1356357359361362364
    @CMunroe said:
    I am here to complain that @FrankZ is not paid enough as VirMach Support Forum Tech!
    Oh but he is as with all politicians it is on the backside!!!
    Thanked by (2)imok hobofl
    edited March 22
    Thanked by (2)AuroraZero someTom
  • @FrankZ said:
    Does that mean you get VPS Escorts?
    edited March 22
    @CMunroe said: Does that mean you get VPS Escorts?
  • edited March 22
    Just get me Tunnel Broker to work in LAX. Use your political voodoo!
    @CMunroe said: Just get me Tunnel Broker to work in LAX. Use your political voodoo!
    Thanked by (2)CMunroe Ganonk
  • is available to change ip with same location/node ?
  • @VirMach, would you at least respond to Ticket #401962? It's been sitting there for a month and a half.
    I'll be happy if you clear that matter.
    edited March 23
    Here you go. For some of you in NYC on NYCB011, NYCB045, NYCB046, and NYCB047
    Dear VIrMach Customers,
    For services on NYCB011, NYCB045, NYCB046, and NYCB047, there will be a change in IP address tomorrow, March 24th, starting at apporoximately 8AM PST. Any specific updates on progress will be posted on the network status page. We apologize for the short notice.
    What does this mean?
    If your service requires an IP change, you will first see your new IP(s) appear in addition to your existing
    We will update the network status page once all new IP(s) have been assigned and when new IP(s) are activated
    Later in the day, we will remove the old IP(s) and reconfigure your networking
    Please note, after the IP change, make sure to utilize the new IP address for any important configuration within your operating system. If you run into issues, feel free to open a ticket afte maintenance is marked as complete as we will be actively monitoring tickets. Select the "Network Status" department. If there is no IP change and we mention in the network status page that they have been changed/completed, this means your service did not require one.
    Why the change?
    The existing IPv4 addresses are no longer being leased to us by a third party.
    Additional Maintenance:
    Services on NYCB011 will also be migrated. These will be processed first, and you will see your new IPv4 when it returns back online. More details will be provided on the status page a few hours after you receive this email.
    Although unlikely, we may need to move some services to a more suitable node, in which case you will likely be notified (via ticket.) The effective end results will be the same (with an IP change and data moved over.)
    We were unable to utilize a new system we've developed in time for this change, but should your service require a change in the future, it will hopefully be a more seamless process with better notifications and options when possible. If you have any additional questions or feedback, let us know by creating a ticket.
  • vyasvyas OGSenpai
    @FrankZ convinced Virmach to make all the changes before April
    Vacation time comes
    Vacation time comes
  • nice :3
  • Wondering if the NYC work may have borked some network configuration. NYCB018 isn't in the list of hosts on the network status page, but networking is down. VNC appears to be working. The gateway at 141.11.235.1 appears down.
    141.11.235.1 looks up to me. Just saying.
     4  ae-2.r22.nwrknj03.us.bb.gin.ntt.net (129.250.3.174)  3.512 ms  3.490 ms  3.462 ms
     5  ae-0.a01.nwrknj03.us.bb.gin.ntt.net (129.250.2.97)  3.530 ms  3.510 ms  3.516 ms
     6  e0-16.cr1.nyc2.us.unitasglobal.net (50.115.91.10)  4.064 ms  5.070 ms  5.275 ms
     7  e0-40.cr1.nyc1.us.unitasglobal.net (50.115.90.134)  4.829 ms * *
     8  inap.cust.nyc1.us.unitasglobal.net (198.232.115.146)  3.642 ms  3.780 ms  3.744 ms
     9  border1-po2-bbnet2.nyj004.us.unitasglobal.net (216.52.95.109)  4.442 ms border1-po1-bbnet1.nyj004.us.unitasglobal.net (216.52.95.46)  4.667 ms  4.639 ms
    10  74.201.136.182 (74.201.136.182)  4.517 ms  4.397 ms  4.364 ms
    11  hosted-by.royalehosting.net (45.59.169.177)  23.207 ms  23.124 ms  83.339 ms
    12  141.11.235.1 (141.11.235.1)  5.974 ms  5.930 ms  5.891 ms
    Yes, I neglected to mention that it seems down from the VPS point of view.
    edited March 25
    Don't be afraid to make a ticket. We usually say to please not make one but this time around I went out of my way to insist on tickets being made and it was with good reason -- this was a huge mess to complete.
    I've already located your issue by looking at some data reports, one moment.
    (edit) Yours was one of these:
    A few services ran into problems (approximately 12~) and need to be migrated again or moved to another server due to high IPv4 requirements
    I made space for you to stay as you didn't have a high quantity of IPs and I wanted to avoid a second migration where possible, but then forgot to take you off the list to move, so when it was moved, the IP wasn't changed because it didn't match the subnet being processed for all the moves. Sorry about that, this took much longer than expected due to issues with the control panel and other (expected) complications and this was at the very end so I'm not firing on all cylinders right now. It's on NYCB018, with the right IP now.
  • It appears that the New York migration has resulted in total data loss.
    Booting from Hard Disk...
    Boot failed: not a bootable disk
    No bootable device.
    GParted has detected a 15GB block device without any partition:
    SolusVM says the server should have 60GB storage, not 15GB.
    We are losing millions per hour.
    Ticket Created #122818
    Thanked by (1)Ganonk
    No hostname left!
  • @yoursunny said: We are losing millions per hour.
    You, as in I singular, may be but is anyone else? Plonker!
  • Chicago down and gone from the route map (at least my subnet) for 2 hours.
    Let's hope it's not quadranet gone... again.
    Thanked by (1)AlwaysSkint
    Confirmed CHIZ029 and CHIZ030 both nodes offline with no CP access.
  • vyasvyas OGSenpai
    edited March 28
    First person plural indicating Victorian era (time traveller?) or Royalty (more likely given King of Push ups)
  • @vyas said: First person plural..
    Yup, thus sticking with my assessment. :)
    edited March 28
    CHIZ001 & CHIZ035 also down. Looks like Chicago is a dead zone: confirmed by https://status.virm.ac/. :(
    Thanked by (1)msatt
  • JabJab Senpai
    edited March 28
    We are aware of the outage in Chicago and are evaluating most recent backups and available space in NYC to load from backups.
    P A N I C
    Thanked by (2)AlwaysSkint Kris
    Why do I expect something like this is running through VirMach's mind regarding Quadranet.
  • @Jab said: We are aware of the outage in Chicago and are evaluating most recent backups and available space in NYC to load from backups.
    Jesus christ.
  • Was the writing not on the wall, for leaving services in Chicago, as is? Head-in-the-sand? More attention paid there, rather than the MJJ fest in Tokyo, might have been prudent?
    Shame to be moved to NYC, where I already have a surplus of services; San Jose would be a marginal improvement, since the demise of Seattle. Need more options in NW and central USA, IMHO.
    QN said to move by end of April. I'm not going to pretend like I wasn't expecting this as a possibility, that's why we already had weekly backups off-site, but it would have been nice if we at least made it to the end of March.
    Most backups look like they're from March 21st. Backups aren't perfect, CHIZ001 is the most likely to potentially have some issues.
    I do not know why they're down, outside of the simple reason being "QuadraNet" so it could be they didn't pay transit, they didn't pay the network engineer, they decided to randomly move us to St Louis even though we didn't ask for it, or whatever else. NYC is low on available space after the migrations that happened this week. ATL has been low as well since Miami got moved into it, still working out a plan. If you need to be moved sooner, open a ticket.
    Miami, we did get a notification from QN that it's been given to Hivelocity. We are likely not continuing with Hivelocity since it is Hivelocity, but I'll let you guys know later today/tomorrow (for the remaining few customers who wanted to stay.)
    Everything was already assessed and this was the best way to do it. We can go over it later in a long post if anyone wants, just not now.
    @AlwaysSkint said: Need more options in NW and central USA, IMHO.
    I've been meaning to post about this, if I can just have 3 hours of breathing room this week :)
  • It wisnae me! A big boy done it and ran away.
