@Rahul said:
installed NextCloud using Softaculous via DirectAdmin
But no Preview for HEIC format
I'm unsure how the previews are implemented in NextCloud, especially if you don't install it yourself, but the first thing I'd try is installing libheif / pillow-heif.
Installing the memory and preview generator apps allowed me to see the previews on Android. You could give that a try.
Installing just one might also do the trick, I haven't checked.
NC has an app to convert heic images
Not sure about preview
https://apps.nextcloud.com/apps/imageconverter
blog | exploring visually |
The choice depends on how codecs work in NC.
☰ Black Friday Storage — AMD EPYC VDS (ref), up to 4TB NVMe / NVMe + big HDD VPS (ref) from $2.29/TB/mo / Storage dedis (ref)
- | Free Uptime Kuma | Best Web Hosting Deal | pdf-tools.site
