@VirMach said: But with all that said, it sounds like you just need an Epyc server.
i just want to high freq CPU and host some personal things, maybe also some blockchain rpc nodes.i can't feel the difference between non-ECC and ECC,so I think I will give up my obsession with ECC
@VirMach said: nd it's already past the amount of NVMe included for that $350 one-time upgrade.
Sub Total: $27.30 USD
Credit: $27.30 USD
Total: $0.00 USD
which ryzen it equivalent?
and check the original OGF thread ,heres multiple cpus:1240v1&v2 and 1270v1, what will they equivalent(maybe not by cpus,by specs instead) ,still Ryzen 5500? also what about the mem(because my original server is 32G but i want to upgrade to 64G) and etc....
@VirMach said: It'd be $200-400 one-time setup fee or something like $15 a month. The IP addresses won't be cheap on dedicated servers. The lowest I could see a /29 being would be $8 per month additional.
are you rent ip and announce on you own ASN?i know someone is trying to group purchase mass /24 ,100 usd per /24 per month,even can lower,just nore sure are they some random iran/ukraine ips or not...
and since the original E3-HDL is /29,i think i don't need more ips
@VirMach said:
I can prioritize this but if it hasn't already been prioritized it means it would have likely been rejected. Alternatively you can elect to wait without contacting us any further and we may be able to provide a suspension fee reduction waiver up to $40 and consider making an exception which would potentially allow for more leniency, resulting in a higher likelihood of unsuspension at a later undetermined date when we are better able to handle a potential repeat in abuse.
If you'd prefer I can take a look and verify this further, but the suspension fee would have to be paid in that case. If at any time you feel any of this is unfair or confusing, we can revert to the normal appeal process (which would mean the suspension fee is owed, with no guarantee of unsuspension.) If we find this was done in error, the fee would be refunded and you'd also receive SLA credits.
I can wait as long as the undetermined date is before my service due date and I can get unsuspension.
I just need responses to make sure that my ticket is not ignored. I understand you don't have many staffs but no responses for almost three months is not a reasonable time.
This is my first time to get suspension and I don't think this time counts as a real abuse because my service has been running stably for two years. All I was doing was just generating thumbnails and I did not get any warning emails before my service got suspended for IO abuse.
And I can assure you that there will be no abuse anymore. For now, all I want now is to get my data back. After the service is back running, all I will do is to rsync some important data and leave the service to its due date.
@taizi said: i just want to high freq CPU and host some personal things, maybe also some blockchain rpc nodes.i can't feel the difference between non-ECC and ECC,so I think I will give up my obsession with ECC
I've spoken with hosts that don't use ECC on their Ryzen nodes and they say it's fine. With a smaller amount of RAM than a host node, I think it should be okay.
Ryzen equivalent of that would likely be the $25 a month one, which already costs lower than what you ordered here. Correct me if I'm wrong but E3-HDL was something like 16GB RAM, 1TB HDD?
I can be flexible on the one you want, to have it be discounted a bit further. Let me know what you actually want minimum in a ticket and your proposed budget and I'll see if it's possible. While it might look nice to have a bigger disk you don't plan on using though, I'd recommend you actually let me know what you specifically require as it'll get you the best price, there's only so much I can push down the price on 2x $200 4TB NVMe SSDs. That $55/mo configuration is already heavily discounted, it's technically nearly $1000 in parts with an MSRP of around $99+ per month depending on how it gets done.
@taizi said: and check the original OGF thread ,heres multiple cpus:1240v1&v2 and 1270v1, what will they equivalent(maybe not by cpus,by specs instead) ,still Ryzen 5500? also what about the mem(because my original server is 32G but i want to upgrade to 64G) and etc....
Technically speaking on the CPU, the equivalent could be a Ryzen 2200 if we're going by power or 2400 if we're going by clock speed and core count, but all we have available right now is 5500.
What I can assure you though is that +48GB RAM, and 7TB in additional disk changed from HDD to NVMe is way past "equivalent."
@taizi said: are you rent ip and announce on you own ASN?i know someone is trying to group purchase mass /24 ,100 usd per /24 per month,even can lower,just nore sure are they some random iran/ukraine ips or not...
The IPv4 amount and IPMI are tradeoffs that I mentioned wouldn't generally be available. I'd be willing to hear anyone out who really needs a /29 and we could maybe make it work, but then I'd have to make everything equivalent, so in your case that means the price ($2.30 per month higher) and definitely no flexibility on disk or memory. It wouldn't work to your benefit.
If you do really need a /29 though mention it in the ticket, just know that no matter what the price I can give you will be at minimum about $3-4 per month higher than without it.
The part that makes the IPv4 cost higher for dedicated servers isn't the cost per IPv4 that we pay, it's having to set aside chunks and manage them efficiently. Non-standard amounts means more manual work and it's not going to be perfectly split and used 100% all the time. For dedicated servers we're also trying to use specific blocks that will be more reliable as it will be a headache to swap them out, more than virtual servers. If I knew you'd be using yours for X years, then I could give them to you at close to $100/MO per /24 but it would have to be on annual term and from a block that could potentially have a higher risk of being renumbered.
Just to kind of guide anyone else in a similar situation as yours, what all of this ends up meaning is that to go from the $27.30 a month special E3 to the $55 a month Ryzen (you're a previous dedicated server customer, want above equivalent) then this is how the math would work, estimated:
$55 --> $45~ so an additional $17.70 a month and if other specs further customized/reduced could be lower
12 x $27.30 (prepay annually at $327.60) plus $175~ setup fee one-time or $655.2 per 2 years and setup fee waived
Let's also say you can do the monthly a $27.30 +$350 one-time original "additional costs" except you get negative however many IPv4, and plus however much memory and a downgrade from 5600X to 5500, plus way more NVMe.
And of course:
Still no IPMI/KVM included
Plus extra $3-4/mo if you need /29
TLDR: you have to still pay more for the one that's very clearly basically 4x what you previously had, you still lose the IPv4 and IPMI, but it can be discounted a little further than how much we'd be selling them to new customers.
@nullgradient said: I just need responses to make sure that my ticket is not ignored. I understand you don't have many staffs but no responses for almost three months is not a reasonable time.
If it's not reasonable refer to the other option:
There was a lot of I/O abuse and it was causing problems on nodes. At the same time I don't like rejecting suspension appeals in cases like yours, and don't like charging the fee, but I have to do one or the other right now unless you want to wait with no reply for an undetermined amount of time. You can effectively consider the service suspended permanently unless otherwise noted. I know you likely haven't noticed it since your service was suspended but we've had a lot less problems recently with nodes. Relative to when we were giving people fee waivers, second chances, third chances, on limited support services (I'm not saying yours is limited support, just that in general it is.) And it's freed up a lot of much needed time in multiple ways because there's a reason there's a suspension fee (the time to investigate, deal with it, other tickets related to the abuse, the ticket for the appeal.) With fee waivers we noticed people generally don't take the suspension seriously and it just happens again and they also just expect another unsuspension and fee waiver.
@nullgradient said: This is my first time to get suspension and I don't think this time counts as a real abuse because all I was doing was just generating thumbnails and I did not get any email warning before my service got suspended for IO abuse.
It doesn't matter if it's your first time. There is obviously a reason it was considered more serious. You made it sound like generating thumbnails was reasonable so I took another look at it and you forgot to mention you're doing this on a storage node. I feel like that's a pretty important part of that.
Also it's not even your first suspension!! Why does no one believe me when I say we can see all your accounts.
Conversation over, refer to what I already clearly stated and proceed accordingly. Contacting us anywhere such as here again would make it more difficult to waive any suspension fee.
I don't want to try to get into an argument here, but this is indeed my first suspension and I have only one account.
Maybe using a VPN to access my account makes you think I have other accounts, but I use VPN to protect my privacy for almost every site I need to log in (I am using VPN to access LES too). If you don't believe me, and I can show you my real IP as long as I can get the service running. As I said, all I want is to get my data back.
@taizi update on KVM... I read into it a little bit more and the specific models for dongles, etc, and of course I could be completely wrong, but I found a potential compatibility quirk across models that would allow us to use cheaper dongles. We lose some features, so it could make KVM useless in some cases (like to mount ISO) but still works effectively the same for emergency access.
If I'm correct, this means we'll be offering free access for everyone*
*Unless some other issue comes up with number of simultaneous seats, or we need to provision a VPS, and so on. At the very least it'll be connected so we _could_ give people free access when needed. This is a very early update I only processed all this about 30 seconds ago.
And if the only concern you have is that I will cause abuses in the future again. You can directly terminate my service after i get my data back. I only need one day (maybe less) to rsync my data. If you suspect i have other accounts, terminate them too.
@VirMach said: I can be flexible on the one you want, to have it be discounted a bit further. Let me know what you actually want minimum in a ticket and your proposed budget and I'll see if it's possible. While it might look nice to have a bigger disk you don't plan on using though, I'd recommend you actually let me know what you specifically require as it'll get you the best price
"D ) $55/mo - Ryzen 5500, 64GB RAM, 2x4TB NVMe" with a /29 is good for me
currently my self hosting things only need 500G space, my blockchain nodes need 2TB space, so although I want some extra HDD,but 2x4T NVME already enough.
Hardware - As currently planned
Ryzen - same/similar leftover Ryzen servers.
Epyc - any existing Epyc that we never deployed, plus a few new.
Storage - some limited storage, and central backups.
Rented dedicated servers - see below
Does this mean there will be offers for dedicated storage servers in the future?
i have ovh LE-A for remote s3 storage,9.99Euro a month with 2x3TB HDD but only 250Mbps upload,want to see if I can replace this with OKC's server
and not sure should I just add some extra HDD to the ryzen dedi or wait for dedicated storage servers
These don’t really make sense if you’re trying to maximize storage and lower cost. Unless you go big and then the demand for it shrinks due to ballooning total costs.
The only way it would make sense is what you mentioned, adding HDDs to the Ryzen server.
So that’s four bays. Past maybe 12TB per drive it starts making sense going more bays (but not really for other reasons unless you really need it on one server.) We could technically do those too.
If you want a 24x 12TB-14TB server we could probably do it for $500 a month or maybe $3000 a year. Don’t quote me on that.
For adding 2x3TB, I think I gave estimate prices for adding that in another reply to you.
@taizi said: Does this mean there will be offers for dedicated storage servers in the future?
I think what you're quoting was referring to storage VPS plans. We'll have those. Which would probably be pretty good. I'll try to find what I didn't post about them in my collection of notepad files, that one's a bit older.
@VirMach said:
But then I'd have to assess the hidden stacking fee that all other configurations have, that's +$23/2YR for a stack of two, discounted $5/2YR to +$18/2YR per two stacks of two (for total stack of four.)
These are just estimates, blah blah. See my previous disclaimers. I couldn't find these so I had to rewrite them from memory which means for these particular plans there's a higher likelihood of the pricing being revised.
All Hardware RAID 10, Dual E5, DDR4. Early birds. 1Gbps (I might maybe take the cap off for trusted LES members.)
$36/2YR - 1TB HDD
$54/2YR - 2TB HDD
$96/2YR - 4TB HDD
These don't look right, that's like a dollar a month per TB? With RAID10? Okay whatever.
This does not make sense?
When has any of this made sense, we're still selling black friday flash specials for $6-7/YR with IPv4 and it's May. I don't even remember how to disable the system anymore.
$36/2YR - 1TB HDD
$54/2YR - 2TB HDD
$96/2YR - 4TB HDD
Oh nice, cheaper than the one you gave me for a few months and you were going to cancel after that and I haven't properly set up after 6 months... WTF it's been half a year already!?
When / where can we "Early birds" get to choose (don't mind being a guinea pig) ?
I know I have too many @VirMach VMs, but I may as well have some storage as well.
Storage VPS Deals Preview
$36/2YR - 1TB HDD
$54/2YR - 2TB HDD
$96/2YR - 4TB HDD
Thank you for using us for your idling needs.
@msatt said: When / where can we "Early birds" get to choose (don't mind being a guinea pig) ?
@VirMach said: $10/2YR - 4GB RAM, 1x Core, 20GB SSD, /64 IPv6 Only (No IPv4)
I want this. When will be available ?
After beta, for beta I'll likely arrange moving the rest today. Sale likely this weekend (but with disclaimers, if anything goes down, I technically might be in a different city for a few days and we haven't tested DC's hands yet.) No worries though for the foreseeable future I'll be around OKC most the time. This was just an expected trip, need to help a family friend.
OKC Update
Networking is properly up now, with IX almost set up, just need to wait for approval for Cloudflare/HE, and some last few things cleaned up. Waiting for more IPv4, working out a deal currently, so until then we'll be operating at scrounging levels, which means aimed toward larger plans and less IPv4 per server but there's a chance we could make this location similar to other locations at least for the VirMach brand Ryzen.
Will be visiting to finally screw in the SSD for the storage node and cable the second cabinet. @animeiscool how is the beta test going? I like how I can check your network usage by just visiting Lumen's portal since you're the only one on there.
I was thinking of trying the speed test script from @sh97, but I think that might use a lot of bandwidth, depending on how many servers/regions I select. I’ll probably try it later with just the NA region selected.
Also, I imagine the typical resource limits for promo plans are still in effect/and might probably set off high usage alerts. So I’ll try to keep that in mind.
@taizi can you tell me why you wanted BIOS access? Because all I can think of right now is that it'd be a bad idea. Any little thing if switched depending on what BIOS version, what CPU and memory combo could mean breaking things. Or maybe you never mentioned BIOS.
It's just you right now, you can do whatever you want. UPDATE
IX with HE and Cloudflare is now ready/set up, @animeiscool please let us know if it improves the network for you. Keep in mind the server's just set up to use 1x1Gbps not both 2x1Gbps.
Lumen also finally fixed the routing issue with the block we got from them which means other servers can have IPv4 now, or at least in the next 24 hours. And another block ready as well (other Miami, ran into some issues after I thought it was up.)
@VirMach said: @taizi can you tell me why you wanted BIOS access? Because all I can think of right now is that it'd be a bad idea. Any little thing if switched depending on what BIOS version, what CPU and memory combo could mean breaking things. Or maybe you never mentioned BIOS.
BIOS access enables to customer to setup admin password and disable the USB ports, so that you can never get into the machine again after the customer cancels their services.
@yoursunny said: BIOS access enables to customer to setup admin password and disable the USB ports, so that you can never get into the machine again after the customer cancels their services.
It's okay we have backup motherboards for that. Wait a minute, you mean to tell me it's possible to fix it without throwing away the motherboard? If only I knew sooner...
actually just IPMI(or the terminal access),last time I tried to setup a new vmbr to my promoxve server so that I can have dedi IP and nat IP at the same time,but first I misconfiged the network, then the network disconnected,so I have to login to IPMI and revert the change I made
edit:can the BIOS set the power plan?maybe set it to max performance is good too
also overclock the CPU to 10Ghz💀💀💀
@VirMach I just woke up. I couldn't really tell any improvement from an earlier yabs to one from today.
Here's the results from nws. Not sure why the output says nearest is a server that appears to be far way. Although, it looks good to me.
Speedtest.net (Region: NORTH AMERICA)
Location Latency Loss DL Speed UP Speed Server
ISP: VIRMACH
Nearest 104.36 ms 0.0% 939.09 Mbps 652.27 Mbps Datos101 - Madrid
Vancouver, BC 51.58 ms N/A 940.96 Mbps 923.87 Mbps TELUS - Vancouver, BC
Calgary, AB 48.51 ms N/A 944.72 Mbps 936.00 Mbps Shaw Communications - Calgary, AB
Winnipeg, MB 29.64 ms 0.0% 941.54 Mbps 942.47 Mbps Voyageur Internet - Winnipeg, MB
Toronto, ON 31.00 ms 0.0% 942.13 Mbps 941.46 Mbps Bell Canada - Toronto, ON
Montreal, QC 39.12 ms 0.0% 942.48 Mbps 940.31 Mbps Rogers Wireless - Montréal, QC
New York, NY 40.36 ms 0.0% 941.67 Mbps 939.63 Mbps Surfshark Ltd - New York, NY
Ashburn, VA 33.05 ms 0.0% 942.43 Mbps 911.66 Mbps Rackdog - Ashburn, VA
Durham, NC 36.80 ms N/A 736.97 Mbps 940.77 Mbps Spectrum - Durham, NC
Atlanta, GA 26.93 ms 0.0% 941.72 Mbps 934.10 Mbps Clouvider Ltd - Atlanta, GA
Miami, FL 37.04 ms 0.0% 942.29 Mbps 906.11 Mbps ReliableSite Hosting - Miami, FL
Dallas, TX 8.24 ms 0.0% 941.41 Mbps 939.08 Mbps Hivelocity - Dallas, TX
Houston, TX 14.10 ms N/A 941.80 Mbps 941.39 Mbps Comcast - Houston, TX
Kansas, MO 25.45 ms 0.0% 942.69 Mbps 941.36 Mbps Nocix - Kansas City, MO
Minneapolis, MN 21.40 ms 0.0% 941.73 Mbps 941.33 Mbps US Internet - Minneapolis, MN
Chicago, IL 18.87 ms 0.0% 949.93 Mbps 948.66 Mbps Hivelocity - Chicago, IL
Cleveland, OH 40.77 ms 0.0% 941.93 Mbps 940.24 Mbps Cleveland Broadband - Cleveland, OH
Albuquerque, NM 28.31 ms N/A 942.54 Mbps 941.25 Mbps Comcast - Albuquerque, NM
Denver, CO 17.74 ms 0.0% 945.01 Mbps 941.09 Mbps T-Mobile Fiber | Intrepid - Denver, CO
Portland, OR 53.39 ms N/A 961.62 Mbps 937.29 Mbps CenturyLink - Portland, OR
Las Vegas, NV 42.43 ms N/A 945.58 Mbps 941.44 Mbps Boost Mobile - Las Vegas, NV
Salt Lake, UT 29.35 ms N/A 937.07 Mbps 941.05 Mbps Novva Data Centers - Salt Lake City, UT
Phoenix, AZ 29.79 ms 0.0% 942.36 Mbps 930.20 Mbps Xiber LLC - Phoenix, AZ
Los Angeles, CA 40.83 ms 0.0% 944.34 Mbps 859.33 Mbps ReliableSite Hosting - Los Angeles, CA
San Jose, CA 44.76 ms 0.0% 932.80 Mbps 934.40 Mbps Misaka Network, Inc. - San Jose, CA
Spokane, WA 64.59 ms 0.0% 937.66 Mbps 916.02 Mbps Crunchbits - Spokane, WA
Seattle, WA 46.13 ms 0.0% 880.43 Mbps 939.54 Mbps Misaka Network, Inc. - Seattle, WA
Hermosillo, MX 45.28 ms 0.0% 944.66 Mbps 941.09 Mbps Megacable - Hermosillo
Guadalajara, MX 35.32 ms 0.0% 940.81 Mbps 916.73 Mbps AT&T México - Guadalajara
Mexico City, MX 57.58 ms N/A 945.16 Mbps 939.04 Mbps INFINITUM - Ciudad de México
Avg DL Speed : 933.85 Mbps
Avg UL Speed : 923.30 Mbps
Total DL Data : 35.38 GB
Total UL Data : 33.55 GB
Total Data : 68.93 GB
yes,I love that big NVME
this need more explain
for example,here's the dedi I ordered at that time:
And of course:
TL;DR; someone please tag me when some free stuff there ^.-
Would it be possible to pay extra for an IPv4? I might get it depending on the price of the add on.
So are Virmach dedis ready or what?
VIIIIIRRRRRMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH!!!
Not for that weird plan, it’s obviously weird for a reason.
Where is @FrankZ?
migraaaaaaaaaaaaaaaaation
to
Virtfuuuuuuuuuuuuuuuuuuuuuuusion
$36/2YR - 1TB HDD
$54/2YR - 2TB HDD
$96/2YR - 4TB HDD
Too early to ask that Q. It's only start of May. Unless this is like a monthly beacon till October...
blog | exploring visually |
OKC Update
@VirMach I’m still jet lagged from Miami.
where are the dealz?
2048GB SSD server when?
