VirMach * 2024 * RYZEN * NVMe ** VPS Black Friday * Flash Deals ** Check inside for offers!
1108109110111112114»
  • edited January 6
    @cybertech said:
    any 2C2G50GB $7/yr?
    Right now for example:
    $ 14.67 PER YEAR
    KVM
    RYZEN SKU# V03-XD
    RAM 2560MB DDR4 RAM
    CPU 2 Core CPU vCORE
    HDD 60GBSSD (NVMe)
    BANDWIDTH 3072GB BANDWIDTH
    IPs 1 IPv4 DEDICATED IPv4
    Miami, Florida.
    @Newyawker said:
    @cybertech said:
    any 2C2G50GB $7/yr?
    $ 14.67 PER YEAR
    KVM
    RYZEN SKU# V03-XD
    RAM 2560MB DDR4 RAM
    HDD 60GBSSD (NVMe)
    Miami, Florida.
    $7 would be good
  • @cybertech said:
    @Newyawker said:
    @cybertech said:
    any 2C2G50GB $7/yr?
    $ 14.67 PER YEAR
    KVM
    RYZEN SKU# V03-XD
    RAM 2560MB DDR4 RAM
    HDD 60GBSSD (NVMe)
    Miami, Florida.
    $7 would be good
    If you have access to the 30% coupon it'd be $10.27, about as good as you'd get that specs from Virmach now.
    where is the 30% coupon?
    The coupon is OG30 - but only qualifying for those that still have an active 2018 KVM special in their collection, one usage per qualifying client only
    (Also OG20 if you have a 2019 and OG10 if you have a 2020)
    Thanked by (1)matcha
    edited January 6
    Now that I'm (back) at 14 VPS!.. I was supposed to be reducing them to 10 or less!!
    Still forlornly awaiting one more idler with 2IP in ATL, to use up the balance that I needed to add previously.
  • @FrankZ said: Secaucas, NJ
    Someone trying to be politically geographically correct? :p
  • sanvitsanvit OG
    edited January 6
    Ooh wasn’t aware of this. Thank you! Are these coupon single-use?
    Edit: found the OP. It’s single use
    Where is the OP?
    Quite rare location, a bit regret for missing it
  • @matcha said: a bit regret for missing it
    Yup, you're definitely missing something!
  • @FrankZ said:
    There are still great deals being put out by VirBot.
    Anybody have any money left ?
    Money isn't a concern, but no hostname left.
    Thanked by (1)eb1995
    No hostname left!
    Where is the OP?
    https://lowendspirit.com/discussion/comment/198999#Comment_198999
    1.hostname.com 2.hostname.com ...
    More hostnames than IPv6 addresses.
  • edited January 6
    He means his own internal VPS0 to VPS9 policy - (he is weird like that) he has great mental strength and self-control / self-restraint :p
    Thanked by (3)skorous FrankZ yoursunny
  • @yoursunny said:
    Mentally strong people install Debian from ISO.
    Templates are for beginners.
    mentally strong people install Debian the Arch Linux way
    https://www.debian.org/releases/bookworm/amd64/apds03.en.html
    because Debian installer expert mode sucks ass
  • @yoursunny said:
    @cybertech said:
    this is the solution y'all
    https://netboot.xyz/docs/booting/grub
    no template no mount iso no nothing
    Netboot won't work with 384/512/768 RAM.
    Debian installer has low ram mode. For bookworm 512M should be fine, not sure about 384M but preseed works
  • FrankZFrankZ ModeratorOG
    Another sweet deal from VirBot
    $9.26 PER YEAR
    1024MB DDR4 RAM
    1 Core CPU vCORE
    50GB SSD (NVMe)
    6656GB BANDWIDTH
    IPs 2 IPv4
    Secauscas, NJ [AKA NYC Metro]
    Thanked by (2)sh97 abtdw
    Self-control is how we earned the respect of the deal compiler awww.
    Thanked by (2)admax FAT32
    No hostname left!
    There are more possible hostnames than IPv6 addresses....
    Thanked by (1)imok
  • KrisKris Content Writer
    Mentally strong people use uuidgen and never run out of hostnames.
    Thanked by (2)imok Decicus
    $9.26 PER YEAR
    1024MB DDR4 RAM
    1 Core CPU vCORE
    50GB SSD (NVMe)
    6656GB BANDWIDTH
    IPs 2 IPv4
    How does it keep doing that? I thought I finally fixed the multiple IP address pricing bug. I guess I didn't look into it that long.
    $9.26 PER YEAR
    1024MB DDR4 RAM
    1 Core CPU vCORE
    50GB SSD (NVMe)
    6656GB BANDWIDTH
    IPs 2 IPv4
    Why fix? it will ruin much fun.
  • Good morning.
    I want to see virbot source code.
    Maybe it's @VirMach updating everything manually.
  • vyasvyas OGSenpai
    @Virmach,
    Ref: Ticket #752809 and the post: https://lowendspirit.com/discussion/comment/202932/#Comment_202932
    "Make a new reply on the thread quoting thee original question on whether you want it or not and explicitly state yes or no on the second roll"
    My response:
    Given the timing - Ryzen 5120 my response is yes,
    Second roll/ Dealers' Choice- Answer is No.
    Posting my response below since the Christmas/ Hanukkah thread is closed. In case of any mis-interpretation of my original response, my learning- to be clear and doubly clear in communication.
    Thanks
    @vyas said:
    Order Number is: 1591747086
    >@virmach said:
    » show previous quotes
    UnimportantVengeful-VM
    I'll just do a wheel for the rest of these instead of picking a number. Okay, focus, record the GIF and do not overwrite.
    And then after that, it's dealer's choice for your second dice roll. Anything goes. I'm definitely going to opt out of doing it the complicated way I did dealer's choice in the past, that took way too long and only made sense in bulk.
    Okay uhhhh... we'll reset the specs to normal. Kidding. I still want it to kind of be random, so we'll do this. I haven't looked at the node you've landed on yet, I'll give you a choice, do you want to keep it the way it is (Ryzen 5120), or proceed with the following?
    If the node has above 1000GB disk left, you get an extra +100GB disk, if it's below, it's reduced to 60GB disk (as in 60GB disk.)
    If the node has above 40GB free memory left over the way I usually manually check it (40,xxx -- not exact) you get 3GB extra RAM, if it's below, reduced to 3GB.
    If the node has below 3TB bandwidth utilization by the time you reply/it's checked so far in the month (it's been 48~ hours since reset) you get an extra 3TB bandwidth, if it's less, you get reduced by 3TB bandwidth.
    If the node has below 20% CPU utilization the way I usually manually check it, you get 2 extra cores. If it's in between 20% and 30% you get the same, and if it's above 30% you get 1 core less.
    If the node has a bunch of extra IP addresses available (at my discretion, since we're not removing any) you get an extra IP as well.
    @vyas said:
    @Virmach,
    My response:
    Thanks
    Okay, processed. This doesn't count, what it would have been with second roll:
    +100GB disk (1.46TB left)
    +3GB RAM (46GB)
    +3TB bandwidth (800GB used)
    +2 Cores (6% CPU utilization)
    (No extra IPs)
    Thanked by (2)user123 FrankZ
    so who else won big? do share your specs
    Thanked by (1)admax
    $9.26 PER YEAR
    1024MB DDR4 RAM
    1 Core CPU vCORE
    50GB SSD (NVMe)
    6656GB BANDWIDTH
    IPs 2 IPv4
    VirBot and me we have this thing going on.
