Warning! The ColoCrossing database appears to have been compromised.
edited May 2025 in General
We warned ColoCrossing, but they decided to restore the email, we
came up with the choice to start leaking the database, and once we
get access to the new data from the email back - we'll send
everything out to the emails
Link to ColoCrossing database https://dropmefiles.com/REMOVED
Removed the download link and I'm not sure if I'm allowed to post it.
Thanked by (2)treesmokah host_c
«13
  • edited May 2025
    Their Virtualizor got breached. ColoCrossing, HudsonValleyHost, ChicagoVPS are affected. ~11k customers data is there, all in plaintext. Passwords, email and data related to VM's. I would recommend reinstalling all your VM's with them and changing passwords. Or even better, don't use providers with Virtualizor.
    mod edit: snip
    Thanked by (4)tulipyun imok tentor zgato
  • And nothing will happen to them.
  • Did anyone received explanation email from cc? Laughable.
  • You mean as usual? This is not the first or last time.
  • edited May 2025
    Dear Customer,
    We’re reaching out to inform you of a recently resolved security matter involving the control panel software used to manage your ColoCloud virtual servers.
    The issue was identified on May 24th and stemmed from a vulnerability in a Single Sign-On (SSO) feature. While this did not impact the ColoCloud billing system (WHMCS) or expose any personal or payment information, the attacker was able to access limited system metadata, email addresses, and used our mail server API to send an unauthorized message to ColoCloud customers.
    All ColoCloud infrastructure is fully operational and secure. With support from the software vendor, we have taken all necessary steps to address the vulnerability and harden the environment.
    As a precaution, we recommend:
    • Rotating the root password for your virtual server container
    • If you reuse your Virtualizor password on other platforms, consider updating those as well
    These recommendations are made out of an abundance of caution. All stored container passwords remain securely encrypted. Additionally, while we have temporarily disabled access to the Virtualizor control panel, customers may still manage and interact with their virtual servers securely via WHMCS.
    We’ve responded quickly and thoroughly to ensure platform security and prevent this from recurring. If you need assistance resetting your passwords, our support team is ready to help.
    Please note: this communication applies only to the ColoCloud cloud/vps platform. It does not involve any part of the ColoCrossing dedicated server or colocation infrastructure, which operates on a separate system.
    Thank you for your continued trust.
    Sincerely,
    The ColoCloud Team
    This is the response. And they are lying about the scope.
    There is evidence of several VM's being compromised as a result of this, and the leaked data speaks for itself.
    Thanked by (2)imok tentor
    dont know why anyone would use CC vps. far from best in price and performance.
    Thanked by (2)imok vyas
    edited May 2025
    Looks pretty ugly, they also posted the link on nodeseek....
  • "the attacker was able to access limited system metadata, email addresses" passwords are not limited system metadata. They are literally lying.
    Plaintext container passwords 🫠
    I wonder why other panels only show a generated root password once…
  • @treesmokah said: I would recommend reinstalling all your VM's with them and changing passwords.
    Do people keep the password set by the panel during installation (and/or set the root password through the panel)? Is this ever a good idea?
    Or if you are using the VPS for something important - shouldn't you install the VPS from scratch anyway, so you know what's actually running on the VPS?
    Thanked by (1)skorous
  • teamaccteamacc OGSenpai
    Sorry, but how does
    "leaking email addresses"
    qualify as
    ".. this did not ... expose any personal ... information"
  • @teamacc said:
    Sorry, but how does
    qualify as
    Maybe the email that got leaked was their company email address, not personal email. :lol:
  • tentortentor Hosting Provider
    @cmeerw said: Do people keep the password set by the panel during installation (and/or set the root password through the panel)? Is this ever a good idea?
    Someone apparently does, and it is definitely not a good idea. Better approach (from a providers' perspective) is to enforce password reset on first successful login. The best approaches are use of SSH public keys, or, as you've mentioned:
    @cmeerw said: Or if you are using the VPS for something important - shouldn't you install the VPS from scratch anyway, so you know what's actually running on the VPS?
    However, there is a problem with this approach - virtual machine provision will take significantly longer or more effort than installation from a provider provided template.
    Check our KVM VPS plans in 🇵🇱 Warsaw, Poland and 🇸🇪 Stockholm, Sweden
    Right, but using the provider provided template will hit you later (most likely at the most inconvenient time): when something breaks (probably because you are upgrading to a new version) and you have to figure out why, and then you have to ask "why on earth did they make that modification in their template?"
    I have yet to see a provider provided template without any issues.
    Thanked by (1)quicksilver03
    Depends, there should be no issues with templates that are official images with cloud-init.
  • @teamacc said:
    Sorry, but how does
    qualify as
    Full names are also exposed, since those are migrated from WHMCS when they create your Virtualizor account for management. Unless you manually changed it.
  • somiksomik OG
    edited May 2025
    Anyone know where to download such files? Asking on behalf of some very reputable hosts looking for new customers :lol:
    EDIT: ^ The above is a sarcasm and not to be taken seriously (cant believe i have to explain it)...
    Thanked by (1)satorik
  • MasonMason AdministratorOG
    Good move. Feel free to discuss what happened but there will be no sharing or distribution of compromised databases/customer details on this platform.
    @VirMach are you secretly enjoying this
  • I'm sure he can neither confirm nor deny it.
  • Well it appears they have received the ColonCleansing they needed
    Thanked by (2)vyas burntascii
    Colonoscopy was done and some artifacts discovered. Now long path to healing... Both reputational damage + damage for deleted servers.
    They are like slimes man they always recover for awful reason. Like the bad guys in DBZ.
  • @VirMach any any refugee offers? Just got 3 of VMs nuked.
    Reguards
    Thanked by (1)Wonder_Woman
  • edited May 2025
    Looks like you won't have to reinstall it anymore, the attackers nuked all the vm's lol
    They still have access to Virtualizor, prior to that some Chinese users started getting infected with crypto miners on their VPS.
    What a disaster
    colocrossing is also not loading anymore
    Reguards
    We can probably honor whatever amount of service you had left with them and renewal at the same price, but I don't know much about the type of offers they've been posting. Let's just say it'd be to help out any LES members, as I don't want to open the floodgates to a bunch of tickets at the moment (it'll be difficult to go through all of them, verify, and manually create.)
    I'm waiting for the @raindog308 "ColoCrossing Teeters at the Edge" LEB post.
  • @VirMach said: I'm waiting for the @raindog308 "ColoCrossing Teeters at the Edge" LEB post.
    Yeah, he won't bite the hand that feeds him. CC ultimately feeds him contrary to other statements. I foresee an LEB post of "all is really fine, they are on top of it, you should thank CC for their effort and not worry, etc".
    Thanked by (2)kheng86 burntascii
  • @VirMach said:
    Reguards
    Wow nice. Their main plan was a $10 one - 1c/1g/20gb SSD and 20tb bw. I think most people are on that.
    Already out
    https://lowendbox.com/blog/colocloud-breach-virtualizer-bugs-lead-to-wild-lowendtalk-thread/
