Right now for example:
$ 14.67 PER YEAR
KVM
RYZEN SKU# V03-XD
RAM 2560MB DDR4 RAM
CPU 2 Core CPU vCORE
HDD 60GBSSD (NVMe)
BANDWIDTH 3072GB BANDWIDTH
IPs 1 IPv4 DEDICATED IPv4
Miami, Florida.
$ 14.67 PER YEAR
KVM
RYZEN SKU# V03-XD
RAM 2560MB DDR4 RAM
HDD 60GBSSD (NVMe)
Miami, Florida.
$ 14.67 PER YEAR
KVM
RYZEN SKU# V03-XD
RAM 2560MB DDR4 RAM
HDD 60GBSSD (NVMe)
Miami, Florida.
$7 would be good
If you have access to the 30% coupon it'd be $10.27, about as good as you'd get that specs from Virmach now.
The coupon is OG30 - but only qualifying for those that still have an active 2018 KVM special in their collection, one usage per qualifying client only
(Also OG20 if you have a 2019 and OG10 if you have a 2020)
Now that I'm (back) at 14 VPS!.. I was supposed to be reducing them to 10 or less!!
Still forlornly awaiting one more idler with 2IP in ATL, to use up the balance that I needed to add previously.
Someone trying to be politically geographically correct?
Ooh wasn’t aware of this. Thank you! Are these coupon single-use?
"Make a new reply on the thread quoting thee original question on whether you want it or not and explicitly state yes or no on the second roll"
My response:
Given the timing - Ryzen 5120 my response is yes,
Second roll/ Dealers' Choice- Answer is No.
Posting my response below since the Christmas/ Hanukkah thread is closed. In case of any mis-interpretation of my original response, my learning- to be clear and doubly clear in communication.
I'll just do a wheel for the rest of these instead of picking a number. Okay, focus, record the GIF and do not overwrite.
And then after that, it's dealer's choice for your second dice roll. Anything goes. I'm definitely going to opt out of doing it the complicated way I did dealer's choice in the past, that took way too long and only made sense in bulk.
Okay uhhhh... we'll reset the specs to normal. Kidding. I still want it to kind of be random, so we'll do this. I haven't looked at the node you've landed on yet, I'll give you a choice, do you want to keep it the way it is (Ryzen 5120), or proceed with the following?
If the node has above 1000GB disk left, you get an extra +100GB disk, if it's below, it's reduced to 60GB disk (as in 60GB disk.)
If the node has above 40GB free memory left over the way I usually manually check it (40,xxx -- not exact) you get 3GB extra RAM, if it's below, reduced to 3GB.
If the node has below 3TB bandwidth utilization by the time you reply/it's checked so far in the month (it's been 48~ hours since reset) you get an extra 3TB bandwidth, if it's less, you get reduced by 3TB bandwidth.
If the node has below 20% CPU utilization the way I usually manually check it, you get 2 extra cores. If it's in between 20% and 30% you get the same, and if it's above 30% you get 1 core less.
If the node has a bunch of extra IP addresses available (at my discretion, since we're not removing any) you get an extra IP as well.
My response:
Okay, processed. This doesn't count, what it would have been with second roll:
+100GB disk (1.46TB left)
+3GB RAM (46GB)
+3TB bandwidth (800GB used)
+2 Cores (6% CPU utilization)
(No extra IPs)
$ 14.67 PER YEAR
KVM
RYZEN SKU# V03-XD
RAM 2560MB DDR4 RAM
HDD 60GBSSD (NVMe)
Miami, Florida.
$7 would be good
where is the 30% coupon?
Edit: found the OP. It’s single use
Where is the OP?
Quite rare location, a bit regret for missing it
Yup, you're definitely missing something!
Money isn't a concern, but no hostname left.
https://lowendspirit.com/discussion/comment/198999#Comment_198999
1.hostname.com 2.hostname.com ...
More hostnames than IPv6 addresses.
He means his own internal VPS0 to VPS9 policy - (he is weird like that) he has great mental strength and self-control / self-restraint
mentally strong people install Debian the Arch Linux way
https://www.debian.org/releases/bookworm/amd64/apds03.en.html
because Debian installer expert mode sucks ass
Debian installer has low ram mode. For bookworm 512M should be fine, not sure about 384M but preseed works
Another sweet deal from VirBot
Self-control is how we earned the respect of the deal compiler awww.
There are more possible hostnames than IPv6 addresses....
Mentally strong people use uuidgen and never run out of hostnames.
How does it keep doing that? I thought I finally fixed the multiple IP address pricing bug. I guess I didn't look into it that long.
Why fix? it will ruin much fun.
Good morning.
I want to see virbot source code.
Maybe it's @VirMach updating everything manually.
@Virmach,
Ref: Ticket #752809 and the post: https://lowendspirit.com/discussion/comment/202932/#Comment_202932
My response:
Thanks
blog | exploring visually |
+3GB RAM (46GB)
(No extra IPs)
so who else won big? do share your specs
VirBot and me we have this thing going on.
Od course but need bigger everything
Still churning out deals in Secaucus.
