Cheap dedicated server with directadmin license
Hi,
I am looking for dedicated server provider with directadmin license with unlimited accounts. I am looking to host shared hosting clients. Any suggestions will be welcomed. Thanks
  • EthernetServersEthernetServers Hosting Provider
    It would likely be beneficial to list your hardware requirements. For example, how much disk space and RAM are you currently using? Or is this a brand new deployment starting with no customers?
    🌐 Ethernet Servers Ltd – 10+ Years Online
    Shared, VPS, Dedicated Servers & Domains – www.ethernetservers.com
  • edited March 26
    I'm just getting my business off the ground, and right now, I'm working with a pretty tight budget. Server must be able to handle about hundred Wordpress sites. All sites contain no more than 4 to 5 pages.
    May be @MichaelCee could offer something if you are ready to prepay some months in advance
  • introserv_rdintroserv_rd Hosting Provider
    In essence, from what I understood, you will host business card sites. This will not require large resources. Any dedicated server with 4-6 cores, 16-32 GB of RAM and 250-500 GB SSD storage may suit you. Channel width - from 500 Mbit/s. That is, in essence, I listed the basic server parameters that almost all providers have. And as for the Directadmin Standard license - you can purchase it directly. I mean that if hosters sell a server with this panel, the cost of the license is often added to the cost of the server.
    If you need help installing the control panel - then among a number of providers, contact the one who offers management services or initial server setup (often this is done for free as a complimentary option).
  • @alim said:
    Hi,
    is that your purpose is using for big, using dedicated server is too much you can try VPS for small than and can find any provider have the good config for that server like high CPU with high benchmark, using SSD NVMe Enterprise with Raid 10, 10 Gbps port speed, that will be cheap than, if you try to find small dedicated server that will be not good for shared hosting, that's not enough strong.
    Server Aptech, LLC - Giving Cheap Plan And Best Service For You.
    Hosting | VPS | Dedicated Servers | Residential ISP Dedicated Servers
    Grab a VDS to start and go from there. Might even find a provider that does internal licensing still. Cheapest way to go that I know of until you get your feet under you.
    Thanked by (1)sh97
  • noackhostingnoackhosting Hosting Provider
    @alim said:
    Hi,
    did you find what you need if not hit me a PM
    Mikael Krantz
    email: [email protected] [email protected] [email protected] No Ack Infrastruktur AB aka No Ack Hosting
    Because you have very limited budget, I will recommend you to starts with reseller hosting, and if you really have 100s of websites from the beginning then it's better to go with vps or vds server then gradually increase th resources and upgrade to a dedicated server in future when you really reached that level..
    Thanked by (1)dartagnan
    I have 7 bucks a month for this project. Where is my server?
