Pikapods and YunoHost
SystemSystem Administrator
This discussion was created from comments split from: ElfHosted offers 20% off streaming bundles and Stremio addons.
Thanked by (1)jcn50
  • @nikhm2n said: @funkypenguin I have no idea what Elfhosted does different, but why are the prices multiple times more than pikapods for the same app? Also, I got lost navigating the website and after like 30 mins, I still don't know up from down.
    You can have cheaper than Pikapods with free YunoHost~
    🤡 "The tags provided to users are worthless permanent labels~ accept them or leave!" 🤡
  • @jcn50 said: free YunoHost~
    No free server to host YunoHost unfortunately.
    But, how good is YunoHost? Would you recommend it?
  • @nikhm2n said: No free server to host YunoHost unfortunately.
    You are free to host it where you want and on what you want~ you can get a (good) LES server starting from $6/year...
    @nikhm2n said: But, how good is YunoHost? Would you recommend it?
    Some APPS are not well maintained~ so you should be careful and always have backups (isn't that true for everything?). I would recommend YunoHost~ (I should probably write about this). Give it a try: it is FREE.
  • Cosmos OS, CasaOS, Runtipi - all seem much better than yunohost
    Team push-ups!
  • edited December 2024
    @Astro said: Cosmos OS, CasaOS, Runtipi - all seem much better than yunohost
    CosmosOS: the deployment is a pain, compared to a single line command with YunoHost on a Debian~
    CasaOS: seems to only have 1x APP (Jellyfin) ?!
    Runtipi: 4GB RAM min recommended~ and it was using all the 1GB RAM last time I tested it -- without having installed even a single APP yet! YunoHost can certainly run on a 512MB RAM VM, and if you don't run NodeJS apps a simple swap is enough.
  • @jcn50 said: CosmosOS: the deployment is a pain, compared to a single line command with YunoHost on a Debian~
    literally getting a docker container up thats it
    @jcn50 said: CasaOS
    Has an entire marketplace.
    Team push-ups!
  • There are now 2x main philosophies/ideas:
    -you continue to pay to host apps (PaaS)
    or
    -you switch to self-host (YunoHost alike) and it is so much cheaper/flexible/autonomous.
    Simple examples:
    -it is FREE to try out new apps
    -you are free to take a backup of your data, break something, then decide to restore (can you be that flexible with a PaaS?)
    -you manage the (sub)domain(s)
    -you can actually resale APPs running on YunoHost (!)
  • @Astro : at least you agree that self-hosting is better than PaaS?
    @Astro said: literally getting a docker container up thats it
    Docker is resources-hungry~ and that is the road of Runtipi~
    @Astro said: Has an entire marketplace.
    any link=?
