[Resolved] rysnc: systemd[1] segfault at [...] error 6 in libsystemd-shared249.so
edited January 2025 in Help
Guys,
I am trying to migrate data from a Xen VM to a KVM and while the rsync is in progress, it stops and disconnects, throwing this on the VNC:
Any help would be appreciated~
🤡 "The tags provided to users are worthless permanent labels~ accept them or leave!" 🤡
    Can't tell exactly what you are doing but maybe slowing it down a bit might help. Are you using a "--bwlimit"?
    rsync -az --bwlimit=2512 -e "ssh"
    Thanked by (1)ehab
  • edited January 2025
    @FrankZ said: Are you using a "--bwlimit"?
    no, shall I?
  • Ah, I have upgraded the destination VM before doing the rsync then rebooted, it seems to be doing OK now! So I guess my problem is resolved!!
