Proxmox Virtual Environment 8.4 available
2»
    @host_c said:
    Dedicated always beats Software :)
    The same for RAID?
    Always, latency wise
  • somiksomik OG
    edited April 2025
    @havoc said:
    @MikeA said: have two right now running via USB-C power,
    TIL - didn't realise they come in usb-c. Or is that after market? Been wondering how much current those $1 aliexpress usb-c power deliver triggers can handle...these things
    Buy this type: https://www.aliexpress.com/item/1005006179191517.html
    Easy to set/configure and even has terminals you can screw cable into. Just make sure to check the voltage on the terminals BEFORE you connect it to your device and ensure the positive and negative are connected right way around.
    Thanked by (2)havoc host_c
