Virmach did get my VM on Node: NYCB032 migrated to Node: NYCB028 and it is back online with new IP. So that is a big
For those of you who were on NYCB032 check the billing panel to see if you are also up. I did not receive any email notice.
My guess is they screwed the prefixes up and wanted to /24 everything, to sell to HostPapaCrossing, who will then throw them on IPXO, to be rented by another LowEndTalk host.
@cybertech said:
my VM in FL is down lol no notice
Functioning normally on MIAZ011 here. What node are you on ?
i dont know as the panel is inaccessible now.
Click the webmail link. When it times out the node name is in the URL. Erm, well, if its a shared host that is. I forget off the top of my head how, but there's another way for vps that's not obvious if you don't know what it is already.
Can also confirm my VM on AMSD016 died.
Around 00:42 today (GMT+1, Poland) it stopped reporting data to HetrixTools.
Few minutes ago tried to ssh - connection open, public key accepted... yet connection closes after that.
Rebooted from panel, "No bootable device".
I guess disk is gone. The same day I wanted to do something there, fucking Murphy.
I am too lazy to boot into rescue mode, it was idling, reinstall time, brb, will report if works after that or not
EDIT:
15 minutes after triggering reinstall via SolusVM server still offline.
Gonna click boot manually, but I don't expect anything.
Clicked booted - server offline, VNC not working.
I guess I've broken it even more.
Good luck @VirMach :DDDD
QD stinks in network quality and now + service
Bet they'll pull a QD/VM again in the near future
https://lowendtalk.com/discussion/comment/4283825/#Comment_4283825
contingency plan
https://bgp.tools/transfer-history/?org=QuadraNet Enterprises LLC
Does CC indirectly own QN now?
That is ...... interesting.
My NYCB032 is still down
Powerful AMD Ryzen VPS (aff)
The circle of life continues.
https://lowendbox.com/blog/hostpapa-acquires-nearly-all-quadranet-ips/
So basically the above comment (sh97) with some screenshots from bgp.he.net
Been like this for days for my LA and NYC server... Their LA nodes look kinda dead. Quadranet related?.
Miss your domain auctions!! Bring back the domains!!!
They're still there occasionally. But on the other green forum. U still there? Gonna run a Prem auction soon...
Won't catch me within 800ft of that place. Has to changed too much and not for the better IMO.
It has it's pros and cons. Been lurking here for a while now. Less noise for sure. Lots of oldtimers around. Maybe I should spend some more time here.
and ex-cons too
just barely took the courage to put dev site on it for a few days 😔
Same, down for the last 6 hours
Same issue with FL
VPS in AMSD016 node: "No bootable device"
time to set SJC up!
can confirm AMSD016 is fucked
i bet they're putting the data in a ssd named SAMSNUG or something
My MIZ018 is down here
Murphy's law is real
Ban Virmach
Good morning btw
Of all VM upstream, QD is the most unstable provider. xTom is the most stable. No surprise at all
No 1200GB for you.
EDIT:
