1354355357359360416
    edited March 14
    @nahaoba said:
    @VirMach said:
    @nahaoba said: It looks like I'm not lucky. TYOC027 has been down for 22 days since the 19 Feb.How long will it take to repair?
    Sorry, I guess I should just go for it. I'm really dreading this situation because if I take action in this particular case, there is a small chance it could go terribly wrong. But you're right, it's been too long and I haven't been able to find a better solution. The main issue is that if it does go bad, it will require a lot more time to be spent on it. Let's see if we're lucky.
    If the failure takes a long time to process, why not migrate to another node first?
    Tokyo-exclusive issue. We can't move people to nearby location as we normally would (we'd get 95% complaints) and can't move everyone to another Tokyo node either because it'll likely cause problems on the other node after a mass migration. Also this would only be possible for the ones that are online.
    What I can offer is to move anyone who contacts us to get recreated on another node if they want to abandon their data.
    As for what I said I'd do the other day, I did. It didn't result in it going terribly wrong but it also didn't go terribly right. Closer to wrong than right. There's a lot more that could be said but it's not helpful.
    Thanked by (1)ahnlak
  • JabJab Senpai
    edited March 14
    Just waiting for a moment that Virmach AI would deem this idler using too much CPU and ban me (-:
    --- 1.1.1.1 ping statistics ---
    26 packets transmitted, 25 received, 3.84615% packet loss, time 26498ms
    rtt min/avg/max/mdev = 1.813/147.843/396.488/93.441 ms
    min 1.8 ms, avg 150 :-D
  • AMSD014 coincidentally started to sweat up :(
    https://imgur.com/a/HSiaKeb
    I can abandon my data,can you help me to move another Tokyo node?
  • OFFER #3212 is good ~ 2 IPv4's :), but I am waiting for the $8 8 IPv4s :lol:
    Thanked by (1)localhost
    This is by far my "idlest" server. Hope they won't look only at that chart like that...
    That one started being weird a day or two ago. None of this is a coincidence though, I just haven't had time to play detective while dealing with LAXA004S. Such a PITA, I had to basically piece together the host operating system because it decided to die mid-patch.
    Shutting down my VM on AMSD014 due to high [70%+] steal.
    I've got extras so no worries.
    @VirMach said: What I can offer is to move anyone who contacts us to get recreated on another node if they want to abandon their data.
    If this is your preferred solution I'll contact you, otherwise I'll just wait it out.
    @FrankZ said: Shutting down my VM on AMSD014 due to high [70%+] steal.
    Should be OK now. Monitoring further.
  • @VirMach Please check Invoice #1678842, my card was charged but invoice still Unpaid
  • JabJab Senpai
    We back to idling!
  • JabJab Senpai
    edited March 15
    Eh.
    -bash-5.1# top
    -bash: /usr/bin/top: Input/output error
    -bash-5.1# htop
    -bash: /usr/bin/htop: Input/output error
    I blame @msatt his disease on AMSD018 is spreading over the node to other VPS on that node :(
    and it's dead after reboot.
    No bootable device.
    @Jab said:
    Eh.
    -bash-5.1# top
    -bash-5.1# htop
    No bootable device.
    And AMSD018 has just gone offline again for me so no, I blame you.
    Getting no response when using VNC so can't even say the disk has gone.
    Not going to do a reboot, will just be patient.
  • JabJab Senpai
    edited March 15
    WE BACK @msatt
    Thanked by (1)msatt
    @Jab said:
    Eh.
    -bash-5.1# top
    -bash-5.1# htop
    No bootable device.
    Aware. They'll be moved off at this point or to another disk. There's also still abuse, I need to wrap up LAXA004S first.
    Thanked by (2)FrankZ msatt
  • TYO027 node how is it going, I saw your lastest update on 5 March @VirMach
  • @VirMach Have you looked at Invoice #1678842 yet? It is now Cancelled while my money is gone, what's your problem ?
    edited March 16
    This is on a renewal or a new service purchase ?
    Did you see this comment on March 14th ?
    New purchase, my card was charged but Invoice is not paid then Cancelled, zero notices from them :(
    edited March 16
    More than likely if the purchase was denied for whatever reason, and it does not show as account credit, the money will be returned to your card. Sometimes it takes the bank a bit to process the reversal. VirMach is not known for keeping peoples money without providing the service purchased. Virmach will probably drop by later to answer this definitively, in the mean time don't worry that you got scammed for your $$.
    P.S. Welcome to LES
    Ok... thought I got a good flash deal but it turned out to be terrible...
    Thank you
  • skorousskorous OGSenpai
    Thank you
    What was it?
  • @skorous said:
    What was it?
    RYZEN SKU# V01-00
    RAM 1024MB DDR4 RAM
    CPU 1 Core
    30GB SSD (NVMe)
    2048GB BANDWIDTH
    2 IPv4
    $7.25 USD annually
    P.S. Welcome to LES
    Hello Sir, how to get ipv6 on Virmach services?
    is Virmach allowed tunnelbroker?
    @tommy1412 said: New purchase, my card was charged but Invoice is not paid then Cancelled, zero notices from them
    Sounds like your payment wasn't accepted. How did you open your ticket by the way? Whichever way you did it means it gets delayed in the queue, I want to make sure we patch that so others don't do it.
    I've located your payment, make a ticket using the contact us button and select billing. Confirm you want us to attempt to capture the payment manually.
    Thanked by (1)burntascii
    edited March 16
    VirMach has some nodes in Amsterdam and Tokyo that have unsupported native IPv6. Otherwise VirMach does not offer native IPv6. From my experience tunnelbroker can be used in all VirMach locations expect for where VirMach uses QuadraNet. Chicago and Miami as example. Tunnelbroker has blocked QuadraNet not VirMach.
    EDIT: tunnelbroker may have had a change in policy and the statement above may no longer be accurate.
    is LAX also included in those blocked by tunnelbroker?
    edited March 16
    VirMach uses Equinix LA3 in El Segundo now for his Los Angeles location now. He recently moved out of QuadraNet Los Angeles. So tunnelbroker should work with VirMach Los Angeles.
    Thanked by (1)Ganonk
    There's no 'Billing' department on select list, I choosed 'Sale' dept. and [Ticket ID: 390345] was closed for improper use... this makes new customer like me don't know what to do, I found only way to get in touch with you via LES
  • @FrankZ said:
    VirMach uses Equinix LA3 in El Segundo now for his Los Angeles location now. He recently moved out of QuadraNet Los Angeles. So tunnelbroker should work with @VirMach Los Angeles.
    my node : LAX-A026
    ip : 104.234.61.0/23
    but Geo on Canada with isp QuadraNet
