VirMach * 2024 * RYZEN * NVMe ** VPS Black Friday * Flash Deals ** Check inside for offers!
19798100102103118
  • edited December 2024
    It's 100, my dudes.
    Tram 100 in Russia (streetcar)
    / note there are two "100" on the tram, one of which is low-end /
    Feels like the right moment for the first post in this thread B)
    Black Friday StorageAMD EPYC VDS (ref), up to 4TB NVMe / NVMe + big HDD VPS (ref) from $2.29/TB/mo / Storage/GPU dedis (ref)
    fastest fingers first
    @adly said:
    I have to say, contrary to expectations, I like the AI support and hope this is expanded - there’s so much room for innovation here.
    It's nice hearing positive feedback about it because in some cases it definitely is getting to the point where the AI support can actually be better than a human. I notice myself referring customers to using some of our AI features and it's usually not taken well, but I only do so in cases where I know for a fact they'll be able to resolve their issue much faster and accurately, especially if it's a limited support service and I would otherwise have to say "sorry, your support level, blah blah..."
    There's an exciting update I finally pushed out: the ticket system now can utilize your service's VNC screen.
    Example, breaking a virtual server on purpose to where it has no operating system and selecting "connection issue"
    Without VNC - Assistant: Your VPS might not have a proper operating system installed or it's corrupted, which is why the IP doesn’t ping despite the VPS being online and VNC working. I recommend checking the OS installation via VNC. If it’s missing or corrupted, reinstall the OS through the control panel. Follow the knowledgebase article for guidance on OS installation.
    This still is shockingly accurate, because it does get enough information to try to find the most likely issue. Also side note, when it says "follow the knowledgebase article" it's actually remnants of our old system in the background before AI, it means it located data it was trained on and knows in this particular case it means its not a connection issue, something people would have to otherwise have read a long list to decipher in the past. Another note, if you pick "VNC error" it comes with the same determination, but it's less confident.
    With VNC - Assistant: Your VPS isn't booting because there's no operating system installed. The VNC screenshot confirms this with a "No bootable device" error. You should reinstall the OS. Check VirMach's knowledge base for steps on installing an operating system via their control panel.
    Notice how it now seems to 100% believe this is the issue. Since we've moved to a newer AI for the chat feature as well, I've re-incorporated pushing the initial determination by the chat into the ticket AI, so the tickets should now take into account the determination from the VNC being checked.
    The way it currently works is you have to explicitly approve it on this step. You only get a few seconds. I'll think about improving the process, and in the future it might only have an option to deny and default to approve instead, which would be noted.
    I've fine tuned some stuff for the flash deals. It doesn't seem to have had a positive impact. On another note, the timers are being played with and are more sophisticated now. It doesn't seem to have had a positive impact.
    Thanked by (2)ariq01 user123
  • FAT32FAT32 OGSenpai
    PAGE 100
    Thanked by (2)ariq01 imok
  • vyasvyas OGSenpai
    100 percent off for page 100 ?
  • Yes, Page 100 is the perfect time for 100% off... then VirBot can feel loved again, it has feelings too :/
    Thanked by (2)yoursunny ariq01
  • Good morning, page 100
    Thanked by (1)ariq01
  • VIVAVIRMACH
  • @slownedstark said:
    @localhost said:
    @slownedstark said:
    Chicago location :smile: (code used)
    woah. Please transfer it to me.
    BTW, what was the original cost b4 coupon?
    99.99 strange i know
    BTW how/ what was the 50% off coupon?
  • _MS__MS_ OGSenpai
    100
    Thanked by (2)imok ariq01
    @MS said: 100
    You missed the bus! Just as well another came along. :p
    [Technically/Pedantically this is the bus, not a tram :+1: ]
    Thanked by (2)imok _MS_
  • 100 pages for 100% lolz
  • VirBot is dead.
  • Maybe he's just resting, taking a nap :o
  • MOARRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
  • Probably preparing for vps.christmas
    Thanked by (1)localhost
  • great timing... 100 pages and VirBot goes Brrrrrrrrrrrrrrrr..........................
  • It's dead.
  • RIP VirBot. Not quite the page 100 celebration we hoped for.
    Thanked by (3)imok ariq01 yoursunny
  • THOR VIRBOT WILL RETURN
  • Thank you for your service sir VirBot
    Thanked by (1)imok
  • Gracias señor Virbot
    Thanked by (2)localhost ariq01
    thanks for all the fun
  • @VirMach I just purchased a VPS, Invoice #1667151, with 2 IPV6 addresses, but the second IPV6 address cannot be connected; can you check it? If you cannot provide support, please ignore it.
    Have you tried their AI support or opening a ticket?
