Help with Jetbackup settings
Hello, I have cca 100 wordpress clients per server with AMD’s Ryzen 9 5950x and 128GB RAM.
What would be ideal settings for Jetbackup and this sites number? I've used Plesk internal backup system, but it's slow. Btw, it's uploading to Backblaze s3 compact storage.
Expertcees pls @MichaelCee @Chievo @bikegremlin @imok
Amadex • Hosting Forums
I am not a professional but I am going to up it
You are big data guuuuy with instruments
@Amadex - you got root access? And full privileges for JetBackup?
I'm asking because my experience with JetBackup is as a reseller hosting user - so quite limited options there.
My writeup on the topic (if it's of any help whatsoever):
https://io.bikegremlin.com/10008/jetbackup-automation/
Relja OneIsNone Novović
I have everything of that except life
JetBackup is a hit-and miss and no longer super-reliable.
DirectAdmin configured backups have worked quite well for me.
Not sure about Plesk's backup reliability.
For cPanel - this works OK for offsite backups to Hetzner:
https://io.bikegremlin.com/21143/cpanel-reseller-hosting-backup-automation/
I found the problem! It's because of CloudLinux and Jetbackup's rsync.
In Jetbackup Binary settings we need to adjust from:
/usr/local/jetapps/usr/bin/rsyncto
/usr/bin/rsyncAmadex • Hosting Forums
Nice you solved it. I haven't used JB in a looong time but it worked perfectly fine when I used to use cPanel in VPSes.
You're welcome
@MichaelCee
@bikegremlin do you have any relation to Mila Jovovich?
Not even once.
But the first and the last name are typical Serbian.
