Main IP pings: false
Node Online: true
Service online: online
Both DHCP and static IP didn't work. Neighbor IPs are pingable.
What's the problem here?
What node? Even i m having trouble
LAX1Z021 marked as complete
Still, no dhcp nor manual works
Another VPS on 172.98.13.0/24 is also having weird issue
Main IP pings: true
Node Online: true
Service online: offline
I can connect but no matter how many times I click power on/boot , it's shown as offline on control panel
A lot of packet losses to some network as well.
For those of you who can VNC into your VM, but have network issues. I expect it would be best to not reinstall, or use the reconfigure network button. As VirMach said earlier if it worked before migration, don't change anything and it should work again as the networking is being set up the same.
I had similar issues earlier and they worked themselves out. It was a big move. and a switch bork'd, so report it here and I expect it will get taken care of.
@VirMach said:
Adjusting some configurations on the switch to address it.
Nothing to do with BGP or the servers or anything else in this case, I just fixed the remaining network issues too quickly and it cascaded into this.
VirMach said: Oh god are they actually founded in 2021 and they're just buying cheap facilities and ruining them and just buying more?
Maybe vulture capitalism has made another appearance. I saw this going on up close in the '80s. Make a holding company, buy other companies, sell off all the parts, put off paying vendors for as long as you can, put the secondary companies into bankruptcy, profit.
Node Online: true
Main IP pings: true
Node Online: true
Control issue on this one, fixing. As in everything's up, controls are down. You could have some secondary issue which you'll be able to see after I fix the controls.
LAX2Z021 being worked on, likely due to human error (me, I'm the human.)
I'm going to be reviewing more recent tickets first, so if you guys put an important one in and the ticket is unanswered, close it and re-open in this case. Then auditing my work again since LAX2Z021 seems to have slipped, it obviously means I marked something off incorrectly so my checklist isn't very useful then.
I registered this account just to ask about my Virmach service on LAX1Z017.VIRM.AC, since my ticket was closed with a generic response and I was not even able to reply to the ticket to re-open. Google brought me here and it seems there is a massive outage for all nodes in LAX (although I wasn't able to find any reference to tell me what happened to that particular node or when I should expect it to come up online after scrolling the last few pages).
The node is showing online but the VM is only accessible via VNC, no outside connectivity at all and I can't even ping the gateway IP.
Google brought me here and I just want to ask Virmach - I understand that this is a ultra-low-cost service and I can also understand you may not want to deal with 1000 tickets being sent at the same time asking you what happened, BUT in that case, what do you want us, as your customers, do? I know you are frustrated but it is also not our fault that the node is not working. Do you think just as some minimum professional courtesy, you should at least try to send out an email to the affected customers and let them know what's going on? If you are too busy to do that should you at least update your status page/make some announcement on your website? I've checked your status page, the node is showing green, solusVM it is showing green, I've explained to you in the tickets I've tried to troubleshoot many things myself before asking you.
And no, I don't have a million dollar business tied to that VM, and I've had VPS with other providers who have longer downtime but yet I did not complain at all, simply because they were able to communicate with me either by a mass email or status page update, or even a 1 line reply to say: "we know there is a problem, we are working on it, ETA x hours". If I pay for something, even if it is 1 cent, I expect that, at the very minimum, to work, and for a virtual server I don't think it is excessive for me to consider able to access the Internet as "work".
Apologies for the rant but this is not the first time this had happened and I just don't think this is the way a service business, even if it is a ultra-low cost business, should conduct itself.
@spammy you're in the right place now. Six comments above you may notice this type of network issue was referred to. VirMach moved all their equipment from one DC to another, some issues are to be expected. I do remember LAX1Z017 being refereed to in a previous VirMach comment, let me see if I can find it for you.
Brayvin said: @VirMach lax2z017.virm.ac is down/unreachable again. Posting here because network status asks that tickets not be opened (albeit lax2z017 is not listed there, so IDK what is expected).
Hi, I'm aware. I listed it as webhosting specifically instead of mentioning the specific name, it still requires some additional work. I'm about 12 hours behind schedule right now with everything. Two servers still have major problems that's the webhosting one and LAX1Z017 (coincidentally the other 17.) Also it's not a coincidence that these two are having a problem, they happen to be next to eachother and related in networking. The naming schemes got messy as we kept the old one for LAX2Z017 to keep the URL the same, that's why I mentioned it as webhosting.
@FrankZ said: @spammy you're in the right place now. Six comments above you may notice this type of network issue was referred to. VirMach moved all their equipment from one DC to another, some issues are to be expected. I do remember LAX1Z017 being refereed to in a previous VirMach comment, let me see if I can find it for you.
Thanks, I appreciate your response and indeed I missed out on that post you quoted, appreciate you flagging it to me.
However I think my point still stands. I honestly feel that a lot of the "unhappy" comments would not have been posted had Virmach could more actively communicate with the affected customers, and closing tickets with a generic response (and not allow the tickets to be re-opened) isn't what I would call the most helpful way to deal with the situation either, especially given creating tickets in their system is probably a bit more tedious and involves a few more steps vs other LE providers.
Happy to wait and appreciate the work over the weekend to fix the node issues, but just thought going forward situations like this could be dealt with more professionally. If I am paying 10 bucks a year and expecting 5 9s that's my problem, but I do expect at least to be notified if there is a wide-spread problem like this happening and may be a line of "please check this LES thread for further update" with the URL to this thread would be a lot more helpful as well.
@spammy said: I honestly feel that a lot of the "unhappy" comments would not have been posted had Virmach could more actively communicate with the affected customers, and closing tickets with a generic response (and not allow the tickets to be re-opened)
If it was closed like that it means there was high confidence it was already resolved. It'd be helpful if you show which generic response you received as they're not meant to be very generic and there's a good set of different ones used that would match what we would normally say. Then I can have a look and see if we can improve the message.
It's also closed on purpose, in some cases where it's not supposed to be closed it won't closed. You should create a ticket if it's still not resolved, then we'll know you created the ticket AFTER a mass fix was applied and therefore the ticket is treated differently since we know you are now having a problem still and therefore the fix did not help. If we did not close the ticket, the title/information may have something in it to where it does not match the current state and delays resolution. In your case, it's possible that you originally for example may have had to create it under "Network Status" but now you should be able to run the troubleshooter as well and select a more relevant department, as we have a backlog of "Network Status" tickets and therefore response on them is delayed.
The way we do things is never meant to have ill intentions so if you have any other feedback after my response, let me know and I'll consider making improvements to the process.
Last Updated 03/01/2025 23:34
We're received reports of a partial outage on TYOC027. Controls will also be unavailable.
TYOC026 is overloading.
Update -- TYOC026 has been brought back online and we are taking action to avoid it from re-occurring.
Update -- TYOC033 will also be tracked here. We'll have another look soon and apologize for the extended outage.
Update -- TYOC027 is still having a partial outage and controls issue but TYOC033 is going to be looked at first as it's a complete outage.
@VirMach said: Never seen that one before. Well okay then, just private message me some information so I can try to fix everything.
I found that when I don't click any of those red categories and just go to "General" it does not start troubleshooter and I can create general ticket. I know it will go to different queue, life is life :P
I can PM you whatever you want to debug the troubleshooter, but from what I can it's trying to load clientarea.php?action=productdetails&id=257736&tickettroubleshoot=true that ends with HTTP 500 with undefined function ping (WHMCS update? ) and that stops everything.
This has been fixed. I also improved the process to where in cases of the troubleshooter timing out, instead of telling you to go back and clicking network status, it tries to let you proceed with creating a ticket instead. If it breaks in a bad way it might still tell you to go back though as fallback.
Pinging tool has also been improved and:
@sh97 said:
anyway to know what node my VM was on (its now down)
The IP is 141.11.92.xxx
You can now see what node you're on during a timeout. This was going to be a more comprehensive version but I've implemented what we already have in terms of the code portion for this specifically. I ended up going a little overboard with it trying to add in some of the rest, big mistake as it took a while, but it's pretty nice now.
Looks something like this, and it also it loads everything before waiting for a timeout from SolusVM. The node says "Cached Data" until I can figure out a better way to communicate that via tooltip, basically it's the last known node you were on. After a migration it may not be accurate.
Guess things are not yet stable.
I'll ride it out for some more time.
The weird thing is. Until now it is was a pure idler. Had a use case, and bam...
@VirMach, one of my vm is in LAX1Z021 45.143.11.xxx, vnc works, but can't connect outside.
Aware this right?
Vnc works
Dhcp/ manual ip and gateway assignment doesn't work for me too
I panicked and re installed it. Still no luck.
My ip range is different though
45.92.195.xxxx
same here
P.S. Hi @SpeedBus good to see you.
VPS running without Internet but @VirMach > @localhost said:
@VirMach once said don't do anything, including installation and reconfiguration, but just waiting for him to replace the switches.
Virmach Deals
Called it
LAX1Z021 came alive, thanks @VirMach, hope you clear Ticket #401962.
Thanks again.
EDIT: Here you go.
LAX1Z017 is going to get decommissioned with a hammer right after I move customers off.
Let me do it. I really want to.
watch out y'all
suspension coming soon, then will post review
Hammer video or it didn't happen.
vps9hostname is available. affbrrThis has been fixed. I also improved the process to where in cases of the troubleshooter timing out, instead of telling you to go back and clicking network status, it tries to let you proceed with creating a ticket instead. If it breaks in a bad way it might still tell you to go back though as fallback.
cool. one suggestion. s/anomoly/anomaly/
Sadly had to get rid of this part for now as it was causing some other problems with controls:
But I fixed anomoly .. maybe. Okay I need to stop staring at this page, some things are bothering me.
why don't you start selling modules for WHMCS
you gonna B rich
i personally like the AI module
@VirMach I was wondering if you have any plans to migrate Chicago in the near future ?
@VirMach, doing anything with SJCZ010? It is currently down.
Look in the mirror and ask yourself.
As we all know, @FrankZ is @VirMach .
