LES BSD Thread!
11314151719
  • linveolinveo Hosting ProviderOG
    @cmeerw said:
    Just heard from someone who switched to @linveo because of the availability of a NetBSD installation image.
    This is great news, thanks for sharing!
    Thanked by (3)toor Not_Oles AlwaysSkint
  • Just a quick note: in the @linveo VirtFusion control panel you can now set the boot mode to UEFI, and at last the NetBSD image also works with that boot mode.
    Thanked by (2)Not_Oles AlwaysSkint
    edited May 2025
    @cmeerw Thanks! <3
    Your customized NetBSD image as provided by Linveo's installer still is required, right?
    NetBSD-current still rebuilds successfully on my Linveo VPS. I'm having a lot of fun! Thanks @Linveo! <3
    Thanked by (1)cmeerw
    @cmeerw Thanks! <3
    My image already has the EFI system partition set up (as long as you have a similar set up, it should work).
    # gpt show ld0
         start      size  index  contents
             0         1         PMBR
             1         1         Pri GPT header
             2        32         Pri GPT table
            34        94         Unused
           128      8192      1  GPT part - EFI System
          8320   1048576      2  GPT part - NetBSD swap
       1056896  51371776      3  GPT part - NetBSD FFSv1/FFSv2
      52428672        95         Unused
      52428767        32         Sec GPT table
      52428799         1         Sec GPT header
  • Just wanted to quickly try the FreeBSD image on my @linveo VPS, but it failed to set up networking. Anyway, then tried my NetBSD images, and they also failed to set up networking... :o
    Ok, had a look at the config data, and it looks like with one of the VirtFusion updates the config format has changed - network-config used to say version: 2, but now says version: 1. Apparently, VirtFusion 5.2.0 has "Added Cloud-init network version 1 support" - and probably also changed the templates to use version 1.
    @linveo could you change the NetBSD templates to use version 2 again (as that's the only format I have implements; VirtFusion docs say "Added the ability to select the Cloud-init network version on a per template basis."). Not sure if that's also the issue I was seeing with the FreeBSD templates...
    Thanked by (2)Not_Oles toor
    I have updated the templates to use v2. It was nice of VF to introduce a breaking change and default everything to it.
    @linveo Thanks for updating the templates!
    I'm continuing to have fun with NetBSD-current on my Linveo VPS! I've been following both the source and the pkgsrc commits. Sometimes I look at the code for a few of the changes, trying to understand a little about what was changed, why, and how the change works. Then I rebuild the entire toolchain, userland, kernel, and whatever packages were updated since the last build.
    I keep all the terminal output for recent updates and builds just in case I need to look back at something.
    My Linveo VPS has been performing consistently great! For example, today's build of NetBSD-current's GENERIC kernel took 339.54 seconds. That's with two vCores on AMD Ryzen 9 9950X.
    Thanks again, so much! <3
    Thanked by (2)linveo toor
    While NetBSD-current was compiling itself really fast on Linveo, I tried FreeBSD's latest CURRENT snapshot image on a VPS at netcup. Everything seemed to "just work."
    https://download.freebsd.org/snapshots/VM-IMAGES/15.0-CURRENT/amd64/Latest/FreeBSD-15.0-CURRENT-amd64-BASIC-CLOUDINIT-ufs.qcow2.xz
  • Thought I would mention that https://tinykvm.com gives you a small VPS for just $15/year. You get:
    • 384 MB Dedicated RAM
    • 10 GB Dedicated Disk Space
    • 500 GB Transfer on our multihomed premium bandwidth blend
    • Gigabit (1000mbps) Network Port
    • 1 CPU Core - AMD EPYC System
    • Supports OpenBSD, FreeBSD
    I have my own test site (running via httpd & relayd on OpenBSD) -> https://tinykvm.btxx.org
    I upgraded mine for an extra $5/year to update the RAM to 512MB.
    PS. I am not affiliated with them - just testing it out!
    Thanked by (2)cmeerw Not_Oles
  • FreeBSD 14.3 has been released.
    Just now, while reading a 2014 HN discussion about CVS, I found out from an HN comment about FreshBSD.org. Apparently, from their About page, "FreshBSD launched in March 2006. . . ."
    Thanked by (3)toor cmeerw tmntwitw
  • #NetBSD 11.0 has been branched, and the stabilization process now begins. Pre-release snapshots will be available for users to try soon(tm).
    This will be the first release with RISC-V, C23, and POSIX 2024 support.
    Here is from my "daily driver" (dd) VPS. It's been going for some months now, I forget how long. dd runs NetBSD-current, which is rebuilt every few days, following successful NetBSD-current test builds on another VPS. dd's files are mostly encrypted and then backed up using rsync to two other VPS locations, one of which is at a different provider. Haha, both of the backup locations are running Linux. I guess it's past time to download another backup to a local had drive.
    I'm still using Chrome on my Chromebook for casual browsing and forum posting, but most everything else gets done on dd with command line, ed and vi.
    What are you guys using? Is there anyone else who uses a daily driver VPS?
    Last login: Fri Aug  1 03:27:59 2025 from xxx.xxx.xxx.xxx
    NetBSD 11.99.1 (GENERIC) #1: Fri Aug  1 03:24:56 UTC 2025
    dd$ uptime
     3:35AM  up 1 min, 1 user, load averages: 0.02, 0.01, 0.00
    daily-driver$ ls -l /bin | head
    total 3888
    -r-xr-xr-x  2 root  wheel   22056 Aug  1 03:19 [
    -r-xr-xr-x  1 root  wheel   22024 Aug  1 03:19 cat
    lrwxr-xr-x  1 root  wheel      11 Jul 25 03:57 chgrp -> /sbin/chown
    -r-xr-xr-x  1 root  wheel   22240 Aug  1 03:19 chio
    -r-xr-xr-x  1 root  wheel   17584 Aug  1 03:19 chmod
    -r-xr-xr-x  1 root  wheel   33528 Aug  1 03:19 cp
    -r-xr-xr-x  1 root  wheel   57720 Aug  1 03:19 cpio
    -r-xr-xr-x  1 root  wheel  190896 Aug  1 03:19 csh
    -r-xr-xr-x  1 root  wheel   27272 Aug  1 03:19 date
    dd$
  • My FreeBSD at @linveo has been absolutely rock solid for months and months so I cannot recommend them enough for great *BSD experience!
    :star: :star: :star: Yaaay!!! @Crab is back! :star: :star: :star:
    Thanked by (1)AlwaysSkint
    edited October 2025
    For sure I can say the same about my Linveo NetBSD VPS! 1001% excellent! <3 It has compiled all of NetBSD-current over and over and over again, every few days!
    Thanks also to @cmeerw for making the NetBSD image for LInveo. <3
    Thanked by (1)linveo
  • My friend @Not_Oles it is nice to see you continue to be very active and providing great products! I have had some health issues and other setbacks this year, but hopefully I can continue to contribute to the community with BSD related things.
    Thanked by (2)toor Not_Oles
    We wouldn't be able to provide much in the way of BSD if it weren't for the testers and @cmeerw for making custom templates. I appreciate everyone's feedback and development here!
    Thanked by (3)cmeerw Not_Oles Crab
    I need to get myself in the mood to try again to make a freebsd image that can take a cloudinit config.... Maybe next try this weekend.
  • Just a note that the fix for the missing memory barriers in the NetBSD virtio driver has now been pulled into the stable NetBSD branches.
    Just put a smile on your face and get it going. That's all you'll need!
    Hi @Crab! :) Hi @cmeerw! HI @Everyone!
    I thought I'd mention the discussion of NetBSD 10 on a VAX in a recent Dave's Garage video, beginning about 10:00:
    Thanked by (2)cmeerw Crab
  • Dave will need another garage soon for all his toys, but thanks for sharing the link. I'll definitely check it out.
    @FrankCastle @Crab @Everyone
    Hello!
    If you have time and inclination, please consider posting a screenshot of your terminal plus a brief comment into my current LES Talk thread at https://lowendspirit.com/discussion/10113/how-do-you-set-up-your-terminal. I would love to see what you are using!
    Thanks!
    Tom
  • Interesting read: Static Web Hosting on the Intel N150: FreeBSD, SmartOS, NetBSD, OpenBSD and Linux Compared
    But it doesn't really go into details of the TLS performance difference - is it just because of different versions of OpenSSL (or whatever fork of it is being used) and maybe gcc (with different optimisations)?
    edited November 2025
    @cmeerw said: details of the TLS performance difference
    @cmeerw You know a lot more than I do, but I am guessing that FreeBSD's excellent performance in the article you linked might be more due to FreeBSD Kernel TLS and SSL_sendfile improvements from Netflix rather than to userland OpenSSL or gcc differences?
    @cmeerw You know more than I do, but I am guessing that FreeBSD's excellent performance in the article you linked might be more due to FreeBSD Kernel TLS and SSL_sendfile improvements from Netflix rather than to userland OpenSSL or gcc differences?
    But then the article has this note:
    Some operating systems (FreeBSD and Linux) support kernel TLS (kTLS) and the related SSL_sendfile path in nginx, which can improve HTTPS performance for static files. Since this feature is not available on all the systems included in the comparison (for example NetBSD, OpenBSD and illumos), the benchmarks were run with a common baseline configuration that does not rely on kTLS. The goal is to compare the systems under similar conditions rather than to measure OS specific optimizations.
