Any unofficial library of Hurricane Electric DNS ?
Hurricane Electric DNS is stable, but there seems to be no API for modifying DNS records. Is there any third-party library available?
  • somiksomik OG
    edited May 2025
    What is a "Hurricane Electric DNS"? How do you define stable? What kind of API are you looking for? Have you tried searching on google/chatgpt/local-pub?
    Finally, who are you?
    Just run your own primary and let HE sync from there.
  • @cmeerw Thanks for your suggestion, although adding an extra system may increase uncertainty, it seems to be the most feasible approach at this time.
  • skorousskorous OGSenpai
    Since OctoDNS, dnscontrol, and the like do it you might have to look harder.
    Thanked by (2)someTom Candace
  • tentortentor Hosting Provider
    @Candace said: Hurricane Electric DNS is stable
    I would like to argue, but to be honest it is mostly their network fault.
    Check our KVM VPS plans in 🇵🇱 Warsaw, Poland and 🇸🇪 Stockholm, Sweden
  • teamaccteamacc OGSenpai
    https://github.com/tsaaristo/certbot-dns-he
    Seems to allow HE DNS modifications for the purpose of letsencrypt dns verification. Probably relatively easy to adapt from there/base code on this.
    Thanked by (1)Candace
  • @skorous said: Since OctoDNS, dnscontrol, and the like do it you might have to look harder.
    Thank you.
    OctoDNS doesn't support Hurricane Electric DNS, but dnscontrol do support.
  • @teamacc said: Probably relatively easy to adapt from there/base code on this.
    Thanks.
    I dig into the code and saw that it simulates user login operations. It should be possible to expand or encapsulate it into a library.
