natvps.net - ipv6 + Alpine trouble
edited January 2025 in Help
Can't ping default ipv6 gw from the Alpine Linux instance.
Should it be working out of the box?
kvm USA
    kvm USA
    Setup the network manually and see if it works.
    kvm USA
    This is correct, I learned this the hard way. @vict0r I assume you got a NAT vps and have yet to configure IPV6 other than just seeing it assigned in the network tab on VPS Control panel. Let us know with details if otherwise.
  • edited January 2025
    Yes it's a NAT vps. Their Debian and CentOS images does set it up with working ipv6 connectivity.
    So far I've done something like:
    ip -6 addr flush dev eth0
    ip -6 neigh flush dev eth0
    ip -6 route flush dev eth0
    ip -6 addr add [mystaticipaddressasprovidedinthecontrolpanel] dev eth0
    ip -6 route add default via [gwaddressasprovidedsomewhere] dev eth0
    Probably not correct. Please help.
  • 1. Check IPv6 Availability
    Ensure your server's network interface supports IPv6. Use:
    ip -6 addr
    If IPv6 is enabled, you’ll see an output listing IPv6 addresses.
    2. Locate the Network Interface
    Identify your network interface (e.g., eth0, ens33, etc.):
    ip link show
    3. Edit the Network Configuration File
    The configuration files are located in /etc/sysconfig/network-scripts/.
    Open the file for your network interface, e.g., ifcfg-eth0:
    sudo nano /etc/sysconfig/network-scripts/ifcfg-eth0
    4. Add IPv6 Settings
    Append or modify the following lines with your IPv6 details:
    IPV6INIT=yes
    IPV6ADDR=your_ipv6_address/prefix
    IPV6_DEFAULTGW=your_ipv6_gateway
    Replace your_ipv6_address with your assigned IPv6 address and your_ipv6_gateway with the gateway.
    5. Restart the Network Service
    Save the file and restart the network service to apply changes:
    sudo systemctl restart network
    6. Verify IPv6 Configuration
    Check if the IPv6 address is assigned to your interface:
    ip -6 addr show
    Ping an IPv6 address to ensure connectivity:
    ping6 google.com
    7. Enable IPv6 Permanently (Optional)
    If IPv6 is disabled globally, enable it in /etc/sysctl.conf or /etc/sysctl.d/99-sysctl.conf:
    net.ipv6.conf.all.disable_ipv6 = 0
    net.ipv6.conf.default.disable_ipv6 = 0
    Apply changes:
    sudo sysctl -p
    Thanked by (1)DrNutella
    Yeah, my first question would be "Do you know it's eth0?" That's less common now than it used to be.
    KVM chances are high but you are correct best to check.
    Here is my network configuration on natvps.net with alpine linux, you need to change the IP to yours:
    wh-us:~$  cat /etc/network/interfaces
    auto lo
    iface lo inet loopback
    auto eth0
    iface eth0 inet static
        address 192.168.100.10
        netmask 255.255.255.0
        gateway 192.168.100.1
        dns-nameservers 8.8.4.4 1.0.0.1
    iface eth0 inet6 static
        address 2a00:5000:60::b/80
        gateway 2a00:5000::2
        pre-up echo 0 > /proc/sys/net/ipv6/conf/eth0/accept_ra
    By the way, IPv6 doesn't work from time to time on Canada node, but I don't bother to open a ticket and just don't renew it.
  • Thank you.
    It is now working.
    The cloud init script in the Alpine Linux image does not set:
    That was the culprit.
