@VirMach said: Okay here's some new weird coupons. Make sure to read disclaimers at bottom.
BUY1AND2 - Buy VPS-BF-ORDER-1 and VPS-BF-ORDER-2 together to get 50% off one-time (non-recurring) on VPS-BF-ORDER-1 only. Must be purchased together.
BUY2AND3 - Buy VPS-BF-ORDER-2 and VPS-BF-ORDER-3 together to get 50% off one-time (non-recurring) on VPS-BF-ORDER-2 only. Must be purchased together.
BUY3AND1 - Buy VPS-BF-ORDER-3 and VPS-BF-ORDER-1 together to get 50% off one-time (non-recurring) on VPS-BF-ORDER-3 only. Must be purchased together.
Even without a coupon it's a great deal but add in a 20% one...
Pricing formula is getting another update so enjoy these while they last (but every attempt I've made to bring them back to reality has just made it worse so...) By worse I mean better for you guys of course.
Not pricing formula, pretty much the entire generation process. BUT it's so complicated now it might never get done.
@adly said:
I have to say, contrary to expectations, I like the AI support and hope this is expanded - there’s so much room for innovation here.
It's nice hearing positive feedback about it because in some cases it definitely is getting to the point where the AI support can actually be better than a human. I notice myself referring customers to using some of our AI features and it's usually not taken well, but I only do so in cases where I know for a fact they'll be able to resolve their issue much faster and accurately, especially if it's a limited support service and I would otherwise have to say "sorry, your support level, blah blah..."
There's an exciting update I finally pushed out: the ticket system now can utilize your service's VNC screen.
Example, breaking a virtual server on purpose to where it has no operating system and selecting "connection issue"
Without VNC - Assistant: Your VPS might not have a proper operating system installed or it's corrupted, which is why the IP doesn’t ping despite the VPS being online and VNC working. I recommend checking the OS installation via VNC. If it’s missing or corrupted, reinstall the OS through the control panel. Follow the knowledgebase article for guidance on OS installation.
This still is shockingly accurate, because it does get enough information to try to find the most likely issue. Also side note, when it says "follow the knowledgebase article" it's actually remnants of our old system in the background before AI, it means it located data it was trained on and knows in this particular case it means its not a connection issue, something people would have to otherwise have read a long list to decipher in the past. Another note, if you pick "VNC error" it comes with the same determination, but it's less confident.
With VNC - Assistant: Your VPS isn't booting because there's no operating system installed. The VNC screenshot confirms this with a "No bootable device" error. You should reinstall the OS. Check VirMach's knowledge base for steps on installing an operating system via their control panel.
Notice how it now seems to 100% believe this is the issue. Since we've moved to a newer AI for the chat feature as well, I've re-incorporated pushing the initial determination by the chat into the ticket AI, so the tickets should now take into account the determination from the VNC being checked.
The way it currently works is you have to explicitly approve it on this step. You only get a few seconds. I'll think about improving the process, and in the future it might only have an option to deny and default to approve instead, which would be noted.
It’s nice to see some actual innovation rather than just another VPS brand. I also share the view that automation and use of AI could be done much better in the industry, with customers benefiting from it rather than “just” being a cost cutting measure.
Where is my 1200GB NVMe idler?
I have "SPECIAL" that was OVZ... Migrate to KVM with weird spec ( 3c/3g/12g/500g ) -> Registration Date: 11/25/2016
Working coupons -> OG10 and ONEMOREIDLER
@VirMach is really awesome
Virmach Deals
MOARRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
Damn! @Virmach Got me again:
$5 DEAL!
$4 DEAL!
$3 DEAL!
$2 DEAL!
$1 DEAL!
ONEMOREIDLER
ONEMOREIDLER in Frankfurt or Seattle please.
No hostname left!
BIGGER DISK!!!
DIKSSSSSSSSSSSSS
@VirMach can you add 1000GB to the drive?
And a couple more cores and GBs of RAM. You'd probably also want more BW with that disk size. And to keep the price the same.
Made some changes for you. I think. It might get smaller who knows but the intention was to make it bigger.
Keep price the same? Why not lower it?
ONEMOREIDLER
VIVAVIRMACH
I hope to be alive to see the changes.
Going to a dangerous place right now. I hope they don't steal my Virmach servers.
TWOMOREIDLERS
VIVAVIRMACH
I'm very disappointed that there's no ONEMOREMISSIONCRITICALPRODUCTIONER.
@roseyysa said:
FTFY...
FORTYTWOMOREIDLERS
( Reduced heading size to cause less eye hurt )
blog | exploring visually |
A month after the return of VirBot I still have a tab open checking for deals.
That's also how I enjoy my break here at LES
But yet donno what to buy
Virmach Deals
Well it seems it didn't make it better.
By the time big disk deals come i would be so sleepy and tired...
I'm going to sleep in a moment. It's too late.
[Redacted]
(nvm - I wasn't logged in. D'oh!)
Finally
Virmach Deals
And offer 1864 - Amsterdam, will be my OneMoreIdler ...so much for trying to stay strong and resist, I am clearly weak
Yay for a nice Amsterdam though
