🌟 Announcing lowendirc.com – The IRC Home for the LowEnd Community 🌟
124
    @itsdeadjim Congrats! If I counted right, there now are 41 people logged in to #general. It's a nice party! :star:
    /list
  • edited December 2024
    Next year we should arrange an amiga demoparty
  • The #deals channel now features the low-end-web-bot, monitoring LET/LES for the latest offers :)
    If I understand right, the lowendirc server is using anope services. Here is a link to anope services' syntax page, which has been helpful to me:
    https://clients.sisrv.net/knowledgebase/86/Anope-Services-commands.html
    Best wishes!
    Thanked by (3)whoami itsdeadjim wankel
    Best wishes!
    Yeah it's using anope services. /ns help and /cs help provide extensive documentation for nickserv and chanserv services
    Well, my bouncer can't connect to the IRC anymore, anything died?
  • I guess I'll try to remember that I have The Lounge running this time...
    I was able to connect just now. Still having issues?
    Yea looks fixed
    Thanked by (2)Decicus Not_Oles
    Well, big rip
    " Cannot join #$7 (Channel is invite only)"
    One network outage and then this
  • edited January 2
    Probably random event, I didnt see anything weird
    @Neoon said:
    Well, big rip
    The channel #$7 is indeed invite only. Was this done by mistake? I don't keep such logs
    edit: @dedicados i see that you initially created this channel, if you locked this by mistake, tell me to unlock it
    Yea looks fixed
    Well, it seems like network issues again.
    Do you guys got a list of nodes?
  • @Neoon said:
    Yea looks fixed
    Try us1.lowendirc.com
    Send me your IP in pm, maybe it's blocklisted or something
    @itsdeadjim said:
    @Neoon said:
    Yea looks fixed
    Its a timeout and then reconnects, doesn't look like a block to me.
  • @Neoon said:
    @itsdeadjim said:
    @Neoon said:
    Yea looks fixed
    Server side you look like exiting with "Connection closed". Seems like a client side disconnect
    @itsdeadjim said:
    @Neoon said:
    @itsdeadjim said:
    @Neoon said:
    Yea looks fixed
    I am connected to a bunch of IRC networks, hence I asked for list of nodes.
    I will try the US one.
  • @Neoon said: I will try the US one.
    It is ipv4 only by the way
    @yoursunny
    If you need more servers for the IRC network, just say it.
    @yoursunny
    Not my fault blame @IV__ for that :)
  • @itsdeadjim said:
    @yoursunny
    Thank you @itsdeadjim
    :) but I can't hide that fact that is there... that server does not have ipv6, but it does have ipv9 to comply with @yoursunny standard.
    Thanked by (2)itsdeadjim Not_Oles
    The ii IRC client which I hopefully am learning to use writes output from the IRC server into "out" files in different directories, one per channel. For example, ii makes a new chanserv directory when "/cs help" is used for the first time. That fooled me the first time I asked chanserv for help, because I didn't know that chanserv would be treated by ii like a channel and so have its own directory. I expected the output of "/cs help" to be in standard output of the ii command, similar to the output of "/HELP". If you might be interested, please check the listings below.
    Here is ii making a new directory for chanserv:
    tom@ctrl-c:~/irc/lowendirc.com$ ls # No chanserv directory prior to asking chanserv for help
    '#bsd'      '#lowendspirit'   cmeerw       in         nohup.out   who-1735254649
    '#general'   aulyaryan        guest11221   nickserv   out
    tom@ctrl-c:~/irc/lowendirc.com$ date +%s
    1735876981
    tom@ctrl-c:~/irc/lowendirc.com$ echo "/cs help" > in
    tom@ctrl-c:~/irc/lowendirc.com$ ls # Now there is a newly created chanserv directory
    '#bsd'      '#lowendspirit'   chanserv   guest11221   nickserv    out
    '#general'   aulyaryan        cmeerw     in           nohup.out   who-1735254649
    tom@ctrl-c:~/irc/lowendirc.com$ cat chanserv/out
    1735877006 -!- "ChanServ allows you to register and control various")
    1735877006 -!- "aspects of channels. ChanServ can often prevent")
    1735877006 -!- "malicious users from "taking over" channels by limiting")
    1735877006 -!- "who is allowed channel operator privileges. Available")
    1735877006 -!- "commands are listed below; to use them, type")
    1735877006 -!- "/msg ChanServ command. For more information on a")
    1735877006 -!- "specific command, type /msg ChanServ HELP command.")
    1735877006 -!- "    BAN            Bans a given nick or mask on a channel")
    1735877006 -!- "    DROP           Cancel the registration of a channel")
    1735877006 -!- "    GETKEY         Returns the key of the given channel")
    1735877006 -!- "    HELP           Displays this list and give information about commands")
    1735877006 -!- "    INFO           Lists information about the specified registered channel")
    1735877006 -!- "    INVITE         Invites you or an optionally specified nick into a channel")
    1735877006 -!- "    KICK           Kicks a specified nick from a channel")
    1735877006 -!- "    LIST           Lists all registered channels matching the given pattern")
    1735877006 -!- "    REGISTER       Register a channel")
    1735877006 -!- "    STATUS         Find a user's status on a channel")
    1735877006 -!- "    UNBAN          Remove all bans preventing a user from entering a channel")
    1735877006 -!- " ")
    1735877006 -!- "Used to manage the list of privileged users")
    1735877006 -!- "  ACCESS, AOP, FLAGS, HOP, LEVELS, QOP, SOP")
    1735877006 -!- "  VOP")
    1735877006 -!- " ")
    1735877006 -!- "Used to modify the channel status of you or other users")
    1735877006 -!- "  DEHALFOP, DEOP, DEOWNER, DEPROTECT, DEVOICE")
    1735877006 -!- "  DOWN, HALFOP, OP, OWNER, PROTECT, UP, VOICE")
    1735877006 -!- " ")
    1735877006 -!- "Used to manage channels")
    1735877006 -!- "  AKICK, CLONE, ENFORCE, ENTRYMSG, LOG, MODE")
    1735877006 -!- "  SET, SYNC, TOPIC")
    1735877006 -!- " ")
    1735877006 -!- "Use the HELP ALL command to list all commands and their descriptions.")
    1735877006 -!- " ")
    1735877006 -!- "Note that any channel which is not used for 14 days")
    1735877006 -!- "(i.e. which no user on the channel's access list enters")
    1735877006 -!- "for that period of time) will be automatically dropped.")
    However, the response from the general "/HELP" command seems to be written to standard output from the login command, and thus, in my case, shows up in the nohup.out file because I am running ii with nohup.
    tom@ctrl-c:~/irc/lowendirc.com$ date +%s; echo "/HELP" > in; sleep 1; tail -n 20 nohup.out
    1735878050
    1735878050 :lowendirc.com 292 tom : -
    1735878050 :lowendirc.com 290 tom :        ***** UnrealIRCd Help System *****
    1735878050 :lowendirc.com 292 tom : Server Commands Help.
    1735878050 :lowendirc.com 292 tom : Specify your Question after the /HELPOP command.
    1735878050 :lowendirc.com 292 tom : You will find all of the server commands and options
    1735878050 :lowendirc.com 292 tom : available for use.
    1735878050 :lowendirc.com 292 tom : If you need extra assistance please visit the server's
    1735878050 :lowendirc.com 292 tom : help channel or ask an available IRCop.
    1735878050 :lowendirc.com 292 tom : /HELPOP USERCMDS - To get the list of User Commands
    1735878050 :lowendirc.com 292 tom : /HELPOP OPERCMDS - To get the list of Oper Commands
    1735878050 :lowendirc.com 292 tom : /HELPOP SVSCMDS  - Commands sent via U-Lined Server (Services)
    1735878050 :lowendirc.com 292 tom : /HELPOP UMODES   - To get the list of User Modes
    1735878050 :lowendirc.com 292 tom : /HELPOP SNOMASKS - To get a list of Snomasks
    1735878050 :lowendirc.com 292 tom : /HELPOP CHMODES  - To get the list of Channel Modes
    1735878050 :lowendirc.com 292 tom : ==-------------------------oOo--------------------------==
    1735878059 PING :lowendirc.com
    I'm new to IRC, so I'm having fun trying various clients. In case anybody else might be interested in ii, here are some links:
    https://en.wikipedia.org/wiki/Ii_(IRC_client)
    https://tools.suckless.org/ii/
    https://tools.suckless.org/ii/usage/ # If interested, definitely check this page. Lots of stuff there.
    You can get the ii source code with:
    chronos@penguin:~/src$ git clone https://git.suckless.org/ii
    The ii source code is not too big, so maybe I can understand some of it:
    chronos@penguin:~/src/ii$ grep -v '#' ii.c | grep -v -e '^$' | wc -l
    737
    Thanks to @itsdeadjim for making the fun lowendirc.com server! <3
    I'm new to IRC
    My friend, I started 1990 so I expected you to be around no later than 1989!
    You should really start using irssi as it is what I call 'the latest and the greatest' of console clients. irssi does the same logging per channel and a lot of other things as well. You should be able to compile it on almost any platform or get it through whatever package manager is applicable.
    edited January 3
    @Crab said:
    @Not_Oles said:
    I'm new to IRC
    In 1972, I remember watching a group of laughing guys scrolling ascii art off a Teletype 33. But I didn't do much with computers myself until much later. And I never have done much with IRC.
    You got me! I am using irssi on Libera.
    Inside tmux.
    Now, about tmux, connected to a server via ssh from inside my Chromebook's Terminal App, I haven't figured out how to get "infinite" scrollback with irssi on tmux with my Chromebook's trackpad like I can get with output from tail -f.
    tmux seems to want Ctrl+[ and then the up or down arrow keys. Any chance you, very knowledgeable about almost everything, know how to get irssi inside tmux to recognize my Chromebook's trackpad without changing my Chromebook's default key assignments?
    Thanks so much! And I do promise to try irssi on lowendirc.com. Thanks for the kind suggestion! :)
    God I am old
    Thanked by (2)Not_Oles itsdeadjim
    God I am old
    I knew it!
  • skorousskorous OGSenpai
    Sounds like at least @Crab and I are older. And that's not including the old guy talkin' about Teletypes. :P
    Thanked by (2)wankel Not_Oles
    Possible excpet I am used to Smoke signals on hills!!!
  • The pressure from @yoursunny was too high, now us1.lowendirc.com support ipv6
  • And finally, we have a web client!
    Thanks to @Mumbly, you can now join directly from your browser:
    https://webchat.lowendirc.com
    Thanked by (4)Not_Oles loay Mumbly Ympker
  • It wasn't me! @itsdeadjim just wants to put the blame on me if something doesn't work! Don't believe him!
    Damned nosey cat anyways I knew he was trouble!!!
    Thanked by (3)itsdeadjim Mumbly Not_Oles
