c-servers experience
can anyone here share their experience with c-servers?
    Depends, if you are unlucky, one of my VM's has been recreated 3 times.
    One VM has been moved to a different location, after I used the upgrade button.
    Had a discussion for a bit until he agreed to move my VM back.
    So yea, if it works, its fine.
    Thanked by (1)KenTech
    Question is why
  • C-Servers sells 99-year plans, so please check back in 99 years.
    Thanked by (2)nick_ KenTech
  • I got their $4 plan a while back. I wanted to see and test ipv6, and from that point i think it's good. My vps has been recreated once, and I haven't had any other hiccup. It works, and i'm pretty confident they aren't going to run away with my four dollars (6/10 confidence).
    I have a very simple note taking app hosted there, but i can never reach it the first time. ssh is similar; i have seldom been able to connect on the first try.
    it's fine, for a cheap little ipv6 only vps. i would even recommend it, if you want something for less than $10/year and don't mind no ipv4. don't expect too much from it though.
