microLXC Public Test
11617182022
    edited September 2024
    @ElonBezos said:
    @Neoon said:
    India, yea you exceeded 50% cpu usage on a shared system for a few hours.
    omg sorry for that.
    actually the cpu usage is quite strange as i don't use the india vm yet, for anything.
    i have temporary shut it down to prevent anything worse
    You can check the logs, from the first email you should be able to figure it out.
    Sometimes I have seen apt-get hanging, while doing some background tasks, hammering a full cpu core.
    However can't tell you what process that was, since not storing or processing that information.
    Thanked by (1)ElonBezos
  • @ElonBezos said:
    Your average CPU usage for your container lxcdcea9534 in the last 30 minutes was higher than 50%
    and it got rebooted by the system,
    how do i know which of my vm's this is? i'd like to check it further.
    for now I'm just using it as a personal vpn (web browsing)
    Usually I log in to each VM to see their container ID.
    Oradea Maitenence
    Due to some infrastructure changes, Oradea will be offline on Saturday the 21 of September.
    This will start at around 08:00 AM Bucharest Time and will take 4-6 hours.
  • 2831-4a7d-30e6-01af
    Mumbai is currently down, forgot to make it public visible on the status page, fixed.
    Thanked by (1)yucchun
  • 4727-141c-9a73-6b62
  • 6303-f03c-b698-ac91
    There is a bug with the bot, will look into it today.
    Thanked by (3)mee2 bliss yucchun
    92a1-5edd-c1f2-2162
    edited November 2024
    The regrex is broken as usual.
    For some reason my debug tool doesn't want to work, so have to figure out that first.
    Fixed.
    edited December 2024
    Since its CB and we still got a decent amount of memory free on some Nodes.
    JP, NL and FI have 50% off memory usage.
    So if you get a 128MB LXC container, only 64MB will be deducted, as long as you keep it.
    Runs either until the memory threshold is hit or CM ends.
  • dosaidosai OG
    Anything for nanokvm?
    No.
    There is about 3GB memory left per Node for the promo.
    Thanked by (1)Wonder_Woman
    Restocked Mumbai.
    I want to post earlier, thought I get some info, however I still don't have any on the outage on Finland as of right now.
    No update yet.
    edited January 7
    Update about the Finland node.
    2 Hours ago PulseMedia responded to my ticket and carried out a hard reset.
    The issue was the network card, why it decided to shit itself, I can't tell yet.
    The node is back online for now.
    SG Deployment update
    Today there was an error on deployments in SG, looks like VPN tunnel died, which is fixed.
    SG Network info
    We got a new IPv6 block for SG from WebHorizion.
    Wednesday, next week, I am going to swap out the IPv6 block in SG.
    Around 22:00 CET, it should not take longer than a few minutes.
    You have to reconfigure the network via the Panel, after the swap.
    If you don't your IPv6 connectivity will stop working until you do.
  • Meppel NL: "Failed to contact Node, please try again later." trying to terminate a KVM instance ^^
    edited January 30
    The VM is deleted, however there was an error hence it wasn't removed from the database, sorted.
    You get this error either if the Node is not reachable or the Node doesn't return any info about your VM.
    Thanked by (2)Shot² hobofl
  • Thank you!
    SG Network info
    Done, sorry about the delay.
    If you go to settings -> reconfigure network you get your new block allocated.
    The old one will stop working in a few days.
    Thanked by (1)tototo
  • Grateful!
    edited February 24
    Maintenance announcement
    Expect some downtime on the node in Meppel on Thursday, roughly 17:00 - 23:00 CET due to Maintenance.
    The Node won't be down for the entire window, but expect interruptions.
    Thanked by (2)Shot² Wonder_Woman
  • 5791-ac18-9a69-80a8
