NetCup VPS piko G11s back in stock — 1 euro / month (annual)
DataRecovery
OG
These VMs been out of stock for quite a long while:
- 1 vCore (KVM)
- 1GB RAM
- 30GB SSD
- 1Gbit/s fair use. Throttled to 100 Mbit/s if the average traffic in the last 24 hours is above 100 Mbps (back to 1 Gbps once it's below)
- Germany, Nuremberg 🇩🇪
12 €/year for EU residents (VAT), 10.08 €/year for others (VAT exempt). That's 1 and 0.84 euro per month.
Previously they've had 5 per customer limitation.
Order: https://netcup.de/bestellen/produkt.php?produkt=3422
Info: https://www.netcup.com/de/server/vps/vps-piko-g11s-12m
YABS (not mine):
# Yet-Another-Bench-Script #
# v2025-01-01 #
Sa 4. Jan 18:52:36 CET 2025
Uptime : 109 days, 17 hours, 37 minutes
Processor : QEMU Virtual CPU version 2.5+
CPU cores : 1 @ 2294.576 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 960.7 MiB
Swap : 0.0 KiB
Disk : 29.4 GiB
Kernel : 6.1.0-25-amd64
VM Type : KVM
ISP : netcup GmbH
ASN : AS197540 netcup GmbH
Host : NETCUP-GMBH
Country : Germany
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda3):
Read | 76.78 MB/s (19.1k) | 939.22 MB/s (14.6k)
Write | 76.98 MB/s (19.2k) | 944.16 MB/s (14.7k)
Total | 153.76 MB/s (38.4k) | 1.88 GB/s (29.4k)
Read | 1.28 GB/s (2.5k) | 1.60 GB/s (1.5k)
Write | 1.35 GB/s (2.6k) | 1.71 GB/s (1.6k)
Total | 2.64 GB/s (5.1k) | 3.31 GB/s (3.2k)
Clouvider | London, UK (10G) | 1.08 Gbits/sec | 821 Mbits/sec | 21.2 ms
Eranium | Amsterdam, NL (100G) | 1.09 Gbits/sec | 929 Mbits/sec | 19.7 ms
Uztelecom | Tashkent, UZ (10G) | 990 Mbits/sec | 794 Mbits/sec | 96.4 ms
Leaseweb | Singapore, SG (10G) | 811 Mbits/sec | busy | 161 ms
Clouvider | Los Angeles, CA, US (10G) | 920 Mbits/sec | 221 Mbits/sec | 156 ms
Leaseweb | NYC, NY, US (10G) | 1.02 Gbits/sec | 816 Mbits/sec | 94.2 ms
Edgoo | Sao Paulo, BR (1G) | 841 Mbits/sec | 390 Mbits/sec | 234 ms
Clouvider | London, UK (10G) | 1.07 Gbits/sec | 749 Mbits/sec | 21.1 ms
Eranium | Amsterdam, NL (100G) | 1.09 Gbits/sec | 908 Mbits/sec | 19.7 ms
Uztelecom | Tashkent, UZ (10G) | 1.02 Gbits/sec | 573 Mbits/sec | 96.3 ms
Leaseweb | Singapore, SG (10G) | 878 Mbits/sec | 709 Mbits/sec | 161 ms
Clouvider | Los Angeles, CA, US (10G) | 951 Mbits/sec | 373 Mbits/sec | 156 ms
Leaseweb | NYC, NY, US (10G) | 1.01 Gbits/sec | 702 Mbits/sec | 94.2 ms
Edgoo | Sao Paulo, BR (1G) | 863 Mbits/sec | 418 Mbits/sec | 234 ms
Test | Value
Single Core | 342
Multi Core | 310
Full Test | https://browser.geekbench.com/v6/cpu/9766899
☰ Black Friday Storage — AMD EPYC VDS (ref), up to 4TB NVMe / NVMe + big HDD VPS (ref) from $2.29/TB/mo / Storage/GPU dedis (ref)
I'll try adding some swap and see if it helps for GB6
With 4GB of swap, speed is pretty awful, but can't complain for a 10EUR/yr machine lol
Two times bigger plan for 2× the price:
24 €/year for EU residents (VAT), 20.16 €/year VAT exempt (2 and 1.68 euro per month correspondingly).
Max 5 per customer.
Order: https://www.netcup.de/bestellen/produkt.php?produkt=3423
https://www.netcup.com/de/server/vps/vps-mikro-g11s-3m
There’s also 4x size machine with 4x the price as well
CPU is weak. im not sure 20 euros is worth it
Tbh I think their upside is network and performance. For that price having sth like 30TB/mo with decent peering and actual ability to spike up to 1Gbps on a shared node, plus decent uptime and support I think it’s pretty great
https://lowendspirit.com/discussion/7482/aeza-net-ryzen-sweden-1-core-4gb-ram-for-1-eur-per-month-recurring
Destroys it with performance:money, have been using it for a year now, 0 complaints.
Only downside compared to netcup is 100Mbps port.
Wish I too could have grabbed one
Good deal. 1EUR a month from reputable provider w/ ipv4 and ssd is a win in my books
It's restocked regularly, you just need to keep an eye on it
The aeza one? will be on look then, I did see zgato recommending them at OGF so kept an eye but was unsuccessful so far
It's back in stock right now, and yes aeza.
Hmmm... Meh. Except for the 30GB SSD, it is still behind Ionos' (!) cheap VPS (1C/1G/10G/fair-use, peak 10Gbps, GB6 score 596/448, 1€/mth).
Link?
Recommended services*: Avoro, Bero-Host, Bunny, Enginyring, HetrixTools, HostBrr, Incognet, MXRoute, Mzungu, NameCrane, Sitebunker, SpeedyPage, Windscribe
*Some links may be affiliate links. The list is sorted alphabetically.
ionos.at then search for vps linux servers, size xs
i'm happy with their 10 EUR deal so far. amazing network to tap on hostbrr DA storage with only 3ms, even better than AlphaVPS nuremberg and xTom frankfurt.
What's your experience with Ionos? I've read some not so good things online.
No problem at all over the last 5 years.
The only drawback is their billing monthly rather than yearly - so 12x e-mail with invoice, instead of 1
what price do you see when you navigate to their Linux VPS URL ( ionos.com/servers/vps )? Just curious if it is geo-dependent...
ionos.com is 2$/m but without contract. All others are 1$/€/pound but if you go monthly you have 10 setup fee
ServerStatus , slackvpn , linux mirrors
Recommended Providers: Servarica(aff) | HostBRR(aff) | SolidVPS(aff) | RackNerd(aff) | KuroIT(aff) | AlphaVPS(aff) | HostDare(aff)
On the German website it's 1€ IONOS.de
