dnscry.pt - Public DNSCrypt resolvers hosted by LowEnd providers β’ Need a free NAT LXC? -> https://microlxc.net/
like this?
LTstats resource monitoring system | Recommended providers: Layer7, Onidel, Dataforest, Host-C, Gigahost, v6node | AS202986
@Brueggus said: like this?
Thatβs it, pretty sure it doesnβt break the rules if itβs aimed at a moderator π¬
Give us dem deals Mr Yeti @AuroraZero
Give us dem deals Mr YetiΒ @AuroraZero
i forgor to post YABS of This
here it is:
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-12-20 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon Dec 30 05:33:32 PM GMT 2024 100 45355 100 45355 0 0 166k 0 --:--:-- --:--:-- --:--:-- 166k Basic System Information: --------------------------------- Uptime : 8 days, 2 hours, 42 minutes Processor : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz CPU cores : 2 @ 2596.990 MHz AES-NI : β Enabled VM-x/AMD-V : β Enabled RAM : 3.8 GiB Swap : 0.0 KiB Disk : 49.9 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-9-amd64 VM Type : KVM IPv4/IPv6 : β Online / β Online IPv6 Network Information: --------------------------------- ISP : Dot-Tech LLC ASN : AS398395 Dot-Tech LLC Host : Kuroit Limited Location : Dallas, Texas (TX) Country : United States fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda3): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 127.58 MB/s (31.8k) | 1.45 GB/s (22.6k) Write | 127.91 MB/s (31.9k) | 1.45 GB/s (22.7k) Total | 255.50 MB/s (63.8k) | 2.91 GB/s (45.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.47 GB/s (2.8k) | 1.62 GB/s (1.5k) Write | 1.55 GB/s (3.0k) | 1.73 GB/s (1.6k) Total | 3.02 GB/s (5.9k) | 3.35 GB/s (3.2k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 794 Mbits/sec | 1.68 Mbits/sec | 105 ms Eranium | Amsterdam, NL (100G) | 828 Mbits/sec | 44.0 Mbits/sec | 115 ms Uztelecom | Tashkent, UZ (10G) | 539 Mbits/sec | 15.8 Mbits/sec | 207 ms Leaseweb | Singapore, SG (10G) | 538 Mbits/sec | 18.0 Mbits/sec | 211 ms Clouvider | Los Angeles, CA, US (10G) | 886 Mbits/sec | 44.5 Mbits/sec | 31.7 ms Leaseweb | NYC, NY, US (10G) | 851 Mbits/sec | 57.9 Mbits/sec | 39.1 ms Edgoo | Sao Paulo, BR (1G) | 739 Mbits/sec | 2.50 Mbits/sec | 147 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 812 Mbits/sec | 13.2 Mbits/sec | 104 ms Eranium | Amsterdam, NL (100G) | 809 Mbits/sec | 217 Mbits/sec | 115 ms Uztelecom | Tashkent, UZ (10G) | 93.7 Mbits/sec | 17.6 Mbits/sec | 204 ms Leaseweb | Singapore, SG (10G) | 505 Mbits/sec | 19.2 Mbits/sec | 210 ms Clouvider | Los Angeles, CA, US (10G) | 888 Mbits/sec | 34.9 Mbits/sec | 31.5 ms Leaseweb | NYC, NY, US (10G) | 884 Mbits/sec | 27.7 Mbits/sec | 37.6 ms Edgoo | Sao Paulo, BR (1G) | 776 Mbits/sec | 14.2 Mbits/sec | 147 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 908 Multi Core | 1500 Full Test | https://browser.geekbench.com/v6/cpu/9689214 YABS completed in 21 min 36 sec
@Blembim said: i forgor to post YABS of This here it is: FYI upstream ISP is HIVELOCITY # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-12-20 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon Dec 30 05:33:32 PM GMT 2024 100 45355 100 45355 0 0 166k 0 --:--:-- --:--:-- --:--:-- 166k Basic System Information: --------------------------------- Uptime : 8 days, 2 hours, 42 minutes Processor : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz CPU cores : 2 @ 2596.990 MHz AES-NI : β Enabled VM-x/AMD-V : β Enabled RAM : 3.8 GiB Swap : 0.0 KiB Disk : 49.9 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-9-amd64 VM Type : KVM IPv4/IPv6 : β Online / β Online IPv6 Network Information: --------------------------------- ISP : Dot-Tech LLC ASN : AS398395 Dot-Tech LLC Host : Kuroit Limited Location : Dallas, Texas (TX) Country : United States fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda3): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 127.58 MB/s (31.8k) | 1.45 GB/s (22.6k) Write | 127.91 MB/s (31.9k) | 1.45 GB/s (22.7k) Total | 255.50 MB/s (63.8k) | 2.91 GB/s (45.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.47 GB/s (2.8k) | 1.62 GB/s (1.5k) Write | 1.55 GB/s (3.0k) | 1.73 GB/s (1.6k) Total | 3.02 GB/s (5.9k) | 3.35 GB/s (3.2k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 794 Mbits/sec | 1.68 Mbits/sec | 105 ms Eranium | Amsterdam, NL (100G) | 828 Mbits/sec | 44.0 Mbits/sec | 115 ms Uztelecom | Tashkent, UZ (10G) | 539 Mbits/sec | 15.8 Mbits/sec | 207 ms Leaseweb | Singapore, SG (10G) | 538 Mbits/sec | 18.0 Mbits/sec | 211 ms Clouvider | Los Angeles, CA, US (10G) | 886 Mbits/sec | 44.5 Mbits/sec | 31.7 ms Leaseweb | NYC, NY, US (10G) | 851 Mbits/sec | 57.9 Mbits/sec | 39.1 ms Edgoo | Sao Paulo, BR (1G) | 739 Mbits/sec | 2.50 Mbits/sec | 147 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 812 Mbits/sec | 13.2 Mbits/sec | 104 ms Eranium | Amsterdam, NL (100G) | 809 Mbits/sec | 217 Mbits/sec | 115 ms Uztelecom | Tashkent, UZ (10G) | 93.7 Mbits/sec | 17.6 Mbits/sec | 204 ms Leaseweb | Singapore, SG (10G) | 505 Mbits/sec | 19.2 Mbits/sec | 210 ms Clouvider | Los Angeles, CA, US (10G) | 888 Mbits/sec | 34.9 Mbits/sec | 31.5 ms Leaseweb | NYC, NY, US (10G) | 884 Mbits/sec | 27.7 Mbits/sec | 37.6 ms Edgoo | Sao Paulo, BR (1G) | 776 Mbits/sec | 14.2 Mbits/sec | 147 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 908 Multi Core | 1500 Full Test | https://browser.geekbench.com/v6/cpu/9689214 YABS completed in 21 min 36 sec
Download doesn't look good IMHO.
@lukast__ said: Download doesn't look good IMHO.
ya, it was better here. maybe something going on with HIVELOCITY
Give us prem dealz @Micronode .
Β£8/year Resource Large, recurring
@AuroraZero has to honor the recurring dealz
@Blembim said: Give us dem deals Mr Yeti @AuroraZero
@Blembim said:
Give us dem deal Mr. Yeti-san @AuroraZero ! < lol >
We are also still waiting for the first daredevil provider to post an IRC-only offer.
He's keeping them to himself.
@yoursunny said: Give us prem dealz @Micronode . Β£8/year Resource Large, recurring @AuroraZero has to honor the recurring dealz
I donβt make the dealZ anymore
Feeling very tired, let's call it a day.
Heβs given all of the deals to miss yeti
Why AI images are so Kubrickian; so symmetrical and one-point perspective.
@WSS said: @AuroraZero said: @imok said: @AuroraZero ban the people giving multiple thanks (because I don't know how they do it) Glitch in the Matrix Your mom's a yeti.
Your mom's a yeti.
I know we have the same mom!
Lifetime Directadmin Shared Hosting Plans
3GB SSD Space Unlimited Emails Unlimited Domains 1TB Bandwidth Available in USA), DE and SG (Singapore, Asia, UK ) Price: $40/Lifetime Order:
β VisualWebTechnologies.com - Your Hosting, Our Responsibility! βView Offers ( cPanel/DirectAdmin & Reseller Hosting Offers )
@visualwebtechno said: Lifetime Directadmin Shared Hosting Plans 3GB SSD Space Unlimited Emails Unlimited Domains 1TB Bandwidth Available in USA), DE and SG (Singapore, Asia, UK ) Price: $40/Lifetime Order:
$3 lifetime deal. $7 if you want to rob me.
You posted a $20 2GB lifetime deal on OGF. Show us some love too. Give us a better deal.
Team push-ups!
@Astro said: @visualwebtechno said: Lifetime Directadmin Shared Hosting Plans
@Astro said:
8GB SSD Space Unlimited Emails Unlimited Domains 1TB Bandwidth Available in USA), DE and SG (Singapore, Asia, UK ) Price: $40/Lifetime Order:
Try this one is better
@visualwebtechno said: @Astro said: @visualwebtechno said: Lifetime Directadmin Shared Hosting Plans 8GB SSD Space Unlimited Emails Unlimited Domains 1TB Bandwidth Available in USA), DE and SG (Singapore, Asia, UK ) Price: $40/Lifetime Order: Try this one is better
amazing
but looking to spend less and not more
@Astro said: but looking to spend less and not more
maybe you meant to write "but looking to spend on LES" ...
blog | exploring visually |
I'll shoot you a PM shortly!
cybertech nick_ toumi111 derekyang MMMMMM FrankZ DrNutella root IV__ dinhvanlocitvn curiouswanderer lowendmeow user123 slownedstark FAT32 dosai codelock Linux admax KernelPanic zgato vyas Frobsy easymoney sh97 Crab localhost _MS_ gsif mayiprint hentaihalo Brueggus kheng86 beagle gritty huginn hyperton cybersurfer jdjx Mei lleddewk teamacc selalumenang cmeerw NullSir DataRecovery FairShare lukast__ Dazzle yoursunny davi arirang WSS Aitilos Astride3961 cainyxues bliss amj gemini86 CaptFidfaddy Richard atomi isenganime snailprincessch tototo LowEnd abtdw how
Hello
like this?
here it is:
NO-HOMO-YETI
ANAL POLYP PROVIDER
3GB SSD Space
Unlimited Emails
Unlimited Domains
1TB Bandwidth
Price: $40/Lifetime
Order:
All jokes aside, thanks for the amazing deals @visualwebtechno
Team push-ups!
8GB SSD Space
Unlimited Emails
Unlimited Domains
1TB Bandwidth
Price: $40/Lifetime
Order:
amazing
Team push-ups!
Congratulation @Crab you're the winner of New Year's Eve giveaway!!
out of 69
entries 68 were eligible
Happy New Years!
Hello
