SSH Key Management
edited February 21 in Help
Question! What do you all use for SSH Key management? I find keeping track of them all to be getting a bit much, lol.
And possibly related, do you generate individual key pairs for every client-server? Like for example, let's say I have two computers I use to access different servers sometimes. Let's say I have 5 servers. Should I do something like:
Server1 gets Key A from computer 1 and Key B from computer 2
Server2, Server3, Server4, and Server 5 all get the same Key A and the same Key B
i.e. one key per computer, given to all servers that computer accesses, making 2 total keys.
Or do you do something like this:
Server1 gets Key A-1 from computer 1 and Key B-1 from computer 2
Server2 gets Key A-2 from computer 1 and Key B-2 from computer 2
Server3 gets Key A-3 from computer 1 and Key B-3 from computer 2
Server4 gets Key A-4 from computer 1 and Key B-4 from computer 2
Server5 gets Key A-5 from computer 1 and Key B-5 from computer 2
i.e. each computer-server pair has its own key pair generated, making 10 total keys.
I ask because the first is what I've been doing, but it seems like the second would be more secure. But the second would also be a ton more work, especially as things scale higher, and I just do this for a fun hobby and minor utility, not a job, lol.
  • While I only have one computer, I also only have one key (used with 20+ servers), and I don't really see any security benefits of method 2. The only thing I would consider important (what you are already doing in method 1) is to use different keys for different computers.
    LTstats resource monitoring system | Recommended providers: Layer7, dataforest (Avoro/PHP-Friends), @host_c
  • this is all insane.
    put it in 1password and use the same user key everywhere.
    add SSH host key signing to your Ansible or whatever config and have every server get a signed key so clients don't complain, and inject your pub key on to each machine at provisioning time so you don't ever need a password.
    I don't see any benefit in the second method too. Most probably won't use a passphrase on the ssh key so incase one key gets stolen through malware all of them are compromised anyway. You would need to use a different passphrase on all of them and don't save the passphrase in a password manager.
    Personally I am using only a single key for both my computer and my notebook which I save in 1Password (afaik Bitwarden does offer a similar feature).
    Thanked by (1)SocksAreComfortable
    There is no security benefits. One key to rule them all is the way to go.
  • edited February 21
    I use KeePassXC with SSH Agent integration, it works great.
    @AuroraZero said: There is no security benefits. One key to rule them all is the way to go.
    There is a privacy benefit, you don't want to leave your pubkey everywhere. I prefer to have separated keys for different tasks.
  • So if I'm understanding, most of you are in the following hypothetical scenario:
    Server1 gets Key A from computer 1 which gets copied to computer 2 as well
    Server2, Server3, Server4, Server5 all also get Key A.
    i.e. one single keypair, so the same single pubkey on all servers and the originally generated private key on any computer I'm accessing them from?
    I think each client/ computer should be its own key pair.
    So 5 clients u use, 5 public keys copied on all servers.
    In that way you don't need to move around and risk exposing the private key.
    Agreed, each client machine has its own key pair and the private key never leaves that machine.
  • Each server has a unique host key.
    Some templates have a built-in host key, which is insecure.
    When we have to use a template, we delete the existing host keys and generate new ones.
    Each mobile client (any device that can be taken outside the house) has a unique private key.
    The corresponding public keys are authorized on a gateway device in the house.
    The device is currently a BeagleBone Black, 12-year old but still operational.
    The gateway device and all desktop computers share the same private key.
    The corresponding public keys are authorized on all the servers.
    If we obtain a new mobile device, we insert its public key in the gateway device.
    If we sell a mobile device, we delete its public key from the gateway device.
  • Each person gets 2 key pairs, generated using 2 fido2 physical keys.
    One physical key is stored somewhere safe, the other one can be taken out of the house.
    Same public keys on every server.
    Same private keys on every admin device.
    If a private key gets compromised, nothing happens.
    If a physical key gets lost, simply buy a new one and add it to the server.
    If both physical keys get lost, there is still the console or vnc
  • vyasvyas OGSenpai
    edited February 22
    Nice discussion so far and while Some of the approaches may be need/use case specific, good to learn
    Interesting approach. I presume that, in order for the gateway device to be used with the mobile devices, they always route back home through some type of VPN connection, otherwise they couldn't authenticate with servers, right? I tend to have all my mobile devices on a wireguard connection to my Unraid box at home whenever I'm on any wifi network besides my own, so I could see something like that being useful in my situation.
    I may be missing something, but how does this part work? I've never used physical keys of any type so I'm assuming there is something important with that part of it.
    Our residential connection has public IPv4 /32 and routed IPv6 /56 from AS701, although both are dynamic addresses.
    The gateway device is behind our OpenWrt router.
    Its IPs are published via he.net dynamic DNS.
    IPv4 port forwarding is configured in the router.
    There's no VPN involved.
    On the mobile devices, we make SSH connection to the gateway device, and then type a separate SSH command from there.
    Having two separate SSH connections means we can only type commands, but cannot transfer files and forward ports between mobiles and servers, but we rarely have such needs.
  • LittleCreekLittleCreek Hosting Provider
    I use Termius. It has built-in key management.
    LittleCreekHosting.com
  • Minimum of 3 keys on hardware tokens / smartcard of different make and/or model.
    A deployment key and user for ansible and all public keys in IaC.
    Managed centrally and deployed on git commit.
    The only tool I know that can do something like that, is a tool called KeyBox -> http://sshkeybox.com/
    @SocksAreComfortable Just send them all to the Yeti he will keep them safe for you!!! :tongue:
    See and if I trusted my comprehension of public keys enough to do it, I could actually send them to you and you couldn't do anything with it, right? lol....but I probably misunderstand that.
    Well to be honest if you sent me the keys there is alot I could do with them. I was not always the steadfast easy going Yeti everyone knows and adores. When I was younger I was a hooligan and pioneered some of the shit script skids use to this day.
    That is about what it looked like until I joined the Military. I decided I needed to protect people instead of causing more misery. Through a series of unformtunate events I was medically disxharged and lost myself for a bit. Took awhile but refound my purpose and here I am with the rest of us.
    Thanked by (1)skorous
    Sometimes it's when you get knocked down a bit by life that you really find yourself. Glad you are here with us now!
    Thanked by (2)AuroraZero skorous
    Threw me a for loop that is for sure. Glad I found this communtiy of good natured people all excepy @imok he is a terrible kitty man!!!! :tongue:
