HostSailor - 12.12 Mega Deal: Get Your KVM VPS NVMe at 90% Recurring Discount – Forever!
1235»
  • vyasvyas OGSenpai
    Involucrated disks ?
    @localhost said:
    @vyas said:
    Is this Hostsailor offer the new (temporary hopefully) c1v ?
    More like coicu
    Thanked by (1)localhost
    @localhost said:
    More like coicu
    Involucrated disks which can not be replaced due to Chia cryptocurrency?
  • Can I get a confirmation of the location of the node #4? The ASN AS60117 is showing as either Romania or Netherlands depending on the site I use to check it (for example https://www.whatismyip.com/asn/60117/). Or if anyone knows an easier way to determine it besides latency math?
    its 2ms to Virmach AMS and 33ms to hosteroid BUC
    Thanked by (1)SocksAreComfortable
    If you just want to check whether it's in RO or NL, you can simply enter your IP into https://bgp.tools, and look what the upstreams are, in my case on node 2 the only upstream is "TNGNET B.V.", which, according to PeeringDB is only present in two NL datacenters.
    Theoretically they could be tunneling it to NL, but that can be disproved with latency tests, and IMHO latency tests are the most reliable ones, even though others (such as the aforementioned) may give some clues/indications.
    cpu_logger | Recommended providers: Layer7, dataforest (Avoro/PHP-Friends), @host_c
    Fair enough. Was hoping there was a trick besides latency math lol.
    Nice, hadn't seen that site before. Seems that node 4 is the same as node 2 based on my IP.
    Thanked by (1)lukast__
  • edited December 17
    LOL so doing some latency tests now out of curiosity (and because I apparently have 3 different VPS in Amsterdam now because reasons)...starting to think two of mine are in the same datacenter:
    rtt min/avg/max/mdev = 0.020/0.036/0.131/0.010 ms
    Thanked by (2)lukast__ ZizzyDizzyMC
  • @root said:
    The coupon from @hostsailor is still active, even though more than 24 hours have passed.
    HostSailor also sent an email to customers with a 80% off Christmas discount for Los Angeles. =)
    Feeling a bit tired, let's call it a day.
  • edited December 19
    Another coupon, this time for KVM VPS in USA (Los Angeles).
    They declare good speed for Asia:
    Our Los Angeles servers are providing excellent routing and low latency for our clients in Asia. Whether you're running websites, apps, or other online services, you'll enjoy faster, more reliable connectivity, ensuring a seamless user experience.
    Combine this with our 80% recurring discount for annual plans and supported Asian payment methods, and it's the perfect solution for your hosting needs!"
    (aff link)
    Coupon:
    KVMUS9090% recurring for annual orders (LES exclusive ;) )
    KVMUS80 — 80% recurring for annual orders.
    Thanked by (1)admax
    ☰ Probably the best Black Friday storage offersAMD EPYC VDSes with NVMe slices (ref) from 250GB to 4TB and 500GB–10TB SAN disk. / Big HDD storage VPSes (ref) from $2.42/month per TB. / Storage dedis and hybrid VPS (SSD + HDD) are there as well.
    Coupon:
    Many thanks, but shame on you for not including a non-affiliated link.
    https://clients.hostsailor.com/index.php?rp=/store/kvm-ssd
    The link above is clearly marked not just as a ref, but as a shameless ref.
    I know different people see this differently, but IMO using a ref is a good (and completely free) way to say "thank you" for searching and testing the coupons — just in case, email contains only the latter coupon (80% — see the picture). I added the former one myself.
    If you included a non-affiliated link, I would've used your aff, but you haven't.
    You can call it whatever. Follow the rules.
  • @zgato said:
    Follow the rules.
    I did — read them. LES rules require ref links to be labelled correspondingly.
    @zgato said:
    Follow the rules.
    Well...
    Affiliate links are fine if prefixed as affiliate links. (aff)
    It is not prefixed, but even if it was, not everyone will understand at first glance what "shameless ref" means anyway.
  • mikhomikho AdministratorOG
    Don't get your panties in a twist ladies ...
    I've edited the post to include (aff link) so hopefully even the new ones on the forum will understand it.
    @zgato said: If you included a non-affiliated link, I would've used your aff, but you haven't.
    Now that is petty ;)
    Okay, okay, changing my dress code to sackcloth and ashes.
    Was in a rush on Friday evening, looking to post ASAP, before the 90% coupon is wasted by MJJs (they have found it already).
    Thought that "shameless" will add some sarcasm to what I do. Didn't expect someone on this board to be unaware of what a referral link is.
    My attitude has a reason. He's also in the OGF doing some (IMO) rather shady practices regarding affiliated links.
    Not related to this post, so not gonna comment further.
  • @zgato said: He's also in the OGF doing some (IMO) rather shady practices regarding affiliated links
    Wow.
    Speaking of OGF and referral links, this can hardly get any nicer:
    zGato lowendtalk
    @mikho
    Clearly didn't want to start a linkstorm when posting the discount above. Probably delete my post and everything below.
    Thanked by (1)someTom
    Make the affiliated link larger pls
    and the no aff smaller.
    That I use hundreds of providers and most of them are rock solid is not my fault. I still have no aff providers there, but I'm not stupid, nor I can include both links in the signature.
    This is the main difference
  • Anyone else unable to reach HostSailor's client portal?
    That's all, folks!
    That's all, folks!
    Doesn't work for me either, but you can place an order and it will go through.
    (as long as WHMCS even works? I think it's completely down now, but partially worked for me when I placed the order)
    Thanked by (1)Freek
  • JabJab Senpai
    edited December 19
    WHMCS is shitting itself whole day today. Sometimes it's on, sometimes off. No idea if they doing something, getting ddosed or just too many requests.
    EDIT: this reminded me that I need to set up backup for my VPS, brb.
    Yup, but if you go to order directly it works
    You'll get the email and basically won't ever need WHMCS to work, as you can just use the SolusVM credentials.
  • Daily YABS of Sailor plan
    #                     v2024-12-17                    #
    Thu Dec 19 07:27:06 PM UTC 2024
    Uptime     : 6 days, 12 hours, 6 minutes
    Processor  : AMD EPYC 9534 64-Core Processor
    CPU cores  : 2 @ 2449.996 MHz
    RAM        : 1.9 GiB
    Swap       : 2.0 GiB
    Disk       : 47.1 GiB
    Distro     : Ubuntu 24.04.1 LTS
    Kernel     : 6.8.0-50-generic
    ISP        : HostSailor
    ASN        : AS60117 Host Sailor Ltd
    Country    : Romania
    fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda2):
    Read       | 199.57 MB/s  (49.8k) | 379.88 MB/s   (5.9k)
    Write      | 200.10 MB/s  (50.0k) | 381.88 MB/s   (5.9k)
    Total      | 399.68 MB/s  (99.9k) | 761.76 MB/s  (11.9k)
    Read       | 558.77 MB/s   (1.0k) | 662.60 MB/s    (647)
    Write      | 588.46 MB/s   (1.1k) | 706.73 MB/s    (690)
    Total      | 1.14 GB/s     (2.2k) | 1.36 GB/s     (1.3k)
    Clouvider       | London, UK (10G)          | 1.17 Gbits/sec  | 2.08 Gbits/sec  | --
    Eranium         | Amsterdam, NL (100G)      | 1.20 Gbits/sec  | 3.09 Gbits/sec  | --
    Uztelecom       | Tashkent, UZ (10G)        | 1.06 Gbits/sec  | 590 Mbits/sec   | --
    Leaseweb        | Singapore, SG (10G)       | 915 Mbits/sec   | 1.31 Gbits/sec  | --
    Clouvider       | Los Angeles, CA, US (10G) | 994 Mbits/sec   | 512 Mbits/sec   | --
    Leaseweb        | NYC, NY, US (10G)         | 1.04 Gbits/sec  | 1.11 Gbits/sec  | --
    Edgoo           | Sao Paulo, BR (1G)        | 864 Mbits/sec   | 550 Mbits/sec   | --
    Single Core     | 1612
    Multi Core      | 2744
    Full Test       | https://browser.geekbench.com/v6/cpu/9512801
    YABS completed in 12 min 13 sec
  • Ah i miss it :'(
    Hope Christmas Deal or New Year Deal will held soon <3
  • AuroraZeroAuroraZero ModeratorHosting Provider
    Can I put my weed in one of these?
  • My $6/yr VPS seems fine so far. There were some PHP errors on their site but they fixed it after I opened a ticket. Quite fast for the money IMHO, especially as it wasn't a flash sale.
    #                     v2024-12-20                    #
    Sat 21 Dec 14:20:48 GMT 2024
    Uptime     : 8 days, 21 hours, 29 minutes
    CPU cores  : 1 @ 2446.322 MHz
    RAM        : 958.7 MiB
    Swap       : 3.6 GiB
    Disk       : 28.4 GiB
    Kernel     : 6.1.0-18-amd64
    ISP        : Host Sailor Ltd
    Host       : Host Sailor Ltd
    Country    : The Netherlands
    Read       | 147.28 MB/s  (36.8k) | 425.47 MB/s   (6.6k)
    Write      | 147.67 MB/s  (36.9k) | 427.71 MB/s   (6.6k)
    Total      | 294.95 MB/s  (73.7k) | 853.19 MB/s  (13.3k)
    Read       | 488.26 MB/s    (953) | 548.23 MB/s    (535)
    Write      | 514.20 MB/s   (1.0k) | 584.74 MB/s    (571)
    Total      | 1.00 GB/s     (1.9k) | 1.13 GB/s     (1.1k)
    Clouvider       | London, UK (10G)          | 6.34 Gbits/sec  | 7.74 Gbits/sec  | 8.59 ms
    Leaseweb        | Singapore, SG (10G)       | 350 Mbits/sec   | 968 Mbits/sec   | 156 ms
    Leaseweb        | NYC, NY, US (10G)         | 1.73 Gbits/sec  | 2.35 Gbits/sec  | 78.5 ms
    Clouvider       | London, UK (10G)          | 7.48 Gbits/sec  | 4.49 Gbits/sec  | 8.45 ms
    Leaseweb        | Singapore, SG (10G)       | 832 Mbits/sec   | 1.10 Gbits/sec  | 156 ms
    Leaseweb        | NYC, NY, US (10G)         | 1.44 Gbits/sec  | 2.33 Gbits/sec  | 78.5 ms
    Geekbench 4 Benchmark Test:
    Single Core     | 5821
    Multi Core      | 5552
    Full Test       | https://browser.geekbench.com/v4/cpu/18364708
    Single Core     | 1417
    Multi Core      | 1089
    Full Test       | https://browser.geekbench.com/v6/cpu/9541942
    YABS completed in 16 min 36 sec
