Out of the last 65 services sold, 36 were sold in Tokyo (55%)
I do notice the system putting in a lot of Tokyo recently, I think that's because it didn't put many earlier on and it's already cycled through many of the other nodes, and/or maybe something's broken with the code or it's very close to pruning the list. There's definitely some improvements that can be made, basically as it reaches near the end of the list it'll start repeating nodes more frequently until it prunes.
(edit) Okay no something's definitely wrong, looking into it.
The duration does need to be fixed a little. I just put in some numbers I thought would work but haven't had time to check it further. It does look like it skips through a bunch of them a little faster than intended. Like we definitely shouldn't be at offer 1735, 1744, and 1745 (with 10 gap.) I actually don't know even if it just fully skipped all of those, that seems likely. Maybe our safety minimum threshold broke. I also assume it makes some of them very long.
@Kris said:
When one purchases the change IP button for a VM does that show up in SolusVM or WHMCS integration?
Not trying to burn a subnet, but semi-anonymous scraping, not sure if it's a manual add-on or I'm missing something obvious.
Glad to see the VirBot's still-a-runnin.
Have you already purchased that? If so, you have it but the button is currently gone as the system's being reworked. Until it's back, I'm your change IP button. You'd make a ticket and it's currently manual. Later on it'll be automatic again with some limitations which I don't remember (but basically so people don't burn through an entire subnet in a day.)
@VirMach said: Have you already purchased that? If so, you have it but the button is currently gone as the system's being reworked. Until it's back, I'm your change IP button. You'd make a ticket and it's currently manual. Later on it'll be automatic again with some limitations which I don't remember (but basically so people don't burn through an entire subnet in a day.)
Gotcha. Purchased it for one and didn't find the button, so I'm gonna wait til that's worked on.
Really not trying to ticket in on these unless the node's down.
VirBot back?
I thought I almost had to begin provisioning these...
@VirMach Can we relaunch this again? I'm very much looking forward to it!
MOARRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
Time to tweak the algorithm™ for 178571575 time.
One day VirMach will kill VirBot :-D
Then please reduce the dealing cycle, hours of duration is s***.
I vote @roseyysa be disqualified from further deals on account of whining.
And a coupon for the rest of us for putting up with it? meekly waves pitchfork around, then gives up, shrugs, and wanders off to a forgotten corner
Ban.
Hours of duration is sweet, what's wrong with this?
Are you sure?
Or it's VirBot coming out with flames against @VirMach
The day when Ai takes over humanity.
Starts here, with @VirMach
Not enough *'s :P
You need to math.
Math or meth?
Ban!
This implies I'll remember to use or provision the VM.
Wishful thinking on my part, only 26 others to go, so I got that goin' for me - which is nice.
Tokyooooooooooooooooooooooooooooooooooo
VirBot seems to be taking another nap ....all 3 stuck on switching SOON™
VirBoff
LAXXXXXOOOOOOOOK
The encryption certificate for vps.virmach.com has expired. @VirMach
cmon man i still need at least one in Amsterdam here
Anyone buy a San Jose flash deal and end up in Seattle (RYZE.SEA-Z010.VMS)? I thought Seattle went away...
quick sell it for profit
It's offline soooooooo I don't think it will sell for much. 😆
crash了 睡香香的胖子
Your VM is in San Jose. The node was shipped from Seattle months ago, but was not renamed after the location change.
