NameCrane Black Friday - CraneMail Email Hosting + Cloud Storage Launch with Lifetime Deal
1234568»
    @treesmokah said: preserving senders privacy.
    This looks to be resolved ;)
    If you can confirm 100%, but our own tests/checks on both SMTP & webmail look to be clean.
    Francisco
    Francisco
    It works :)
    Thank you
    Thanked by (1)Francisco
  • @dgc1980 said:
    @Francisco said:
    @dgc1980 said: just what I am after
    Let me know how it goes :)
    Someone put in a request to changes for forwarders, i'll see what I can do.
    Francisco
    sending to the email address that has the domain internally and the server set the an external server works now, but I am having issues with postfix using the servers as a relay, still trying to debug that, not sure what the issue is currently. just seems to be timing out.
    ended up getting relaying working with addy.io
    I had to modify the docker image to use SSL rather than TLS as it seems that namecrane is not accepting TLS on either 465 or 587 and it just timing out.
    SSL works
    # openssl s_client -showcerts -connect us1.workspace.org:465 -servername us1.workspace.org
    CONNECTED(00000003)
    depth=2 C = US, O = Internet Security Research Group, CN = ISRG Root X1
    verify return:1
    depth=1 C = US, O = Let's Encrypt, CN = E6
    verify return:1
    depth=0 CN = us1.workspace.org
    verify return:1
    StartTLS does not :(
    # openssl s_client -starttls smtp -showcerts -connect us1.workspace.org:587 -servername us1.workspace.org
    CONNECTED(00000003)
  • edited January 23
    @Francisco @NameCrane
    @dgc1980 said: StartTLS does not
    StartTLS now works on port 587, I am happy, great work NameCrane
    myself and 3 friends I referred think this is the best investment we have done in 2024 :)
    Thanked by (1)bdl
    Sorry about starttls. It caused a few other issues initially but it’s correct now.
    We went ahead and added the follow alternative ports:
    • 2465 (ssl/tls)
    • 2587 (starttls)
    • 2525 (starttls)
    Glad you like the product! We are getting very close on rclone.
    Francisco
    Come one come all! The RCLONE beta is now out!
    https://github.com/namecrane/rclone/releases/tag/1.0
    You can also find my fumbled pull request to upstream in the 'closed issues' part of the official rclone repository. Woops.
    Let me know if we missed an arch and i'll push up the compiled binaries.
    We do intend to request this get pulled into the official codebase.
    Francisco
    Thanked by (4)FrankZ Decicus SuriHost bdl
    https://github.com/rclone/rclone/pull/8336
    We've gone ahead and pushed up the rclone backend, lets see if we can get it included in 1.7.0 :)
    A big thanks to our beta testers as well as our devops team.
    Francisco
    Thanked by (1)bdl
    This will likely require more effort because adding a remote probably requires docs and tests.
    rclone has been recompiled to support mount on both Windows & Mac :)
    https://github.com/namecrane/rclone/releases/tag/1.0.1
    We've also got an early BETA of z-push setup for those wanting EAS like push emails :)
    Francisco
    Thanked by (1)eb1995
  • @Francisco any update regarding WebDAV?
    Nothing from them yet. Rclone is there and we are making good progress on zpush.
    Francisco
    We’ve made great progress with activesync support for everyone :) we have rolled out all pf our changes so far:
    NOTE: events (calendar related mostly) might take up to ~30s to propagate to your phone.
    • autodiscover now supports both activesync and normal methods
    • you can now use “exchange” when configuring your phone (though it may pick that automagically if you have autodiscover setup)
    • IOS PUSH for email messages <3
    • Calendar events sync back and forth
    Known bugs:
    • The 'FROM" field isn't picking up the users 'display name'. this will require additional code that I'll finish in the next few hours.
    • Contacts are being a pain and will require further work
    This is not as feature complete as full activesync in Smartermail. It's not as fast (SM is probably near instant?), Contacts are being derpy, GAL search (when contacts are in there) is being a full on hater. It is free though, compared to the $4/inbox/year it'd normally be.
    This is meant to be a 'pretty good' improvement over the default 15 minute IMAP timers Apple Mail does.
    Enjoy!
    Francisco
    Thanked by (3)SuriHost rcy026 treesmokah
  • since it has not been posted here yet, I noticed on the control panel that FTPS support has been added to the file storage, and confirmed on OGF
