I was to meet up with @FAT32 & VirMach on a bus in Los Angeles back in 2017, but @FAT32 did not show up.
So unfortunately @FAT32 is unable to confirm that VirMach and I were at the same place at the same time.
Plot twist: there was only one person on the bus
(has anyone seen Fight Club)
@tulipyun said:
ATLZ034 is going offline unexpectedly more and more often, it's grown to several times a day, @VirMach can you check it when you have time?
Start Time
End Time
Down
Info
9 Mar 05:34
9 Mar 05:37
3min
Errors
9 Mar 05:16
9 Mar 05:18
2min
Errors
8 Mar 08:19
8 Mar 08:21
2min
Errors
7 Mar 22:39
7 Mar 22:40
1min
Errors
7 Mar 15:09
7 Mar 15:13
4min
Errors
Create a ticket to be moved away. I've been working on this and trying to get it more stable, it does appear temporarily more stable after every fix for a few days to a week and then this happens again as you've described.
By the way I'm aware of our website(s) offline. It's the CDN. Going to give it some time.
xfs_repair kinda failed - a lot of important files in lost+found, grub files, apt configuration, basic perl modules rendering dpkg useless lost. Rabbit hole, not worth digging into. System lost, clean reinstall done
Sure I'll venture a guess.
Virmach has remote hands checking and/or trying to recover a broken drive. I don't think the node is down, only some VMs are down on TYOC027. We were just lucky enough to be on a drive that has issues. If the drive can't be recovered, it will be replaced and restored from backups. This could take a few more days or a week depending on DC hands workload and what needs to be done.
When the Los Angeles migrations are finished, I expect that VirMach may have time to deal with this, but right now it is probably not the top priority as relatively few VMs are affected. I know this probably doesn't make you feel any better about this downtime, but that is my guess. If you are really in a bind, and have your own backups to restore, PM me with what size VM you have and I'll see if there is something I can lend you in the meantime.
Of course maybe you'll get lucky and because I said it could take a week, it will be up in a hour just to show how wrong I am.
It looks like I'm not lucky. TYOC027 has been down for 22 days since the 19 Feb.How long will it take to repair?
@nahaoba said: It looks like I'm not lucky. TYOC027 has been down for 22 days since the 19 Feb.How long will it take to repair?
Sorry, I guess I should just go for it. I'm really dreading this situation because if I take action in this particular case, there is a small chance it could go terribly wrong. But you're right, it's been too long and I haven't been able to find a better solution. The main issue is that if it does go bad, it will require a lot more time to be spent on it. Let's see if we're lucky.
Mine seems to work, but this idler have amazing CPU usage for last 5 hours and I guess some dicks died [yours!] and node is struggling?
This is pre-hetrixtools steal-update agent, but 99.5% of this CPU usage is steal.
If the failure takes a long time to process, why not migrate to another node first?
See, @FrankZ doesn't realize that he's actually @VirMach.
But no one has ever seen them at the same time.
Now I am confused
Virmach Deals
Perhaps you've heard of multiple personalities?
Split (2016)
wow virmach, are you arab/middle eastern?
Wow I used to have a lot of hair back then.
Persian/Iranian.
why isn't anyone asking the real question?
what number was the bus??
Do you have a Persian cat?
Wow, Vinnie Colaiuta (drummer for Sting and Alejandro Sanz) worked with Frank Zappa, and they have some songs with really uncommon time signatures.
y0 @VirMach do I click Reboot or not? :-D
// id=613983 @ AMSD036
Welp, looks like someone (or something!) tiggered that reboot for me.
Are we dead yet? :-D
xfs_repairkinda failed - a lot of important files in lost+found, grub files, apt configuration, basic perl modules rendering dpkg useless lost. Rabbit hole, not worth digging into. System lost, clean reinstall doneHaven't bought a single service in VirMach Great Ryzen 2022 - 2023 Flash Sale.
Might just be your VPS only, I don't see a problem with the node.
Good and bad.
I also realized I need a hot backup server as restoring these 178578187517857817857815 files takes years from that HDD :F
100% CPU usage, IOWAIT 99.5% ^.-
Hello Sir,
is ipv9 IPV6 available at the LAX node?
Good afternoon.
Today is an extremely hot day.
Also, all my Virmach servers are online.
L.A Storage Node is down.
Problems with AMSD018 ?
Boot failed: could not read the boot disk
after HT agent update
Mine too
update: I am dead now too, the whole node is most likely dead (or rebooting) because even solusvm does not load
signed,
AMSD018 enjoyer
updatev2: I am back alive.
Oh, also I can assume same/similar thing happening to
AMSD014?my idler went crazy also
Confirmed - Back working again.
Thanks
