What do you do with your idle VPS?
Although it's idle, I still want to continue buying the $5/year VPS :p
  • skhronskhron Hosting Provider
    If it is truly idle you don't use it
    Check our KVM VPS plans in 🇵🇱 Warsaw, Poland and 🇸🇪 Stockholm, Sweden
  • Use one idle VPS to ping another idle VPS, so that both of them become useful. B)
  • setup uptimekuma
    Thanked by (2)ehab rizkiv1
    only one thing I'd do.
  • @gomi An idle VPS doesn’t need to go to waste you can put it to work in several practical ways. One effective use is setting up a monitoring tool like Uptime Kuma or Prometheus to track the performance and uptime of your websites or servers. This helps you stay informed about issues in real-time.
    Alternatively, you can turn your VPS into a secure VPN server using OpenVPN or WireGuard. This allows you to browse the internet privately, encrypt your traffic, and access geo-restricted content globally offering both security and flexibility.
    Thanked by (1)gomi
    John Smith
    🌍 www.hifivehost.com | ⚡ Empowering Scalable Hosting Solutions
  • We cancel the idle VPS.
    Thanked by (2)host_c Ouji
    sounds great
  • @techie_john said: Alternatively, you can turn your VPS into a secure VPN server using OpenVPN or WireGuard. This allows you to browse the internet privately, encrypt your traffic, and access geo-restricted content globally offering both security and flexibility.
    That sounds like a lot of marketing BS.
    Thanked by (1)skhron
    Glorified AIM chatbot on steriods derivative
    Winners never quit!
  • seedbox is 90% idle.
    Don't have a lot mostly because I don't have a use. I've got a static ip, gigabit at home and 24/7 servers at home so limited use for vps beyond shielding IP.
    My gut feel would be seed linux isos (actual ones) because I like helping people....but most providers aren't down with torrent traffic - understandably.
  • amigaamiga OG
    edited August 25
    A list of Free Software network services and web applications which can be hosted on your own servers:
    https://github.com/awesome-selfhosted/awesome-selfhosted/
    Thanked by (1)hornet
  • FreekFreek Senpai
    I run an Archive Team Warrior on every 'idle' VPS I have: https://github.com/ArchiveTeam/warrior-dockerfile
    It's really easy to setup and you help to preserve the internet. Yes it does cost some bandwidth, but since it's idle anyway, why not use the resources? It's very low on CPU and MEM, so even 1 core and 1GB is sufficient.
    Thanked by (1)ehab
    You all have idle vps?
  • I pay @VirMach for them religiously.
    Thanked by (2)ehab DataRecovery
  • Feel guilty, eventually cancel to save money, which frees up money for me to buy other VPS to idle.
    Thanked by (1)jnd
    Finally found a good use for one - getting past this new upload your passport bullsht the UK rolled out. Rest is currently idle
    Think I've got 4x floating around but they're all ~12/y so no big deal
  • I usually leave it running with basic monitoring and auto-updates. Sometimes I spin up a personal project, host a private git repo, or use it as a backup target. If it’s truly idle for weeks, I shut it down - no point paying for nothing.
    Same here. Last month got another dedicated server that was on offer. Then realized I dont need it, so canceled it. I am sure I'll soon be spending that money on something else I dont need soon.
    Erm, but doesn't that identify verification requirement only apply if you are accessing adult content?
    Kinda, but places like reddit are basically broken without it cause it uses the NSFW tag to determine it. And all sorts of random crap gets marked nsfw. Hell you can even mark your own profile page nsfw.
    Also imgur decided to block UK wholesale yesterday. Think that's a separate beef though
    I'm just glad that thus far all the filters are pretty easy to sidestep. Companies are doing the bare minimum rather than fancy GFWish stuff
    Basically your proxy works by checking what domain you are accessing? How do you set that up? Maybe open a new thread with the details?
    Warning, do not view if you are from UK. NSFW image.
    Squid(nginx? don't remember) on vps along with UFW to allow only home IP, then .pac file loaded into firefox proxy config. Pac can can do per domain proxy
  • somiksomik OG
    edited October 1
    Doesn't squid sent traffic unencrypted?
    So nginx encrypts the traffic...
    Nope - it's just passthrough so encryption remains intact between browser and website. No real change in risk for https
    Getting a proxy to decrypt https is a pain to do and more complicated so kinda ends up being secure by default
    Found my notes on it
    # Squid proxy for HTTP and HTTPS
    Install on debian and edit the config
    apt update && apt upgrade -y
    apt install squid -y
    mv /etc/squid/squid.conf /etc/squid/bck_squid.conf
    nano /etc/squid/squid.conf
    Config file:
    # Allow access from your IP range
    acl localnet src xxxyourIPxxx
    http_access allow localnet
    # Deny all other access
    http_access deny all
    # Set the port Squid will listen on (default is 3128)
    http_port 7777
    # Allow CONNECT method to access HTTPS sites
    acl SSL_ports port 443
    acl Safe_ports port 80      # http
    acl Safe_ports port 443     # https
    acl CONNECT method CONNECT
    http_access allow CONNECT SSL_ports
    Restart the squid daemon
    systemctl restart squid
    And monitor:
    tail -f /var/log/squid/access.log
    Note that adding UFW is a good idea
    Thanked by (2)eliphas DataRecovery
    Don't you happen to know what would the smallest VPS to run Squid these days (especially RAM consumption)?
    The last time I used Squid was long, long time ago - something like Opera v6/7/8 days or so.
    So no simple options for a non-static IP, like a cell phone access?
    Another option is installing Prosody and moving away from proprietary messengers.
    But that also requires talking your buddies into switching to something like Conversations.
    StorageAMD EPYC VDS (ref) up to 4TB NVMe & 10TB SAN disk / NVMe + big HDD storage VPS (ref) from $2.29/TB/mo
    Should run on a potato. It's not caching anything...so not squid in the usual sense
    You'd have to do certificate auth I'd imagine. Figuring that out is on my todo list but haven't yet (want to use it to do DoH adguard without vpn / open resolver)
    Bunch of small ones. Though moving more stuff inhouse...chunky homeserver makes it harder to justify vps
    Thanked by (1)DataRecovery
    Yes. We buy ridiculous $7 deals and then don’t use them. The providers running real money deals sell a lot less and see a lot more usage. Abusers and North Korean spies excluded from statistics from being sh*ts.
    @DrNutella said: Abusers and North Korean spies excluded from statistics from being sh*ts.
    Got ya maybe I need to buy them all up and resell them at huge markups. You know the American way have to make sure my support of them is just as sh*t as the users though.
    Thanked by (1)DrNutella
