1356358360361362
    edited March 16
    @Ganonk said:
    my node : LAX-A026
    ip : 104.234.61.0/23
    but Geo on Canada with isp QuadraNet
    I expect that the geolocation service that you are using has not updated the AS to AS46261 which is QuickPacket not Quadranet.
    I have a VM on node LAXA026 in IPv4 range 104.234.61.0/23 and just checked if tunnelbroker would allow a IPv6 tunnel to that VM.
    It allowed it now, when in the past when it was at Quadranet it did not allow it. So you should be good to go. :)
    EDIT: tunnelbroker may have had a change in policy and the statement above may no longer be accurate.
    Thanked by (1)Ganonk
    many thanks Sir. i would open ticket on ipv6@he.net 😀
  • @VirMach said:
    Aware. They'll be moved off at this point or to another disk. There's also still abuse, I need to wrap up LAXA004S first.
    Hello my Virmach, i have sent an email to tunnelbroker.net to get an ipv6 tunnel but unfortunately it was rejected on the grounds that the ip of my node LAX-A026 already has native ipv6.
    is there a solution for me to implement ipv6 on my service?
    Thanked by (1)burntascii
  • Any LESters have a VPS on CHIZ003 and if so are you experiencing issues? I am. When I run the Connection Troubleshooter in the client area:
    Main Server IP: Offline
    Node Server: Offline
    Service Status: Active
    Conclusion: Both your server and node appear to be offline. Please check the network status page for updates.
    edited March 16
    This seems to be something new from HE tunnelbroker. I expect they are allowing tunnels to still exist from IPv4 that have, or have had them in the past. Who know how long they will continue to allow this.
    If this is HE tunnelbrokers new policy, that networks that announce IPv6 can not use tunnelbroker, this is going to be a problem.
    I need to do some more digging on this and see if I can find an announcement from HE on what their policy is going to be going forward.
    My apologies for the misinformation of my earlier statements. I have added a note so that others are not misinformed by them.
    Thanked by (2)Ganonk burntascii
  • by the way, what is the reason why virmach can't activate its native ipv6 ?
    especially in the US region 😀
  • @VirMach, Ticket #401962 opened Feb.10th, please let me know one way or the other..
    Thanked by (2)FrankZ skorous
  • @VirMach screenshot dm'ed, can't contact Billing dept...
    Knowledgebase articles on ticket submit removed as it was just annoying, buggy, and it's already basically replied with AI. Long overdue. If we integrate it back it'll be at the AI phase most likely.
    Priority department removed (technically not fully, yet.) It'll be absorbed into the ticket creation process automatically.
  • Is node TYOC038 in problems or is just my vps offline in that node ?
    AI replaced $15 tickets.
    Thanked by (3)Brayvin Ganonk fan
    No hostname left!
  • Will Virmach be the next one? Of course not.
  • @imok said: Will Virmach be the next one? Of course not.
    already happened B)
    in problems. my service is offline too.
  • Is there something wrong with node 038 or is there something wrong with my service?
    @VirMach
  • edited March 21
    Your downtime has been doubled.
  • Your downtime has been scheduled
    Thanked by (4)Ganonk imok yoursunny sh97
  • Please check the network status page https://billing.virmach.com/serverstatus.php and you will find it mentioned there.
  • TYOC027 Offline for Extended Period
    Also, Heathrow was closed yesterday.
  • Please do not open a new thread for a down node at Virmach, Just mention it in the complain / moan Virmach thread as you already have.
    If we all followed your rule the board would end up being filled with down messages.
    Thanked by (2)burntascii FrankZ
    Well LES is now the virmache support forum more or less, since VirMach said on LET, nah.
    Guess close the thread before more will ryzen.
  • Wait, aren't there always some Virmach servers offline? What's so special about that one?
  • Virmach is doubled.
    Neat now we are back to this awesomeness!!!!
    Thanked by (2)skorous VirMach
    edited March 22
    LES trivia:
    In the December 2019 LES conducted a "Peoples host of the year" voting.
    @Virmach tied NetCup as the #1 unlisted provider on LES. [#4 overall]
  • What happened since then? U_U
  • apart from hidden fee, @VirMach offers many hidden things B)
  • I am here to complain that @FrankZ is not paid enough as VirMach Support Forum Tech!
