Here is a VPS running Windows 11 Enterprise, SQL Server database server and SSMS client on the same VPS
That is pushing the VPS to the limit since VPS has only 2.5 GB memory
Similar setup is not possible on Linux based OS running SQL Server and trying to retrieve 5 million rows
Processor : AMD Ryzen 9 5950X 16-Core Processor
CPU cores : 3 @ 3393.622 MHz
AES-NI : ✔ Enabled
RAM : 2.4 GiB
Swap : 512.0 MiB
Disk : 109.3 GiB
Distro : Debian GNU/Linux 11 (bullseye)
Test | Value
Single Core | 1943
Multi Core | 4928
Full Test | https://browser.geekbench.com/v6/cpu/9870782
Rough, is that Windows 11 eating 2GB on idle? how fat windows has become yeez
Here you go .... Windows Server 2022 Standard installation (with turning off unneeded services)
$8.69/year vps .... 2x vCore / 1.5 GB / 60 GB
Do you disable pagefile / swapfile to prevent excessive IO when you setup your VPS with < 3GB RAM ?
Because Windows tends to write a lot to disk, which must be even more the case with little RAM available.
AES-NI : ✔ Enabled
RAM : 2.4 GiB
Swap : 512.0 MiB
Disk : 109.3 GiB
Test | Value
Single Core | 1943
Multi Core | 4928
Let me share something -
one member on OGF reached out to me, he was getting not so good performance from his windows vps
3x vCores 3900x / 4 GB / 50 GB
Here is what I suggested him
1. Open System Properties:
• Press Windows + R to open the Run dialog box.
• Type sysdm.cpl and press Enter.
2. Access Performance Options:
• In the System Properties window, go to the Advanced tab.
• Under the Performance section, click Settings.
3. Adjust Virtual Memory Settings:
• In the Performance Options window, go to the Advanced tab.
• Under Virtual memory, click Change.
4. Disable Automatic Management:
• Uncheck the box for Automatically manage paging file size for all drives.
5. Select the Drive:
• Click on the drive where you want to set the paging file size (usually C:).
6. Set Custom Size:
• Select Custom size.
• Enter 8192 MB (8 GB) for both Initial size and Maximum size.
• Click Set.
7. Apply and Restart:
• Click OK to save the settings.
• You might need to restart your computer for the changes to take effect.
His feedback
system seems to be stabilized now...
constantly using 2-3GB RAM with LAMP & no editors
and cpu is just 2-3%
I always recommend using fixed size paging file in windows ... it can make dramatic improvement in performance
VPS 2000 ARM G11. Manassas, US.
$9/m
AMD EPYC™ Rootserver (Christmas), somewhere in Germany.
$8/m
So much power, but I don't have a use for it so maybe I'm getting rid of it. I don't want to do it, but I should. But I don't want to.
Trials and tribulations of a true LESbian...
HostHatch London CM 2024 AMD Compute
Free DigiRDP India Machine
Thanks to @FAT32 btw
YABS of an project IDX vm
- | Free Uptime Kuma | Best Web Hosting Deal
BF/CM/CHRISTMAS/NEW YEARS Mega idle machine YABS GB 5 + 6 (only idle machine is included) part 1
@heartbeat_IT Heartbeat-IT 6EUR/y 🇳🇱 (WITH SWAP)
Onidel @ ~6USD/y 🇻🇳 (WITH SWAP)
@Zappie ZappieHost 7.2USD/y 🇳🇿 (WITH SWAP)
BF/CM/CHRISTMAS/NEW YEARS Mega idle machine YABS GB 5 + 6 (only idle machine is included) part 2
@Hosteroid Hosteroid Klompen-Mini 14.55$/y 🇳🇱
@Hosteroid Hosteroid Comet 18.71$/y 🇷🇴
@Abdullah WebHorizon 30USD/y 🇲🇾🫱🏻🫲🏼🇸🇬
@Ayyub NatVPS 7.50USD/y 🇺🇸 (WITH SWAP)
BF/CM/CHRISTMAS/NEW YEARS Mega idle machine YABS GB 5 + 6 (only idle machine is included) part 3
@DigiRDP DigiRDP 12$/y 🇮🇳 (WITH SWAP)
@CharityHost_org CharityHosting 2000G 48USD/q 🇺🇸
@AlbaHost AlbaHost 5EUR/m 🇳🇱
@ShockHosting ShockHosting 29.99USD/y 🇸🇬
Raspberry Pi 5 with NVMe
@CLAWCLOUD
Hong Kong (non CN optimized)
ClawCloud 1c1g20g 500GB@200Mbps Tokyo
https://lowendtalk.com/discussion/201696/clawcloud-special-new-year-offers-cloud-vps-1c1g-7-year-asia-europe-us/p1
VirMach $29/y BF 2024
GCV $66/2y
3x vCores Ryzen 5950x
2.5 GB
110 GB NVMe
8 TB Monthly Bandwidth
Virm*** $18.63/year
Windows 11 Pro needs minimum of 2 GB .... just like Ubuntu Desktop, Linux Mint, and MX Linux
https://linuxconfig.org/linux-mint-system-requirements
https://help.ubuntu.com/community/Installation/SystemRequirements
and it is not idle ... but in idle mode it was using 1.7 GB memory
ps -- Windows Server 2022 Core (non-gui edition) needs 512 MB minimum
ClawCloud, Tokyo, $7/y
First YABS, forgot to change from GB6 which failed due to RAM:
Second YABS run, just GB5 (with some swap just in case):
Hello, Can VPS be transferred? Is this promotion valid for life?
Hosteroid
AMS
Similar setup is
running SQL Server and trying to retrieve 5 million rowsDo you disable pagefile / swapfile to prevent excessive IO when you setup your VPS with < 3GB RAM ?
His feedback
now I learned something. This should be 1x or 2x the amount of ram?
Don't know about Windows Server, but for Desktop, the recommended size of paging file is 1.5 times the amount of RAM.
THX Senpaisei
memory upto 2gb ... do not run windows unless one is expert
memory <= 4 GB ..... 2x size
memory >= 6 GB ..... 1.5x size (max 12 gb)
memory >= 16 GB .... fixed 12 gb size
my laptop with 16gb ram i set 2gb for paging file
my advin vps with 8gb ram also i just set 2gb for paging file
light workload tho
