No Ack Hosting
We are hosting company in sweden. We do have redundant network and very much capacity. We dont care about abuse.
We would like to start with a couple of offers. We wanted our portal to support v6 only. Currently not supported unless manual accept deploy. Working on this.
We do provide bgp colocation and vm services. Our ASN is 30893 we been operational since 2003 under diffrent brand names. But now we use no ack hosting and I think we going to keep it.
First offer we would like to do is:
Specifications:
CPU: 1 Core
RAM: 256 MB
Disk Space: 5 GB SSD
IPv4: 1 Address
IPv6: 1 Address
Bandwidth Details:
5TB Transfer: Included with a 10Gbit port from node.
Post-Limit Speed: Once 5TB is exceeded, the port speed is reduced to 10Mbps until the start of the next month.
Traffic is unlimited within the provided bandwidth allocation and fair usage policy to ensure consistent network performance.
Network Interface: 10Gbit Limited to 100 unless other requested
150 SEK / year (~$15.50 USD year)
order here: https://order.noackhosting.se/?cmd=cart&action=add&id=156
Second offer but needs to after order create case to support and we remove 10% of cost (coz of ordersystem)
Specifications:
CPU: 1 Core
RAM: 1 GB (1024 MB)
Disk Space: 15 GB SSD (Additional storage options available for large data requirements)
IPv4: 1 Address
IPv6: 1 Address
Enjoy unlimited traffic with fair usage. The service is optimized for an average bandwidth of 100Mbps, ensuring balanced performance for all users.
Need more? Bandwidth upgrades are available upon request.
Network Interface: 10Gbit Limited to 1000 unless other requested
210 SEK per 3 month -10% LES special (~$20 USD)
https://order.noackhosting.se/?cmd=cart&action=add&id=55
We do have speedtest server in co-op with our hosting provider https://speedtest.cityhost.se
We have our own asn since 2003 and network and peeringdb info: https://www.peeringdb.com/net/5075
We also peering with bgp.tools so we have looking-glass available https://bgp.tools/lg/30893
We have 3x40G transit with a 10g backup link. Also we have 100G link to IX (https://ix.se) as a reseller we can offer free connection to that ix on our vms and colo/dedic services. We also have 100G to SONIX (sonix.network) and 10Gbit to Netnod stockholm (https://netnod.se)
If there is any questions of if we missed out on mentioning anything dont hesitate to ask. We can probably fix whatever needs there is.
Best Regards,
Mikael
Owner No Ack Hosting
Mod edit: added prices and conversion to USD. USD rate is approximate as the provider is charging in Swedish Kronor.
Also added bandwidth and transfer information for clarity.
Mikael Krantz
email: [email protected] [email protected] [email protected] No Ack Infrastruktur AB aka No Ack Hosting
Why there is no price?
@noackhosting - This ^
And asking people to register before they can see what they are buying is going to be a no go.
I apparently disabled a function my mistake. First package 150 SEK / year 2nd 210 SEK per 3 month -10% LES special
Mikael Krantz
No free options for bandwidth and port speed so your stated price is incorrect.
Edit: for the second plan
We need 1gb ram $7/yr deal on your next offer please. Ty ty
Why do I expect that is another oversight in the billing panel. Let's see if he again fixes it directly.
EDIT: Nope did not fix it so the offer has been removed for being over the LES price limits 525.00 KR/3 months ($15.66 USD a month).
I'll put the offer back if/when the provider fixes the cart misconfiguration.
Also
may mean
OP is not a native English speaker so let's give him a chance to clarify.
We need 2GB RAM $6/year or 4GB RAM $11.69/year dealz.
vps9
hostname is available. affbrrI suggest you provide 512m of memory, as memory resources are already quite cheap.
https://zhujisou.com chinese vps bloger,Truly in-depth testing
My pricing is correct and Ive had same pricing for years for the other packages. As I havent got the hostbill platform working with reducing prices. I will when accept order before payment reduce the price manually.
Portspeed on the small vps is 10Mbit by reason that it wouldnt be useful for anything anyways in my way of thinking. But if higher bw needed its just a support case away and I can change the vps manually.
Mikael Krantz
Sure I have it on 1GB in provisioning but dedicate 256mb ram. But its also limited by how many vms can host on a node. So I dont wanna give away to much memory on the cheap vpses.
Mikael Krantz
That wont happen Im affraid
Mikael Krantz
210SEK = 3 Months I dont see the problem. 210/3 = 70 SEK less then 7 dollar a month for the 1gb ram vps.
Mikael Krantz
I added LOWEND that works on site wide vps products. That will give 10% off on recurring invoicing. Can be applied once per customer and only new customers and a maximum of currently 500 times. So lets see.
Mikael Krantz
As promotional code that is gah.
Mikael Krantz
I removed the portspeed/bw options.. and put it as possible addons. Just not gonna be configured then. But yes should have had the default values as free. My mistake.
Mikael Krantz
I have removed the transfer-cap that was configured. Figure its better let everyone use whatever available on the 10Mbit nic that is enabled per default. Also upped the product to 1GB RAM with 256MB dedicated.
Mikael Krantz
For most applications, 256mb ram and a 5gb disk are too small. Barely enough to run a container.
Not if using alpine as os. Works pretty well i use it for nginx machines works just perfect even got 50% ram free.
Mikael Krantz
Now shows 210SEK in cart. Second offer restored.
Use Promocode LOWEND for 10% off on recurring invoicing.
Mikael Krantz
I like @yoursunny counter offer. That’s is all. Thank you.
Asking now anyway, related with ultravps.eu?
We need 6-core 12GB RAM 1200GB NVMe $100 triennial dealz.
vps9
hostname is available. affbrrKeep dreaming pal
Mikael Krantz
No noackhosting.se is my own company and nobody elses. Order page is order.noackhosting.se but website ordinary one do have more information around the services. Like our anycast-dns and LIR services and such.
Mikael Krantz
Does anyone want good offer on dedic servers. And Im not talking the most powerful machines. I do have spare DL 380/360 G8 machines where I can offer good options on add storage and 40Gbit ports. I only have 10Gbit or 40Gbit ports available. But ofcoz I do have 20 free 100Gbit ports but they will cost more bw.
Maybe add a bunch of 12tb drives(I do have in stock) and optional to add on as a good price spread over 12 month contract. I am very flexible.
Mikael Krantz
What if I would do 30% off on this deal https://order.noackhosting.se/?cmd=cart&action=add&id=177 I do have some servers in stock. All I have todo is replace disk/mem depending on needs.. Bw isnt a huge problem. I can put 10g/40G in all servers I dont care its only thing I got. All dep how much willing to pay
The more the more fun will be.
Mikael Krantz
👎 other finger for @ehab .
Price so high and no routed /64, so this is the appropriate finger.
vps9
hostname is available. affbrrLES should have more diversity, from what I can see, bandwidth offerings for their dedicated servers are pretty cheap
Check our KVM VPS plans in 🇵🇱 Warsaw, Poland and 🇸🇪 Stockholm, Sweden
I disagree. Bandwidth prices are fantastic considering the upstream, and "value added" features are totally worth the price (most abuse reports ignored). Compared to some G*rman host, prices may seem high, but its a completely different quality of the service.
And its not some summer host, it's run by someone with a long history and recognition on Swedish scene.
