Looking for a UK VPS with a /28 or /29
This will be used to tunnel the IPs to my proxmox setup which mainly runs a few personal websites and development servers. Basically I need a few of the VMs to be public facing.
Currently I’m just using ngrok to tunnel stuff over the web but I want a bit more control.
Single ipv4 address + a /28 or /29
It will also need a IPV6 connectivity, a /48 would be ideal but I’ll take a /64.
Shouldn’t use much bandwidth at all, I’d prefer unmetered so I don’t have to worry about it but really anything over 10tb should be fine.
Need a gigabit port, 1 gb RAM, 10GB disk.
I don’t have a budget in mind but definitely keen to hear offers.
  • edited December 2024
    Hosthatch? Not sure about whether Gullo allows additional IPv4 addresses.
    Hello @jamesmd,
    Based on your requirements, such as a stable solution with a single IPv4 and a /28 or /29 subnet and IPv6, plus some basic resources like 1 Gbps, 1GB RAM, and 10GB disks, our small VPS plan with additional IPs will be sufficient for you.
    You can easily set up routing and tunneling to your Proxmox VMs. A dedicated server could also work, but it's likely more than you need for this specific purpose.
    We offer both VPS and dedicated servers and provide the option to add IPv4 blocks. However, with VPS, the availability of multiple IPs will depend on the server location, which is not the case with dedicated servers.
    We can help you find a solution that meets your needs and budget. Please provide more information about your preferred location so we can discuss the available options.
  • @clay_p said:
    Hello @jamesmd,
    heeey... probably get a provider tag first? asking nicely!
    welcome, but also check this out :D
    i can offer additional ipv4 as many as you need but we dont have /48 IPV6 ATM
    Thanked by (1)yucchun
    Bit of a late reply, but just noticed it because of the bumps today.
    Given how low your requirements are, you might want to look at just getting a cheap VM from anyone and using haproxy to forward HTTP/HTTPS/random TCP to the VMs, or if not web-facing just iptables to forward random TCP and UDP ports to the VMs.
    If you use a reverse proxy you only need the one IP for all web traffic but can select the VM to send it to based on the domain name in the SSL request.
    Thanked by (3)skorous wankel yucchun
    +1 for that suggestion if price and flexibility is of any concern.
    Your post has a hard requirement for a /28 or /29, without saying whether you need these 5 or 13 IP's need to be in the same subnet for one reason or another.
    My ISP used to provide a /29. After they stopped offering that, I went shopping for a small routed subnet and quickly found out that, at these low quantities, a budget VPS with IPv4 costs less per month than one eighth of a /29 (let alone one fifth). The CPU, RAM and storage come as a free extra. Your use case states low traffic, so the only concern (lack of bandwidth / port speed) may not be a problem.
    If open ports can be of your choosing for these dev/test apps, you could even get away with a Yetibundle or some other NAT offering.
  • Actually got sorted with this for £15 per month with layer.
    One of these IPs runs haproxy for a bunch of HTTP services I run, others need to run over TCP and require specific ports so NAT wouldn’t work and haproxy doesn’t work well for these TCP services.
    Thanks for the suggestions but I’m all sorted here.
    Thanked by (5)FrankZ hobofl ralf wankel rsk
    /thread
