The Dedi Conundrum
I definitely dont need both so have to let go of one but I cant really make up my mind.
GSI - $60/month - 64TB disks
Leaseweb - $40/month - 32TB disksr
Pasting Yabs and network test for both below. Which one would you keep and why?
Leaseweb
YABS
# Yet-Another-Bench-Script #
# v2025-04-20 #
Thu Jun 5 02:52:58 AM UTC 2025
Uptime : 3 days, 10 hours, 27 minutes
Processor : Intel(R) Xeon(R) E-2388G CPU @ 3.20GHz
CPU cores : 16 @ 1100.544 MHz
AES-NI : ✔ Enabled
RAM : 31.3 GiB
Swap : 4.0 GiB
Disk : 29.0 TiB
Distro : Ubuntu 24.04.2 LTS
Kernel : 6.8.0-60-generic
VM Type : NONE
ISP : LeaseWeb Netherlands B.V.
ASN : AS60781 LeaseWeb Netherlands B.V.
Host : LeaseWeb Netherlands B.V.
Country : The Netherlands
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md5):
Read | 1.80 MB/s (451) | 26.68 MB/s (416)
Write | 1.82 MB/s (457) | 27.11 MB/s (423)
Total | 3.63 MB/s (908) | 53.79 MB/s (839)
Read | 101.88 MB/s (198) | 102.15 MB/s (99)
Write | 107.29 MB/s (209) | 108.96 MB/s (106)
Total | 209.18 MB/s (407) | 211.11 MB/s (205)
Clouvider | London, UK (10G) | 939 Mbits/sec | 936 Mbits/sec | 7.92 ms
Eranium | Amsterdam, NL (100G) | 941 Mbits/sec | 942 Mbits/sec | 1.28 ms
Uztelecom | Tashkent, UZ (10G) | 891 Mbits/sec | 473 Mbits/sec | 82.1 ms
Leaseweb | Singapore, SG (10G) | 766 Mbits/sec | 552 Mbits/sec | --
Clouvider | Los Angeles, CA, US (10G) | 822 Mbits/sec | 287 Mbits/sec | 159 ms
Leaseweb | NYC, NY, US (10G) | 885 Mbits/sec | 614 Mbits/sec | 78.1 ms
Edgoo | Sao Paulo, BR (1G) | 699 Mbits/sec | 242 Mbits/sec | 201 ms
Test | Value
Single Core | 2282
Multi Core | 9843
Full Test | https://browser.geekbench.com/v6/cpu/12286092
Nws.sh
---------------------------------- nws.sh ---------------------------------
A simple script to bench network performance using speedtest-cli
Version : v2025.05.01
Global Speedtest : wget -qO- nws.sh | bash
Region Speedtest : wget -qO- nws.sh | bash -s -- -r <region>
Basic System Info
CPU Model : Intel(R) Xeon(R) E-2388G CPU @ 3.20GHz
CPU Cores : 16 @ 1900.000 MHz
CPU Cache : 16384 KB
AES-NI : ✔ Enabled
Total Disk : 29.0 TB (4.6 GB Used)
Total RAM : 31.3 GB (1.1 GB Used)
Total Swap : 4.0 GB (0 Used)
System uptime : 3 days, 10 hour 12 min
Load average : 0.00, 0.13, 0.31
OS : Ubuntu 24.04.2 LTS
Arch : x86_64 (64 Bit)
Virtualization : NONE
TCP Control : bbr
Basic Network Info
Primary Network : IPv4
IPv6 Access : ❌ Offline
IPv4 Access : ✔ Online
Location (IPv4) : Lelystad, Flevoland, NL
Location Latency Loss DL Speed UP Speed Server
ISP: LeaseWeb Netherlands B.V.
Nearest 0.87 ms 0.0% 940.52 Mbps 941.49 Mbps 31173 Services AB - Amsterdam
Kochi, IN 169.67 ms 0.0% 523.11 Mbps 451.64 Mbps Asianet Broadband - Cochin
Bangalore, IN 263.49 ms 0.0% 526.45 Mbps 318.28 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 155.37 ms 0.0% 519.56 Mbps 518.25 Mbps Jio - Chennai
Mumbai, IN 257.60 ms 0.0% 905.21 Mbps 323.88 Mbps Melbicom - Mumbai
Delhi, IN 272.61 ms 0.0% 431.65 Mbps 298.44 Mbps Tata Play Fiber - New Delhi
Seattle, US 149.70 ms N/A 644.83 Mbps 538.92 Mbps Comcast - Seattle, WA
Los Angeles, US 128.83 ms 0.0% 517.48 Mbps 599.71 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 122.69 ms 0.0% 704.19 Mbps 697.46 Mbps Hivelocity - Dallas, TX
Miami, US 111.11 ms 0.0% 510.54 Mbps 642.95 Mbps Telxius - Miami, FL
New York, US 76.53 ms 0.0% 969.87 Mbps 886.62 Mbps GSL Networks - New York, NY
Toronto, CA 92.21 ms 0.0% 862.12 Mbps 871.02 Mbps Rogers - Toronto, ON
Mexico City, MX 168.27 ms N/A 580.98 Mbps 506.61 Mbps INFINITUM - Ciudad de México
London, UK 6.17 ms 0.0% 941.27 Mbps 935.30 Mbps VeloxServ Communications - London
Amsterdam, NL 1.38 ms 0.0% 938.83 Mbps 941.46 Mbps 31173 Services AB - Amsterdam
Paris, FR 10.97 ms N/A 944.58 Mbps 941.40 Mbps Axione - Paris
Frankfurt, DE 7.57 ms 0.0% 940.36 Mbps 935.35 Mbps Clouvider Ltd - Frankfurt am Main
Warsaw, PL 20.24 ms 0.0% 944.11 Mbps 926.44 Mbps Play - Warszawa
Bucharest, RO 34.75 ms 0.0% 61.90 Mbps 916.02 Mbps Vodafone Romania Mobile - Bucharest - Bucharest
Moscow, RU 42.94 ms 0.0% 199.83 Mbps 910.77 Mbps t2 Russia - Moscow
Jeddah, SA 70.19 ms 0.0% 969.58 Mbps 922.05 Mbps Saudi Telecom Company
Dubai, AE 120.93 ms N/A 979.01 Mbps 715.28 Mbps e& UAE - Dubai
Istanbul, TR 43.87 ms 0.0% 950.28 Mbps 934.35 Mbps Turkcell - Istanbul
Tehran, IR 79.26 ms 0.0% 567.01 Mbps 405.67 Mbps MCI
Cairo, EG 59.63 ms N/A 889.40 Mbps 905.36 Mbps Orange Egypt - Cairo
Tokyo, JP FAILED
Shanghai, CU-CN 264.47 ms 0.3% 818.50 Mbps 5.06 Mbps China Unicom 5G - Shanghai
Suzhou, CT-CN 184.89 ms N/A 320.26 Mbps 453.99 Mbps China Telecom JiangSu 5G - Suzhou
Hong Kong, CN 168.79 ms N/A 672.21 Mbps 129.71 Mbps Misaka Network, Inc. - Hong Kong
Singapore, SG 155.10 ms 0.0% 598.87 Mbps 533.75 Mbps NewMedia Express - Singapore
Jakarta, ID FAILED - IP has been rate limited. Try again after 1 hour.
Avg DL Speed : 702.50 Mbps
Avg UL Speed : 658.87 Mbps
Total DL Data : 26.01 GB
Total UL Data : 21.59 GB
Total Data : 47.59 GB
Duration : 13 min 10 sec
System Time : 05/06/2025 - 02:50:45 UTC
Total Script Runs : 114171
Result : https://result.nws.sh/r/1749091458_LTBUPC_GLOBAL.txt
GSI
YABS
# v2025-04-20 #
Thu Jun 5 02:53:03 AM UTC 2025
Uptime : 0 days, 4 hours, 53 minutes
Processor : Intel(R) Xeon(R) CPU E3-1240 v3 @ 3.40GHz
CPU cores : 8 @ 2499.855 MHz
AES-NI : ✔ Enabled
RAM : 31.3 GiB
Swap : 3.8 GiB
Disk : 58.0 TiB
Kernel : 6.1.0-37-amd64
VM Type : NONE
ISP : GorillaServers, Inc.
ASN : AS53850 GorillaServers, Inc.
Host : Webnx Inc
Country : United States
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/mapper/WNX0027368--vg-root):
Read | 5.68 MB/s (1.4k) | 50.85 MB/s (794)
Write | 5.69 MB/s (1.4k) | 51.17 MB/s (799)
Total | 11.37 MB/s (2.8k) | 102.02 MB/s (1.5k)
Read | 225.01 MB/s (439) | 277.60 MB/s (271)
Write | 236.96 MB/s (462) | 296.09 MB/s (289)
Total | 461.97 MB/s (901) | 573.69 MB/s (560)
Clouvider | London, UK (10G) | 451 Mbits/sec | 646 Mbits/sec | 155 ms
Eranium | Amsterdam, NL (100G) | 828 Mbits/sec | 685 Mbits/sec | 174 ms
Uztelecom | Tashkent, UZ (10G) | 656 Mbits/sec | 629 Mbits/sec | 216 ms
Leaseweb | Singapore, SG (10G) | 331 Mbits/sec | 608 Mbits/sec | --
Clouvider | Los Angeles, CA, US (10G) | 934 Mbits/sec | 937 Mbits/sec | 14.4 ms
Leaseweb | NYC, NY, US (10G) | busy | 869 Mbits/sec | 58.8 ms
Edgoo | Sao Paulo, BR (1G) | 745 Mbits/sec | 12.0 Mbits/sec | 185 ms
Test | Value
Single Core | 1322
Multi Core | 4386
Full Test | https://browser.geekbench.com/v6/cpu/12286175
YABS completed in 18 min 26 sec
Nws.sh
Basic System Info
CPU Model : Intel(R) Xeon(R) CPU E3-1240 v3 @ 3.40GHz
CPU Cores : 8 @ 2399.923 MHz
CPU Cache : 8192 KB
AES-NI : ✔ Enabled
Total Disk : 58.0 TB (1.6 GB Used)
Total RAM : 31.3 GB (626.9 MB Used)
Total Swap : 3.8 GB (0 Used)
System uptime : 0 days, 4 hour 38 min
Load average : 1.26, 1.20, 0.61
OS : Debian GNU/Linux 12
TCP Control : bbr
Basic Network Info
Host : Webnx Inc
ISP: GorillaServers
Nearest 1.11 ms 0.0% 942.41 Mbps 941.39 Mbps WebNX Inc. - Ogden, UT
Kochi, IN 237.15 ms 0.0% 742.88 Mbps 329.45 Mbps Asianet Broadband - Cochin
Bangalore, IN 254.16 ms 0.0% 959.41 Mbps 318.82 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 268.79 ms 0.0% 823.64 Mbps 293.20 Mbps Jio - Chennai
Mumbai, IN 260.03 ms 0.0% 866.71 Mbps 283.72 Mbps Melbicom - Mumbai
Delhi, IN 285.10 ms 0.0% 937.36 Mbps 272.77 Mbps Tata Play Fiber - New Delhi
Seattle, US 40.74 ms N/A 945.42 Mbps 934.17 Mbps Comcast - Seattle, WA
Los Angeles, US 15.75 ms 0.0% 941.59 Mbps 933.08 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 49.16 ms 0.0% 913.33 Mbps 921.25 Mbps Hivelocity - Dallas, TX
Miami, US 74.24 ms 0.0% 944.33 Mbps 897.31 Mbps Telxius - Miami, FL
New York, US 57.20 ms 0.0% 967.58 Mbps 893.71 Mbps GSL Networks - New York, NY
Toronto, CA 63.37 ms 0.0% 951.06 Mbps 900.18 Mbps Rogers - Toronto, ON
Mexico City, MX 54.05 ms N/A 949.60 Mbps 921.20 Mbps INFINITUM - Ciudad de México
London, UK 142.99 ms 0.0% 938.55 Mbps 494.40 Mbps VeloxServ Communications - London
Amsterdam, NL 188.09 ms 2.1% 884.99 Mbps 350.61 Mbps 31173 Services AB - Amsterdam
Paris, FR 161.02 ms N/A 939.50 Mbps 439.93 Mbps Axione - Paris
Frankfurt, DE 184.49 ms 2.3% 849.65 Mbps 204.79 Mbps Clouvider Ltd - Frankfurt am Main
Warsaw, PL 202.95 ms 4.7% 875.59 Mbps 250.28 Mbps Play - Warszawa
Bucharest, RO 182.96 ms 0.0% 11.45 Mbps 443.44 Mbps Vodafone Romania Mobile - Bucharest - Bucharest
Moscow, RU 197.14 ms 0.0% 7.79 Mbps 9.26 Mbps t2 Russia - Moscow
Jeddah, SA 173.39 ms 0.0% 955.84 Mbps 480.21 Mbps Saudi Telecom Company
Dubai, AE 264.96 ms N/A 861.70 Mbps 76.13 Mbps e& UAE - Dubai
Istanbul, TR 186.48 ms 0.0% 969.54 Mbps 425.08 Mbps Turkcell - Istanbul
Tehran, IR 230.21 ms 0.0% 943.19 Mbps 339.55 Mbps MCI
Cairo, EG 220.19 ms N/A 923.79 Mbps 290.93 Mbps Orange Egypt - Cairo
Tokyo, JP FAILED
Shanghai, CU-CN 203.22 ms 0.0% 940.77 Mbps 402.57 Mbps China Unicom 5G - Shanghai
Suzhou, CT-CN 151.22 ms N/A 34.90 Mbps 546.71 Mbps China Telecom JiangSu 5G - Suzhou
Hong Kong, CN 174.80 ms N/A 678.59 Mbps 366.12 Mbps Misaka Network, Inc. - Hong Kong
Singapore, SG 259.31 ms 3.0% 80.42 Mbps 273.06 Mbps NewMedia Express - Singapore
Avg DL Speed : 785.57 Mbps
Avg UL Speed : 490.80 Mbps
Total DL Data : 31.15 GB
Total UL Data : 17.73 GB
Total Data : 48.88 GB
Duration : 14 min 34 sec
System Time : 05/06/2025 - 02:52:04 UTC
Total Script Runs : 114172
curl is not installed, Unable to share result online
Result stored locally in /root/network-speed.txt
Team push-ups!
You don't need either of them. So keep the Leaseweb.
Wdym
Team push-ups!
I'd keep the leaseweb one unless you need the disk on GSI or you think you might need it soon.
any particular reason you'd go that route?
Team push-ups!
Because you're paying extra for something you're not using, I'd suppose.
hmm makes sense
Team push-ups!
dump both and get a $7 vps
Come on Benchmark King. Pick one!
Team push-ups!
Just get rid off them if you don't use them.
Jokes aside.
I should also get rid of my MYSTERY that burns 25$ every month.
leaseweb for better CPU. but pointless to idle on
This thread should be renamed
The Return of the Dedi
just because...
blog | exploring visually |
I'm in the market for something similar, how did you mange to find it?
