3 or 4TB
2»
  • @ZizzyDizzyMC Hey! That would be great. Thanks.
  • @ZizzyDizzyMC said:
    BF is near. Anyone tag me if you see a good deal please.
    I know I'm a new provider, I there's a couple special deals going into the blackfriday mega thread that are limited offer.
    However with that said, I do have storage VMs, My plan sizes are 2, 5, 10 and 20. My blackfriday offer code will make them $2/TB/month, which unfortunately is still probably more than you're expecting. The arrays are pretty beefy and should have some good IOPs, and the network is routed out of Frantech / BuyVM in NYC.
    The plan only comes with 2 cores by default, I can add 2 cores to it since I know if you're running PBS it's not gonna be a core blaster 9000.
    If you end up wanting to try it dm me here on LES and I'll give your account credit so you can try it for a month free, on the recurring bf code.
    Where is the offer code? :-) ... I need one server for PBS too
  • noackhostingnoackhosting Hosting Provider
    I should install PBS and take backups in a storage VPS outside my network.
    Let me know if you see a good deal please. My servers are in the US, so that's the preferred location, but I think EU would be fine.
    How about a pbs-account, encrypt data and just do backups and pay for storage used? PM if interesting.
    Mikael Krantz
    email: [email protected] [email protected] [email protected] No Ack Infrastruktur AB aka No Ack Hosting
    Damn bro been a minute since I have a seen a pbs account.
    Easy to fix. And backups done with crypto np.
    Better then host a server somewhere to store backups and for once cheaper.
    Mikael Krantz
    Not knocking it man they always have worked great just been a minute since anyone even mentioned them is all.
    Are we taking about the job scheduler here?
    Proxmox backup system most don't use them anymore and just rsync the backups.
    Thanked by (1)skorous
    PBS suffers under high latency connections, is that the only reason for rsync? @imok , how is your PBS faring?
    Thanked by (1)imok
  • imokimok OG
    edited February 2025
    Backing up / restoring from Dallas to:
    • SSDs in Kansas / 76ms. Working great but a bit expensive for my use case. Heymman Servers.
    • HDDs in NJ / 40ms. Seems fine, cheap, currently the best one. @VirMach -
    • HDDs in Oradea / 143ms. Failed, too far away, cheap, I don’t wanna go Mr. @host_c
    • HDDs in BHS CA. Failed, HDDs were so slow. OVH
    • "NVMe" (performing like HDDs) in Montreal. Failed. Servarica.
    So that's why I'm still looking for something in Dallas.
    Unfortunately I still haven't tested Michigan with PBS (the service I got from this thread from Z Plus), but I will set it up this week.
    Thanked by (2)wankel host_c
  • Oh I still have to find a way to run PBS on Netcup's ARM platform. That's 45ms away.
    No idea but that could be the case.
