200 GB Storage VPS
Looking for a VPS - mostly focused on storage space.
1-2 cores (of a modern CPU - Xeon Gold / Platinum, Epyc, Ryzen)
2 GB memory
180-200 GB disk (NVMe preferably, but SSD could work)
500 GB+ bandwidth
1 IPv4
North America or Europe
Around $5 per month, if that's not too low
Thanked by (1)GreenMustard
I couldn't find a provider at your price point per storage, but for $10/month, you can get a 2 TB SSD storage VPS in Texas.
https://oplink.net/high-storage-vps/
Free Online DevTools
Yeah, 2TB is overkill, but thanks for checking!
This would have been great, but it's out of stock - https://prohosting24.net/easter-deal
If so, you can keep an eye on Prepaid-Host. They keep restocking a similar plan (16 GB RAM 200 GB CEPH at 5 euros) from time to time.
Found it! I think they no longer offer that plan and likely won't restock. The page has been removed from their website - https://prepaid-host.com/en/aktion/2025-sale-m
Change your criteria to HDD to make it affordable for you.
2GB Dedicated RAM
1TB RAID60 HDD
3TB Bandwidth
2 Shared Xeon CPU cores
1Gbps Port
1 IPv4 IP
/64 of IPv6
BG
4€/month from alphavps
No thanks. A few databases on a hard drive sounds very slow these days!
Haumea Revision 2.0 - NVME VPS
Fully Configurable with Add-ons!
2 vCPU Xeon Scale Generation 2
2 GB DDR4 RAM
80 GB NVME Storage
1 Free Backup Slot
1 Dedicated IPV4 IP
1 Dedicated /64 IPV6
Port Speed 1 GBPS
High-Speed Included Traffic - 3TB ( All products drop to 10 Mbps after using the included traffic until the next month )
$8.00/mo
IO 200 Revision 2.0 - NVME VPS
3 vCPU Xeon Scale Generation 2
8 GB DDR4 RAM
200 GB NVME Storage
1 Free Backup Slot
1 Dedicated IPV4 IP
Port Speed 1 GBPS
High-Speed Included Traffic - 4TB ( All products drop to 10 Mbps after using the included traffic until the next month )
$14.00/mo
https://host-c.com/store/hosting-vps
Looking Glass: https://lg-ro-or.host-c.com/
If you're happy with it being in the UK then this is definitely something I can provide. Starting from 1TB right up to 25TB. We do this as a storage focused VPS but can also attach this extra HDD space on to our regular VPS plans.
https://vivehosting.com/uk-storage-vps/
Feel free to reach out - were being vey generous with our discounts lately 💪 with long term or even lifetime discounts available for LES members.
UK Shared Hosting | 10TB Storage KVM | UK KVM VPS | NAT KVM VPS
Wait, this is a OLD post....
I believe their entry-level package perfectly meets your requirements: https://cheapvpsbox.com/provider/dedirock.html
Please note the website link includes an affiliate link.
Cheap VPS Deals List :www.cheapvpsbox.com
