NetCup VPS piko G11s back in stock — 1 euro / month (annual)
These VMs been out of stock for quite a long while:
  • 1 vCore (KVM)
  • 1GB RAM
  • 30GB SSD
  • 1Gbit/s fair use. Throttled to 100 Mbit/s if the average traffic in the last 24 hours is above 100 Mbps (back to 1 Gbps once it's below)
  • Germany, Nuremberg 🇩🇪
12 €/year for EU residents (VAT), 10.08 €/year for others (VAT exempt). That's 1 and 0.84 euro per month.
Previously they've had 5 per customer limitation.
Order: https://netcup.de/bestellen/produkt.php?produkt=3422
Info: https://www.netcup.com/de/server/vps/vps-piko-g11s-12m
YABS (not mine):
#                     v2025-01-01                    #
Sa 4. Jan 18:52:36 CET 2025
Uptime     : 109 days, 17 hours, 37 minutes
CPU cores  : 1 @ 2294.576 MHz
VM-x/AMD-V : ❌ Disabled
RAM        : 960.7 MiB
Swap       : 0.0 KiB
Disk       : 29.4 GiB
Kernel     : 6.1.0-25-amd64
ISP        : netcup GmbH
ASN        : AS197540 netcup GmbH
Host       : NETCUP-GMBH
Country    : Germany
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda3):
Read       | 76.78 MB/s   (19.1k) | 939.22 MB/s  (14.6k)
Write      | 76.98 MB/s   (19.2k) | 944.16 MB/s  (14.7k)
Total      | 153.76 MB/s  (38.4k) | 1.88 GB/s    (29.4k)
Read       | 1.28 GB/s     (2.5k) | 1.60 GB/s     (1.5k)
Write      | 1.35 GB/s     (2.6k) | 1.71 GB/s     (1.6k)
Total      | 2.64 GB/s     (5.1k) | 3.31 GB/s     (3.2k)
Clouvider       | London, UK (10G)          | 1.08 Gbits/sec  | 821 Mbits/sec   | 21.2 ms
Eranium         | Amsterdam, NL (100G)      | 1.09 Gbits/sec  | 929 Mbits/sec   | 19.7 ms
Uztelecom       | Tashkent, UZ (10G)        | 990 Mbits/sec   | 794 Mbits/sec   | 96.4 ms
Leaseweb        | Singapore, SG (10G)       | 811 Mbits/sec   | busy            | 161 ms
Clouvider       | Los Angeles, CA, US (10G) | 920 Mbits/sec   | 221 Mbits/sec   | 156 ms
Leaseweb        | NYC, NY, US (10G)         | 1.02 Gbits/sec  | 816 Mbits/sec   | 94.2 ms
Edgoo           | Sao Paulo, BR (1G)        | 841 Mbits/sec   | 390 Mbits/sec   | 234 ms
Clouvider       | London, UK (10G)          | 1.07 Gbits/sec  | 749 Mbits/sec   | 21.1 ms
Eranium         | Amsterdam, NL (100G)      | 1.09 Gbits/sec  | 908 Mbits/sec   | 19.7 ms
Uztelecom       | Tashkent, UZ (10G)        | 1.02 Gbits/sec  | 573 Mbits/sec   | 96.3 ms
Leaseweb        | Singapore, SG (10G)       | 878 Mbits/sec   | 709 Mbits/sec   | 161 ms
Clouvider       | Los Angeles, CA, US (10G) | 951 Mbits/sec   | 373 Mbits/sec   | 156 ms
Leaseweb        | NYC, NY, US (10G)         | 1.01 Gbits/sec  | 702 Mbits/sec   | 94.2 ms
Edgoo           | Sao Paulo, BR (1G)        | 863 Mbits/sec   | 418 Mbits/sec   | 234 ms
Single Core     | 342
Multi Core      | 310
Full Test       | https://browser.geekbench.com/v6/cpu/9766899
Black Friday StorageAMD EPYC VDS (ref), up to 4TB NVMe / NVMe + big HDD VPS (ref) from $2.29/TB/mo / Storage dedis (ref)
Thanked by (4)FrankZ Not_Oles hobofl admax
  • * root@v2202502145645312537:~# curl -Ls yabs.sh | bash
    * #              Yet-Another-Bench-Script              #
    * #                     v2025-01-01                    #
    * # https://github.com/masonr/yet-another-bench-script #
    * Thu Feb  6 02:22:52 AM CET 2025
    * Basic System Information:
    * Uptime     : 0 days, 0 hours, 1 minutes
    * Processor  : QEMU Virtual CPU version 2.5+
    * CPU cores  : 1 @ 2294.608 MHz
    * AES-NI     : ✔ Enabled
    * VM-x/AMD-V : ❌ Disabled
    * RAM        : 932.6 MiB
    * Swap       : 0.0 KiB
    * Disk       : 29.4 GiB
    * Distro     : Ubuntu 24.04.1 LTS
    * Kernel     : 6.8.0-52-generic
    * VM Type    : KVM
    * IPv4/IPv6  : ✔ Online / ✔ Online
    * IPv6 Network Information:
    * ISP        : netcup GmbH
    * ASN        : AS197540 netcup GmbH
    * Host       : NETCUP-GMBH
    * Country    : Germany
    * fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda3):
    * Block Size | 4k            (IOPS) | 64k           (IOPS)
    * Read       | 69.76 MB/s   (17.4k) | 798.33 MB/s  (12.4k)
    * Write      | 69.95 MB/s   (17.4k) | 802.54 MB/s  (12.5k)
    * Total      | 139.71 MB/s  (34.9k) | 1.60 GB/s    (25.0k)
    * Block Size | 512k          (IOPS) | 1m            (IOPS)
    * Read       | 891.30 MB/s   (1.7k) | 929.71 MB/s    (907)
    * Write      | 938.66 MB/s   (1.8k) | 991.63 MB/s    (968)
    * Total      | 1.82 GB/s     (3.5k) | 1.92 GB/s     (1.8k)
    * iperf3 Network Speed Tests (IPv4):
    * Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
    * Clouvider       | London, UK (10G)          | 1.06 Gbits/sec  | 817 Mbits/sec   | 21.2 ms
    * Eranium         | Amsterdam, NL (100G)      | 1.09 Gbits/sec  | 938 Mbits/sec   | 28.9 ms
    * Uztelecom       | Tashkent, UZ (10G)        | 1.02 Gbits/sec  | 830 Mbits/sec   | 99.7 ms
    * Leaseweb        | Singapore, SG (10G)       | 919 Mbits/sec   | 740 Mbits/sec   | 161 ms
    * Clouvider       | Los Angeles, CA, US (10G) | 894 Mbits/sec   | 253 Mbits/sec   | 156 ms
    * Leaseweb        | NYC, NY, US (10G)         | 1.01 Gbits/sec  | 715 Mbits/sec   | 99.0 ms
    * Edgoo           | Sao Paulo, BR (1G)        | 881 Mbits/sec   | 598 Mbits/sec   | 203 ms
    * iperf3 Network Speed Tests (IPv6):
    * Clouvider       | London, UK (10G)          | 1.08 Gbits/sec  | 805 Mbits/sec   | 21.3 ms
    * Eranium         | Amsterdam, NL (100G)      | 1.08 Gbits/sec  | 925 Mbits/sec   | 28.8 ms
    * Uztelecom       | Tashkent, UZ (10G)        | 1.03 Gbits/sec  | 818 Mbits/sec   | 99.6 ms
    * Leaseweb        | Singapore, SG (10G)       | 948 Mbits/sec   | 661 Mbits/sec   | 161 ms
    * Clouvider       | Los Angeles, CA, US (10G) | 937 Mbits/sec   | 270 Mbits/sec   | 156 ms
    * Leaseweb        | NYC, NY, US (10G)         | 1.01 Gbits/sec  | 789 Mbits/sec   | 99.1 ms
    * Edgoo           | Sao Paulo, BR (1G)        | 887 Mbits/sec   | 773 Mbits/sec   | 203 ms
    * Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems).
    I'll try adding some swap and see if it helps for GB6
  • root@v2202502145645312537:~# curl -Ls yabs.sh | bash -s -- -i96
    #                     v2025-01-01                    #
    Thu Feb  6 05:56:00 AM CET 2025
    Uptime     : 0 days, 3 hours, 35 minutes
    RAM        : 932.6 MiB
    Swap       : 4.0 GiB
    Disk       : 29.4 GiB
    ISP        : netcup GmbH
    Host       : NETCUP-GMBH
    Country    : Germany
    Read       | 70.43 MB/s   (17.6k) | 745.95 MB/s  (11.6k)
    Write      | 70.62 MB/s   (17.6k) | 749.87 MB/s  (11.7k)
    Total      | 141.05 MB/s  (35.2k) | 1.49 GB/s    (23.3k)
    Read       | 830.10 MB/s   (1.6k) | 751.97 MB/s    (734)
    Write      | 874.20 MB/s   (1.7k) | 802.05 MB/s    (783)
    Total      | 1.70 GB/s     (3.3k) | 1.55 GB/s     (1.5k)
    Geekbench 4 Benchmark Test:
    Single Core     | 2250
    Multi Core      | 2176
    Full Test       | https://browser.geekbench.com/v4/cpu/18501907
    Geekbench 5 Benchmark Test:
    Single Core     | 462
    Multi Core      | 473
    Full Test       | https://browser.geekbench.com/v5/cpu/23320385
    Single Core     | 339
    Multi Core      | 297
    Full Test       | https://browser.geekbench.com/v6/cpu/10345679
    YABS completed in 37 min 45 sec
    With 4GB of swap, speed is pretty awful, but can't complain for a 10EUR/yr machine lol
  • Two times bigger plan for 2× the price:
    • 2 vCore, KVM
    • 2GB RAM
    • 60GB SSD
    • Snapshots (Copy-On-Write)
    • Germany, Nürnberg
    24 €/year for EU residents (VAT), 20.16 €/year VAT exempt (2 and 1.68 euro per month correspondingly).
    Max 5 per customer.
    Order: https://www.netcup.de/bestellen/produkt.php?produkt=3423
  • https://www.netcup.com/de/server/vps/vps-mikro-g11s-3m
    There’s also 4x size machine with 4x the price as well
    CPU is weak. im not sure 20 euros is worth it
    Thanked by (1)hobofl
    Tbh I think their upside is network and performance. For that price having sth like 30TB/mo with decent peering and actual ability to spike up to 1Gbps on a shared node, plus decent uptime and support I think it’s pretty great
  • https://lowendspirit.com/discussion/7482/aeza-net-ryzen-sweden-1-core-4gb-ram-for-1-eur-per-month-recurring
    Destroys it with performance:money, have been using it for a year now, 0 complaints.
    Only downside compared to netcup is 100Mbps port.
    Wish I too could have grabbed one :sweat_smile:
    Good deal. 1EUR a month from reputable provider w/ ipv4 and ssd is a win in my books
    Thanked by (1)cainyxues
    It's restocked regularly, you just need to keep an eye on it
    Thanked by (2)Not_Oles admax
    The aeza one? will be on look then, I did see zgato recommending them at OGF so kept an eye but was unsuccessful so far :sweat_smile:
    It's back in stock right now, and yes aeza.
    Thanked by (3)cainyxues Not_Oles admax
    Hmmm... Meh. Except for the 30GB SSD, it is still behind Ionos' (!) cheap VPS (1C/1G/10G/fair-use, peak 10Gbps, GB6 score 596/448, 1€/mth).
    Link?
    Recommended services*: Avoro, Bero-Host, Bunny, Enginyring, HetrixTools, HostBrr, Incognet, MXRoute, Mzungu, NameCrane, Sitebunker, SpeedyPage, Windscribe
    *Some links may be affiliate links. The list is sorted alphabetically.
  • ionos.at then search for vps linux servers, size xs
    edited February 10
    i'm happy with their 10 EUR deal so far. amazing network to tap on hostbrr DA storage with only 3ms, even better than AlphaVPS nuremberg and xTom frankfurt.
    What's your experience with Ionos? I've read some not so good things online. :/
  • No problem at all over the last 5 years.
    The only drawback is their billing monthly rather than yearly - so 12x e-mail with invoice, instead of 1
    what price do you see when you navigate to their Linux VPS URL ( ionos.com/servers/vps )? Just curious if it is geo-dependent...
  • edited July 19
    ionos.com is 2$/m but without contract. All others are 1$/€/pound but if you go monthly you have 10 setup fee
  • On the German website it's 1€ IONOS.de
