbits/sec  | 2.02 Gbits/sec  | 89.2 ms
    Leaseweb        | Singapore, SG (10G)       | 876 Mbits/sec   | 954 Mbits/sec   | 182 ms
    Clouvider       | Los Angeles, CA, US (10G) | 1.23 Gbits/sec  | 659 Mbits/sec   | 136 ms
    Leaseweb        | NYC, NY, US (10G)         | 2.03 Gbits/sec  | 2.39 Gbits/sec  | 75.1 ms
    Edgoo           | Sao Paulo, BR (1G)        | 948 Mbits/sec   | 925 Mbits/sec   | 186 ms
    Tiny bit faster on some of those, lol. Just a smidge.
  • Does Almalinux trick is legal for us to do @hostsailor
    Myself has used it as well but will redo if it's not allowed.
    I'm sorry, what?
    Thanked by (1)TrendyJack
    Sadly yes. Well, after that post the network up and normal till now lol. Yet to test and maybe not running yabs.
  • vyasvyas OGSenpai
    Is this Hostsailor offer the new (temporary hopefully) c1v ?
    More like coicu
    Redo how? And what exactly?
    It's just a simple OS reinstall from the template via the control panel. It's not like you did anything illegal...
