1334335337339340400
  • edited January 6
    @Ahui said:
    @Ahui said:
    It seems that you have become accustomed to being humble and kneeling, so keep kneeling and continue using this provider that easily imposes the death penalty
    I don't think you understand the difference between a VPS and a VDS. If you want to use 100% of the resources assigned all the time you need to buy a VDS. A VPS has shared resources and can only be used at high rates for a limited time.
    Your question is very good. Let me ask you a few questions
    1.VPS will first directly restrict IO usage, for example, each VPS will only have 2000IOPS
    2.When VPS uses 1000IOPS, the provider will directly sentence you to death and permanently ban VPS
    3.Have you experienced the issue of IO abuse being sentenced to death by other providers?
    Let me help you out here. I have a few VMs that I am not going to use from other providers in the EU that ether have hard limits on I/O or do not have hard limits but let people run wild. Let me see which one will let me transfer one to you. I'll give it to you for free for almost a year. It's Christmas after all. They are all much bigger than your 768MB VPS, lets see if that works for you.
    Thank you for your help. I want to say thank you to you. I have many VPS, 50-60 , and I also have 15 on @ VirMach. I just find it unbelievable
  • From the kind of answers he gives, I've come to a conclusion, but no one cares so I keep it to myself.
  • BTW I've run out of flan.
    It's arroz con leche time... maybe.
    Thanked by (2)imok admax
    You are all great, it's just that this provider is too bullying users when dealing with things
    I had a several suspensions a few years ago on a @Virmach VPS I still have. I was perplexed and stated so in a ticket. @Virmach gave me advice how to potentially fix/avoid suspension. I've not had trouble since. My experience was that @Virmach worked with me rather than giving me the ax immediately. At the time, the VPS was running a spigot (minecraft) server for a handful of users. One user was apparently going crazy flying over massive amounts of unexplored terrain. I put a limiter on the server to deal with it.
    I think its really harsh to say @Virmach is bullying. Frankly, I think you're being rude. It's hard to want to help rude people. I'm surprised at @FrankZ 's offer... also impressed. Take a deep breath, calm down. It feels like the flood of stacatto messages and answers really do not have meat (detailed facts). I doubt that will help the situation.
    Thanked by (2)imok FrankZ
  • @Ahui said: I have many VPS, 50-60
    what do these people do with this much vps? vpn? jumpbox to clean the tracks?
    That suggests you are using a low-end provider in some type of production (that is to say "serious use") environment. This may not be a good idea.
    In other news ....
    I finally had my VirMach only regional failover system fail completely after 1456 days [3.98 years] of continuous website uptime.
    Was it VirMach's fault ?
    Not this time. it was my fault for not updating a certificate chain.
    I had 15 minutes of downtime while I corrected it.
    So I'm now down to 99.9992846% uptime with VirMach on this production website.
  • JabJab Senpai
    Outrageous!
  • @FrankZ said:
    In other news ....
    tutorial?
  • @imok said: tutorial?
    Jeez, is this the first sensible comment, ever?
    Just saying.
    @FrankZ i wouldnt mind some help too lol
  • FAT32FAT32 OGSenpai
    @tulipyun said:
    @FAT32 said:
    @tulipyun said:
    @FAT32 said:
    Any tips on installing for 128MB RAM on VirMach servers? I tried a few ways via ISO/Netboot directly but all of them crashed/killed with OOM (Debian 9+, AlmaLinux 8+)
    You can run debian 10 on a VPS with 128M RAM by using the official debian cloud image.
    1. Download from here: https://cloud.debian.org/images/cloud/buster/latest/
    2. Add your own password to the image using virt-customize
    virt-customize -a disk.raw --root-password password:yourpass
    1. Compress and upload your image to your own server.
    2. DD to your 128M RAM VPS and shutdown (using POWER OFF)
    3. Login and use the VPS
    Thank you, so basically I boot into rescue more and dd into the disk right? Let me try :)
    Yes, write an image from another server DD in rescue mode (make sure that image has your own password written to it)
    Just like:
    wget -O- “http://11.11.11.11/10disk.raw.xz” | xzcat | dd of=/dev/vda
    Since the rescue mode version is quite old, you may also need to update some software like wget or xz or something like that.
    Good luck!
    Well I given up at this point and just installed CentOS 6 and call it a day, the Debian 10 image is still showing out of memory and kernel panic :( Tried to Geekbench but to no avail as it requires newer glibc, so ya that's that for now :joy:
    ./yabs.sh -g
    #                     v2025-01-01                    #
    Mon Jan  6 19:03:09 EST 2025
    Uptime     : 0 days, 0 hours, 35 minutes
    Processor  : AMD Ryzen 9 5900X 12-Core Processor
    CPU cores  : 1 @ 3693.060 MHz
    RAM        : 112.4 MiB
    Swap       : 256.0 MiB
    Disk       : 2.5 GiB
    grep: /etc/os-release: No such file or directory
    Distro     :
    Kernel     : 2.6.32-431.29.2.el6.x86_64
    VM Type    :
    ISP        : Flexential Colorado Corp.
    ASN        : AS13649 Flexential Colorado Corp.
    Host       : Virtual Machine Solutions LLC
    Country    : United States
    Read       | 317.46 MB/s  (79.3k) | 418.64 MB/s   (6.5k)
    Write      | 317.26 MB/s  (79.3k) | 431.09 MB/s   (6.7k)
    Total      | 634.73 MB/s (158.6k) | 849.73 MB/s  (13.2k)
    Read       | 497.31 MB/s    (971) | 150.09 MB/s    (146)
    Write      | 539.85 MB/s   (1.0k) | 167.46 MB/s    (163)
    Total      | 1.03 GB/s     (2.0k) | 317.55 MB/s    (309)
    Clouvider       | London, UK (10G)          | 67.4 Mbits/sec  | 73.8 Mbits/sec  | 89.0 ms
    Eranium         | Amsterdam, NL (100G)      | 62.3 Mbits/sec  | 60.9 Mbits/sec  | 110 ms
    Uztelecom       | Tashkent, UZ (10G)        | busy            | 33.6 Mbits/sec  | 185 ms
    Leaseweb        | Singapore, SG (10G)       | 27.0 Mbits/sec  | 30.0 Mbits/sec  | 208 ms
    Clouvider       | Los Angeles, CA, US (10G) | 124 Mbits/sec   | 136 Mbits/sec   | 48.9 ms
    Leaseweb        | NYC, NY, US (10G)         | 334 Mbits/sec   | 324 Mbits/sec   | 20.6 ms
    Edgoo           | Sao Paulo, BR (1G)        | 52.7 Mbits/sec  | 53.7 Mbits/sec  | 125 ms
    YABS completed in 3 min 19 sec
    @VirMach can you bring back the $0.95/yr package that I forgot to pay 6 years ago? :joy: I would have never expected 128MB RAM to be that painful nowadays, most installer crashed even Debian 8/9 ISO
    Thanked by (1)admax
  • edited January 7
    Just like:
    Good luck!
    Blame me for not describing it well.
    Yes, you will get kernel panic after the installation is done, at that point you need to POWER OFF the VPS and reboot it and you will be able to log in via VNC using the root password.
    Thanked by (2)FAT32 admax
  • @Fritz said:
    @VirMach said:
    @core said:
    @VirMach said:
    @core said:
    @VirMach
    I submitted a suspension appeal in Ticket #619341
    I paid the relevant fees as required, but because I did not receive the email notification, my server was suspended again (only 5 hours later)
    I am not sure what happened to the server that caused the abnormal traffic. I cannot operate it immediately after the server is restored to normal, so please reinstall the system and restore it
    If you're in a rush to receive a response, I can provide a rushed response. You won't like the response though. Any time a suspension appeal is taking a long time it means I really know I have to deny the appeal but waiting to see if I can convince myself otherwise.
    A #619341 #791068
    "This ticket is regarding a matter that was previously communicated. Please refer to previous communication by us."
    I responded to the ticket, and you just closed it without responding to me
    In fact, my server was suspended for some reason, I paid the fine, I waited for 2 hours, and didn't see the server back to normal, so I went to work
    After 4 hours, I received a reminder that my server was suspended again
    In this case, I didn't know when my server was back to normal, and I didn't receive any reminder of recovery. I think I was treated unfairly.
    I don't know why you're mentioning paying anything. That did occur, but you're leaving out the part where I specifically refunded you the fee. Not that we're required to refund the fee. So $40 suspension fee was reduced to $5 as a courtesy. This is for the suspension and not the appeal. The appeal was rejected, and I also refunded the fee as I mentioned.
    You also received this communication, Which did not include anything about it being unsuspended and resuspended, the appeal was just rejected. So the response you received is correct, as it was previously communicated. Refer to previous communication:
    This cannot be unsuspended due to the severity. Heavy traffic even after suspension with packets being sent to it. I've refunded the appeal fee.
    Reminder, your suspension reason as well:
    Reason: Mass file sharing/torrent/high connection + high I/O
    Let me know how it's unfair. You basically simultaneously broke at least four portions of our AUP in a really bad way, to an extreme level. You contributed to the entire node crashing. When I say you contributed I mean I believe you caused the node to crash but there's obviously a possibility that one other abuser at the same time may have exasperated the situation, and you would have instead only heavily overloaded the server. Your service also almost immediately crashed the server again after it came back online. You most definitely can rest assured that even if we billed you our $40 standard suspension fee, you would be receiving a big discount compared to our bill rate as this took would have cost in the $80 to $120 range if we were to bill you for the actual time it took to address, not including responding to you here or your tickets.
    Your service is less than a 1/100th chunk of all the disk, yet your service by itself was 40% average or as high as 60% utilization rate, as in the proportion of total disk processing capacity being used by your service alone, with peak of around 5MB/s reads and 4MB/s writes at around 4kB to 8kB average request size. Other people use the server too, so this likely led to saturation, overloading, and a crash.
    This also is not the first time this has happened and you should have honestly been suspended sooner (that's my fault for missing it.) Your usage for this server looks like it shifted some time around August 2024 in some way, with larger incoming network spikes about once every 1 to 3 months, with the accompanied heavy I/O spikes. When you were suspended, over 500 individual IP addresses were connecting to your service.
    Although you'd still be breaking our terms of service, we can't provide a service to you, nor would we want to continue doing business with you in any other way, my recommendation for your use case, with another provider, would at the very least be an SSD service. That won't solve everything but it would get rid of the problem where your service is trying to do (according to SolusVM) 60MB/s to 200MB/s in reads to serve whatever content or whatever you're doing (and they're at 4kB to 8kB average request size.)
    My math and analysis above may not be perfect and I've been awake for a very long time, if any of the above bothers you, refer to the most important portion of the message again, the only part that matters:
    Welcome to judgement day bro @core
    Make ticket will make you naked here.
    @Fritz said:
    @VirMach said:
    @core said:
    @VirMach said:
    @core said:
    @VirMach
    A #619341 #791068
    Yes, virmarch was smart and suspended my server 6 months after PayPal payment. According to him, the abnormality appeared in August, but my server was suspended around December.
    Yes, according to him, he should have suspended me earlier, but he was very considerate and waited until the PayPal payment exceeded 6 months before suspending it
    In addition, I don't know why a 2-core 3G memory VPS can cause the entire node to crash. If virmarch's technology is so good that it can allow people to use a low-configuration VPS to cause the entire node to crash, it is really worth learning for other merchants
    So, I doubt the authenticity of what he said. Is it true?
    He still didn’t answer my most important question. My VPS returned to normal for a short time, and I didn’t receive any notification
    edited January 7
    @tulipyun said: Blame me for not describing it well.
    Nope the kernel panic happened after the reboot, it seems like 128MB just didn't cut it for some reason. Tried twice using different image (one with cloud-init and one without) but to no avail :/
    Thanked by (1)admax
  • @Ahui said:
    As a user of @ VirMach for 3 years, I purchased 15 VPS with annual billing. Recently, I received a notice stating that a VPS has been suspended and accused of abuse IO@VirMach Please tell me that lifting the suspension requires a payment of $40. This is the first time I have encountered a problem in three years, and that's how he solved it. This is so interesting, it made me see @ VirMach clearly. No wonder so many people are boycotting @ VirMach. I finally understand
    Hi guys,
    If your server has some abnormal servers that are running continuously, you need to deal with it as soon as possible after payment. If you are late by 3 hours, your server will be suspended again and the fee will be refunded.
    Also please note that there is no email reminder when the server is restored to normal. Please refresh the page 24 hours after payment until the server is restored.
    The above is my experience
  • edited January 7
    That's right, the kernel panic does happen after the first reboot, the key is that after the kernel panic happens, the normal reboot doesn't work, You need to go to “Full VPS Control Panel” and click “Power Off” instead of other buttons, then reboot again. At this point you should see the login screen.
    PS: Make sure you use a cloud image, virmach's default debian 10 image won't run on a VPS with only 128M RAM.
    I took this approach to install debian 10.13 on my mystery box.
    If you take the proper steps, you can do it too.
  • skorousskorous OGSenpai
    @core said: Yes, according to him, he should have suspended me earlier, but he was very considerate and waited until the PayPal payment exceeded 6 months before suspending it
    What are you saying here?
    @core said: He still didn’t answer my most important question. My VPS returned to normal for a short time, and I didn’t receive any notification
    That's not a question it's a statement.
    @core said: Also please note that there is no email reminder when the server is restored to normal. Please refresh the page 24 hours after payment until the server is restored.
    Surely your monitoring saw it return to service. A relatively minor thing which most will never notice as they will never get suspended.
    It is a cloud image, I might just try Debian 9 instead and I did poweroff before reboot...
    Thanked by (1)admax
    I'll describe them in order:
    1. enter rescue mode and install the cloud image with DD
    2. exit rescue mode and the system should automatically reboot and go into a kernel panic state
    3. Use the POWER OFF button in the Full VPS Control Panel
    4. BOOT
      5.login (you need to use VNC)
    debian 9 cloud image also works perfectly.
    Thanked by (2)admax FAT32
    I installed the Windows system through the backend. Where can I monitor whether my VPS has returned to normal? Please tell me the URL
    In fact, I visited the virmach website within 2 hours after payment. I don’t know how I can know that my VPS has returned to normal in the first time except this method. At least virmach official does not provide it (if there is no email reminder)
    edited January 7
    4. BOOT
    Yup thats exactly what I did, unfortunately I dont think I want to spend more time on this but thanks for the suggestions!
  • vyasvyas OGSenpai
    Just saying.
    Maybe because he ran out of flan
    Just saying.
    I dont understand
    Thanked by (2)admax skorous
    In other news ....
    tutorial?
    Let me catch up on some stuff and then yes.
  • @Ahui said:
    @Jab said:
    @Ahui said:
    @Jab said:
    70% swap used
    "30% unused memory"
    Haha, is there a problem? 1G switching is the most basic use, isn't it?
    No idea, just making fun of yours 30% unused memory.
    • Honey, I know you gave me 1000$ for the new PC, I only used 70% of budget!!!!!!
      -- Oh, ignore that extra loan for 2000$ I've spent.
    Are you here to be funny? I bought 768mb of memory and paid for it too. Why do you say I only paid 70% of the money?
    Just for the sake of clarity, using 70% swap space isn’t using the memory you paid for; it’s using disk space as memory (thus causing high IOPS) to overcome the fact that 768MB RAM isn’t sufficient.
    Tokyo migrations happening likely before February 4th. Emails will go out soon with some more information.
    Same contract/partners (xTom/Cat Networks.) What happened was we're currently in BBTower building, and traffic provided through them. BBTower changed connectivity from inbound IIJ to NTT, which negatively affected some customers, mostly in China (a few people mentioned it here.) Server will physically be moved to another building, NTT East Komagome. Even though the building's name is NTT, what will actually happen after this change is that we'll receive network more directly from xTom, which have their own blend, which will restore inbound IIJ. (Just making a note of that, since some people might see "NTT" and incorrectly assume this means it's changing to NTT.) From my understanding, they have NTT East Komagome connected to the other facility they operate out of which is Equinix TY8.
    IP addresses stay the same and your service stays on the same node. What will change later in another maintenance afterward (not this one) is that we're finally activating/connecting other servers we sent out here. That may involve some other changes, likely migrations to minimize IP changes, but potentially also some IP changes if necessary.
    cant wait for black friday 2025 tokyo
    Thanked by (1)admax
