1353354356358359432
  • @FrankZ said:
    @VirMach I was wondering if you have any plans to migrate Chicago in the near future ?
    Look in the mirror and ask yourself.
    As we all know, @FrankZ is @VirMach .
    See, @FrankZ doesn't realize that he's actually @VirMach.
    But no one has ever seen them at the same time.
    B)
    Thanked by (1)imok
  • @tulipyun said: @FrankZ doesn't realize that he's actually @VirMach.
    Now I am confused
    Now I am confused
    Perhaps you've heard of multiple personalities? :)
    Thanked by (2)tuc imok
  • Thanked by (1)sh97
  • Split (2016)
    Thanked by (3)cybertech tuc _MS_
    edited March 2025
    B)
    I was to meet up with @FAT32 & VirMach on a bus in Los Angeles back in 2017, but @FAT32 did not show up.
    So unfortunately @FAT32 is unable to confirm that VirMach and I were at the same place at the same time.
  • LinuxLinux OG
    edited March 2025
    B)
    Plot twist: there was only one person on the bus
    (has anyone seen Fight Club)
    edited March 2025
  • @FrankZ said:
    Wow I used to have a lot of hair back then.
    @sh97 said:
    wow virmach, are you arab/middle eastern?
    Persian/Iranian.
  • Plot twist: there was only one person on the bus
    why isn't anyone asking the real question?
    what number was the bus??
  • @VirMach said:
    Persian/Iranian.
    Do you have a Persian cat?
  • Wow, Vinnie Colaiuta (drummer for Sting and Alejandro Sanz) worked with Frank Zappa, and they have some songs with really uncommon time signatures.
  • ATLZ034 is going offline unexpectedly more and more often, it's grown to several times a day, @VirMach can you check it when you have time?
    Start Time End Time Down Info
    9 Mar 05:34 9 Mar 05:37 3min Errors
    9 Mar 05:16 9 Mar 05:18 2min Errors
    8 Mar 08:19 8 Mar 08:21 2min Errors
    7 Mar 22:39 7 Mar 22:40 1min Errors
    7 Mar 15:09 7 Mar 15:13 4min Errors
    Create a ticket to be moved away. I've been working on this and trying to get it more stable, it does appear temporarily more stable after every fix for a few days to a week and then this happens again as you've described.
    By the way I'm aware of our website(s) offline. It's the CDN. Going to give it some time.
    Thanked by (1)tulipyun
  • JabJab Senpai
    edited March 2025
    y0 @VirMach do I click Reboot or not? :-D
    // id=613983 @ AMSD036
    Welp, looks like someone (or something!) tiggered that reboot for me.
    Are we dead yet? :-D
  • JabJab Senpai
    edited March 2025
    xfs_repair kinda failed - a lot of important files in lost+found, grub files, apt configuration, basic perl modules rendering dpkg useless lost. Rabbit hole, not worth digging into. System lost, clean reinstall done :D
  • @Jab said: AMSD036
    Might just be your VPS only, I don't see a problem with the node.
  • JabJab Senpai
    edited March 2025
    Good and bad.
    I also realized I need a hot backup server as restoring these 178578187517857817857815 files takes years from that HDD :F
    100% CPU usage, IOWAIT 99.5% ^.-
  • Hello Sir,
    is ipv9 IPV6 available at the LAX node?
  • Good afternoon.
    Today is an extremely hot day.
    Also, all my Virmach servers are online.
  • @FrankZ said:
    @nahaoba said:
    @nahaoba said:
    TYOC027 has been down for 5 days since the 19 Feb.This issue was confirmed as a network issue.How long will it take to repair?
    @FrankZ Hello?
    Sure I'll venture a guess.
    Virmach has remote hands checking and/or trying to recover a broken drive. I don't think the node is down, only some VMs are down on TYOC027. We were just lucky enough to be on a drive that has issues. If the drive can't be recovered, it will be replaced and restored from backups. This could take a few more days or a week depending on DC hands workload and what needs to be done.
    When the Los Angeles migrations are finished, I expect that VirMach may have time to deal with this, but right now it is probably not the top priority as relatively few VMs are affected. I know this probably doesn't make you feel any better about this downtime, but that is my guess. If you are really in a bind, and have your own backups to restore, PM me with what size VM you have and I'll see if there is something I can lend you in the meantime.
    Of course maybe you'll get lucky and because I said it could take a week, it will be up in a hour just to show how wrong I am.
    It looks like I'm not lucky. TYOC027 has been down for 22 days since the 19 Feb.How long will it take to repair?
  • @nahaoba said: It looks like I'm not lucky. TYOC027 has been down for 22 days since the 19 Feb.How long will it take to repair?
    Sorry, I guess I should just go for it. I'm really dreading this situation because if I take action in this particular case, there is a small chance it could go terribly wrong. But you're right, it's been too long and I haven't been able to find a better solution. The main issue is that if it does go bad, it will require a lot more time to be spent on it. Let's see if we're lucky.
  • L.A Storage Node is down.
    Problems with AMSD018 ?
    Boot failed: could not read the boot disk
  • JabJab Senpai
    edited March 2025
    Mine seems to work, but this idler have amazing CPU usage for last 5 hours and I guess some dicks died [yours!] and node is struggling?
    This is pre-hetrixtools steal-update agent, but 99.5% of this CPU usage is steal.
    after HT agent update
    Thanked by (2)msatt kheng86
    Mine too :'(
  • JabJab Senpai
    edited March 2025
    update: I am dead now too, the whole node is most likely dead (or rebooting) because even solusvm does not load
    signed,
    AMSD018 enjoyer
    updatev2: I am back alive.
    Oh, also I can assume same/similar thing happening to AMSD014? :(
    my idler went crazy also
    If the failure takes a long time to process, why not migrate to another node first?
    Confirmed - Back working again.
    Thanks
