1343344346348349361
  • @ATInDaHause said:
    Same issue with FL
    Node: TPAZ004
  • Can I buy Virmach?
  • @ususk said:
    Of all VM upstream, QD is the most unstable provider. xTom is the most stable. No surprise at all :o
    QD has gone to shits recently. Checked in to see my virmach VMS are affected. They probably are. Didn't even get to set them up yet.
    Also, nice to see the status page is down.
  • Can't connect to the panel in NYC, MIA and LA now. Some other NT nodes still alive.
  • FrankZFrankZ ModeratorOG
    @Jab said: Can also confirm my VM on AMSD016 died.
    I can confirm that this time it was not me. I have no VMs on AMSD016. :sunglasses:
    Best of luck to those effected.
  • Has anyone experienced an unexpected reboot on the ATLZ034 (used to be called DALZ007)?
    I've encountered three unexpected reboots in the last 5 days, and I checked the logs and didn't record the reboot process, so I suspect the node was rebooted unexpectedly.
    On two occasions apparent CPU stealing time was recorded before the reboot.
    Node: TPAZ004
    Node: TPAZ004
    Node: MIAZ016
    Mentioned at Network Status, let's wait!
  • My virmach Florida vps is down
    Yes! I thought it was just me. My VPS has experienced some unexpected reboots for a few weeks now. As of Wednesday, it immediately shuts down when trying to boot Windows. Ubuntu full desktop also shuts down, but I can use some of the lighter weight distributions. 4 CPUs, 8GB RAM, so I should have plenty of headroom.
    Thanked by (1)tulipyun
    You're getting virmached :)
    It's a hit/ miss really.
    La still dead after a couple of days. Replaced and will cancel service.
  • Finally, my NYCB032 machine is back online.
  • Curious. Does anyone have a server with 100% uptime?
    FWIW, my VM on NYCB020 has been 100% up (bought & set up on Jan 9th).
    Excluding deliberate reboots, yes and more than just one.
    Thanked by (1)skorous
    for more than a year?
  • @cybertech said: for more than a year?
    Yup, NVMe2G in AMS is just one example. Up until recently, CHIZ001 was very stable.
  • We cannot load the controls for your service at this time.
    This could either mean:
    A) It took too long to load.
    B) The server controls have been automatically disabled due to an anomoly.
    C) The server could be offline, in which case we have already been notified.
  • so looks like virmach is just going silent unil next BF pretending like nothing hapens like last year
    anyone wanna bet on this? feels like i'll be winnin'
    Thanked by (1)someTom
  • edited February 4
    My vps in node MIAZ018 is online again.
    mine in MIAZ016 is up too. seems like network related issue.
  • @cybertech said: ..seems like network related issue.
    I had no problem with my MIA, during this time. Touch wood!
    edited February 4
    @Encoders
    VirMach said: I'm going to disappear for a while to really try to focus..
    Thanked by (2)FrankZ imok
  • @ususk said: ..the trickle down virmached effect
    There's also a cross-over effect: Kahnwebhost changed my IP in Texas yesterday, due a network issue.
    Too bad the ATLZ034 went offline again and then rebooted successfully a few minutes later.
    This is the fourth time in 7 days.
    Can @VirMach look into this.
  • Also thanks to Virmach, the Tokyo server has been properly inbound using the IIJ line, which has solved the poor internet connection for the past six months.
    Spoiler
    edited February 4
    Virmachhhhhhhhhh
    Spoiler
    -------------------- A Bench.sh Script By Teddysun -
    ------------------ Version : v2024-11-11
    Usage : wget -qO- bench.sh | bash
    CPU Model : AMD Ryzen 9 5900X 12-Core Processor
    CPU Cores : 2 @ 3693.060 MHz
    CPU Cache : 512 KB
    AES-NI : ✓ Enabled
    VM-x/AMD-V : ✓ Enabled
    Total Disk : 49.9 GB (4.6 GB Used)
    Total Mem : 1.9 GB (469.3 MB Used)
    System uptime : 10 days, 19 hour 55 min
    Load average : 0.00, 0.00, 0.00
    OS : Debian GNU/Linux 12
    Arch : x86_64 (64 Bit)
    Kernel : 6.12.9-amd64
    TCP CC : bbr
    Virtualization : KVM
    IPv4/IPv6 : ✓ Online / ✗ Offline
    Organization : AS3258 xTom Japan Co., Ltd.
    Region : Tokyo
    I/O Speed(1st run) : 1.8 GB/s
    I/O Speed(2nd run) : 1.9 GB/s
    I/O Speed(3rd run) : 2.1 GB/s
    I/O Speed(average) : 1979.7 MB/s
    Node Name Upload Speed Download Speed Latency
    Speedtest.net 914.81 Mbps 934.66 Mbps 1.13 ms
    Paris, FR 259.31 Mbps 840.71 Mbps 257.84 ms
    Amsterdam, NL 118.30 Mbps 474.35 Mbps 236.85 ms
    Beijing, CN 894.23 Mbps 961.02 Mbps 53.30 ms
    Shanghai, CN 664.82 Mbps 953.97 Mbps 65.83 ms
    Hong Kong, CN 863.09 Mbps 921.67 Mbps 55.76 ms
    Singapore, SG 313.39 Mbps 836.12 Mbps 84.91 ms
    Tokyo, JP 906.79 Mbps 943.70 Mbps 1.68 ms
    Finished in : 3 min 22 sec
    Timestamp : 2025-02-04 11:45:37 +08
    Thanked by (1)admax
  • ipv6 doesn't seem to work on my TYO-C034 Tokyo vps, it's worth mentioning that it was working fine before the migration.@VirMach
  • JabJab Senpai
    and you say this after multiple servers get fixed and multiple website status updates?
    That is kinda strange logic. Or you mean he will stop posting on the forum... like he said he will?
    Anyway @VirMach check this out if you still clicking links here :D
    https://lowendtalk.com/discussion/comment/4287165/#Comment_4287165
    Thanked by (2)sh97 skorous
    Try pinging the IPv6 gateway. If that does not work try setting VM up with only the single IPv6, not the /48 and see if you can ping the gateway.
    Thanked by (1)admax
