Free LES Community Server from Hosteroid via MetalVPS!
17810121315
    The next step is installing the sources, which is covered in the OpenBSD FAQ - Building the System from Source.
    OpenBSD and NetBSD use CVS as their source code version management software. OpenBSD and NetBSD both recommend avoding running CVS as root. So we want initially to
    • set up an unprivileged CVS user.
    Then, we need to
    • set up additional source directories /usr/xenocara (for X11), and /usr/ports (for packages).
    Next, we need to select an OpenBSD CVS server from the list at OpenBSD Anonymous CVS.
    Finally, we want our unprivileged user to
    • fetch the OpenBSD-current, xenocara, and ports sources.
    I will post a little more about each of these steps as I go through them. Thanks! <3
    Thanked by (1)cmeerw
  • So the update seems to have overwritten /etc/rc.conf - the main thing that I had changed in there was setting httpd_flags= (from httpd_flags=NO - the old file was backed up in /var/backups/etc_rc.conf.backup). I have made that change again now.
    @Not_Oles do you happen to remember any warning related to that?
    @cmeerw As you know, in NetBSD there is etcupdate, which is a specific command designed to adjust upgrades to the files in etc.
    But, in OpenBSD, when somebody runs sysupgrade -s it's not clear to me, yet, how etc is protected. Or if etc is protected. In particular, I don't recall seeing a warning about etc/rc.conf, but a warning could have been displayed prominently and I might nevertheless have missed it.
    If I understand correctly, you want http_flags= set to nothing (not even set to "") in /etc/rc.conf. So I will check that setting when I do something that seems like it might change /etc/rc.conf.
    I will take another look at the sysupgrade man page and documentation to see what I can find about how sysupgrade -s treats /etc. Anything else, please let me know. Apologies for any inconvenience! Thanks! <3
    edited June 24
    @Not_Oles said: I will take another look at the sysupgrade man page and documentation to see what I can find about how sysupgrade -s treats /etc.
    Looking again at the sysupgrade(8) man page, which is available online at https://man.openbsd.org/sysupgrade.8, there seems to be nothing said about what happens to /etc when sysupgrade is used.
    The OpenBSD Following -current and using snapshots FAQ also doesn't seem to say anything about /etc.
    When I previously used sysupgrade at Hetzner Cloud, there were no issues that I recall.
    Nevertheless, it seems obvious that hlcs wasn't in the default state, so I should have looked for any changes @cmeerw made which might have needed attention. My bad!
    @cmeerw If there is anything else that I need to fix, I sincerely hope and trust that you would have mentioned it. So, moving onward! :)
    @Not_Oles said: we want initially to
    @cmeerw Okay to name the unprivileged CVS user "ucvsu"?
    Sure.
    edited June 25
    Guys, @cmeerw Does this seem reasonable?
    Plan for creating a build user, creating directories, and fetching OpenBSD sources for hlcs
    June 25, 2025
    References:
    https://www.openbsd.org/faq/current.html # Scroll down to see note re login class
    https://www.openbsd.org/faq/faq5.html#Bld
    https://www.openbsd.org/anoncvs.html
    man useradd
    man login.conf
    man id
    Commands:
    # useradd -G wsrc,wobj -L build ucvsu # _u_nprivileged _cvs_ _u_ser
      # Looks like we already have login class "build":
      hlcs$ grep build /etc/login.conf
      build:\
      pbuild:\
      hlcs$
    # cd /usr
    # mkdir ports xenocara
    # chown root:wsrc ports xenocara
    # chmod 775 ports xenocara
    # su ucvsu
    $ cvs -qd [email protected]:/cvs checkout -P src
    $ cvs -qd [email protected]:/cvs checkout -P ports
    $ cvs -qd [email protected]:/cvs checkout -P xenocara
    Notes:
    Nearby CVS mirror updated hourly from main server:
    hlcs$ ping -c 2 ftp.hostserver.de
    PING ftp.hostserver.de (217.31.80.35): 56 data bytes
    64 bytes from 217.31.80.35: icmp_seq=0 ttl=246 time=29.643 ms
    64 bytes from 217.31.80.35: icmp_seq=1 ttl=246 time=29.597 ms
    --- ftp.hostserver.de ping statistics ---
    2 packets transmitted, 2 packets received, 0.0% packet loss
    round-trip min/avg/max/std-dev = 29.597/29.620/29.643/0.023 ms
    hlcs$
    Expected ftp.hostserver.de fingerprint:
    (ED25519) SHA256:KeG1InAfAnQKqpCewmXw/Egb+4UZZuIMGdlYVG+uxNg
    Confirmed the fingerprint:
    hlcs$ ssh ftp.hostserver.de
    The authenticity of host 'ftp.hostserver.de (217.31.80.35)' can't be established.
    ED25519 key fingerprint is: SHA256:KeG1InAfAnQKqpCewmXw/Egb+4UZZuIMGdlYVG+uxNg
    This key is not known by any other names.
    Are you sure you want to continue connecting (yes/no/[fingerprint])? no
    Host key verification failed.
    hlcs$
    # We're already running clang 19.1.
    hlcs$ clang --version
    OpenBSD clang version 19.1.7
    Target: amd64-unknown-openbsd7.7
    Thread model: posix
    InstalledDir: /usr/bin
    hlcs$
    # We already have some of the needed directories:
    hlcs$ ls -l /usr
    total 120
    drwxr-xr-x   7 root   wheel   512 Jun 18 15:16 X11R6
    drwxr-xr-x   2 root   wheel  6144 Jun 19 15:39 bin
    drwxr-xr-x   2 root   wheel  1024 Jun 19 04:12 games
    drwxr-xr-x  31 root   bin    3072 Jun 19 04:12 include
    drwxr-xr-x   6 root   wheel  3584 Jun 19 15:39 lib
    drwxr-xr-x   5 root   wheel   512 Jun 18 14:30 libdata
    drwxr-xr-x   7 root   wheel  1024 Jun 19 15:39 libexec
    drwxr-xr-x  11 root   wheel   512 Jun 18 15:16 local
    drwxr-xr-x   2 root   wheel   512 Jun 18 14:30 mdec
    drwxrwx---   2 build  wobj    512 May 29 12:28 obj # <--
    drwxr-xr-x   2 root   wheel  4096 Jun 19 15:39 sbin
    drwxr-xr-x  18 root   wheel   512 Jun 18 14:30 share
    drwxrwxr-x   2 root   wsrc    512 May 29 12:28 src # <--
    drwxrwx---   2 build  wobj    512 May 29 12:28 xobj # <--
    hlcs$
    Plan for building OpenBSD-current from source code for hlcs
    June 25, 2025
    Guys, @cmeerw How about this plan for compiling and installing OpenBSD-current? Assuming that the sources are fetched successfully as described in the previous post. . . . Thanks! <3
    References
    From https://www.openbsd.org/anoncvs.html :
    After upgrading your source tree, you should read the comments at the top of /usr/src/Makefile before attempting a build. Also, you should build a new kernel before doing a make build if possible. In some cases it may be necessary to rebuild and install the config utility before you can build the kernel. If config GENERIC fails this is probably the case.
    From https://www.openbsd.org/faq/faq5.html#wsrc :
    Building OpenBSD
    At this point you are ready to build OpenBSD from source.
    If you are building -current, review changes and special build instructions listed on this page.
    Follow the detailed instructions in steps 2 and 3 of release(8).
    Further Reading on the Build Process
    mk.conf(5)
    src/Makefile
    /usr/share/mk/bsd.README
    config(8)
    options(4)
    Step 1: Build a new kernel and reboot
    # cd /sys/arch/amd64/compile/GENERIC.MP
    # make obj
    # make config
    # make && make install
    # reboot
    Step 2: Build and install a new userland and reboot
    # cd /usr/src
    # make obj && make build
    # sysmerge
    # cd /dev && ./MAKEDEV all
    # reboot
    Thanks to @Hosteroid for our lovely hlcs! <3 Thanks to @cmeerw for great sysadmin help! <3
    Guys, if you would like an account on hlcs, please review the How to Apply section of the first post in this thread! :star:
  • edited June 26
    @Not_Oles said: # cd /sys/arch/amd64/compile/GENERIC.MP
    # make obj
    # make config
    # reboot
    Shouldn't the compile steps ideally be done under an unprivileged user, and then only switch to root for make install and reboot?
    @cmeerw said: Shouldn't the compile steps ideally be done under an unprivileged user, and then only switch to root for make install and reboot?
    Yes! Especially, haha, immediately after we went through making the unprivileged user!
    So,
    $ make obj
    $ make config
    $ make
    # make install
    # reboot
    Also, things might go less quickly without the -j option!
    Probably I want to build xenocara. We might not want to build all the ports.
    Thanks for fixing my mistakes! Much appreciated! <3 More before too long. . . .
    Hosteroid says,
    . . . maintenance at our Bucharest M247 Data Centre on 5th July 2025, starting at 11:00 GMT + 3. . . .
    Monitor our live status page for real-time updates and detailed progress: https://www.hosteroid.uk/serverstatus.php
    Thanked by (2)cmeerw babywhale
    edited June 28
    Hi!
    ucvsu is now present on hlcs! Here are a few highlights. :)
    I forgot to include the -m option in the above plan! :star:
    hlcs# useradd -G wsrc,wobj -L build ucvsu
    useradd: Warning: home directory `/home/ucvsu' doesn't exist, and -m was not specified
    hlcs#
    So I copied /etc/skel/.* manually, and changed the owners manually. The result is below.
    hlcs# pwd
    /home/ucvsu
    hlcs# ls -alR
    total 72
    drwxr-xr-x  3 ucvsu  ucvsu  512 Jun 27 23:54 .
    drwxr-xr-x  6 root   wheel  512 Jun 27 23:46 ..
    -rw-r--r--  1 ucvsu  ucvsu   87 Jun 27 23:54 .Xdefaults
    -rw-r--r--  1 ucvsu  ucvsu  761 Jun 27 23:54 .cshrc
    -rw-r--r--  1 ucvsu  ucvsu  101 Jun 27 23:54 .cvsrc
    -rw-r--r--  1 ucvsu  ucvsu  281 Jun 27 23:54 .login
    -rw-r--r--  1 ucvsu  ucvsu  175 Jun 27 23:54 .mailrc
    -rw-r--r--  1 ucvsu  ucvsu  199 Jun 27 23:54 .profile
    drwx------  2 ucvsu  ucvsu  512 Jun 27 23:54 .ssh
    ./.ssh:
    total 24
    drwxr-xr-x  3 ucvsu  ucvsu  512 Jun 27 23:54 ..
    -rw-------  1 ucvsu  ucvsu  940 Jun 27 23:57 authorized_keys
    hlcs#
    I checked /etc/passwd and /etc/group:
    hlcs# grep ucvsu /etc/passwd
    ucvsu:*:1002:1002::/home/ucvsu:/bin/ksh
    hlcs# grep ucvsu /etc/group
    wsrc:*:9:ucvsu
    wobj:*:21:ucvsu
    ucvsu:*:1002:
    hlcs#
    I checked to make sure login works as expected on IPv4 and IPv6:
    chronos@penguin:~/servers/hosteroid$ ssh [email protected]
    OpenBSD 7.7-current (GENERIC.MP) #22: Wed Jun 18 08:57:04 MDT 2025
    Welcome to OpenBSD: The proactively secure Unix-like operating system.
    hlcs$ whoami
    ucvsu
    hlcs$ exit
    Connection to xxx.xxx.xxx.xxx closed.
    hlcs$ who am i
    ucvsu    ttyp0    Jun 28 00:35   (xxxx:xxxx:xxxx::xxxx)
    hlcs$
    If ucvsu needs anything more, will somebody please speak up!? :)
    @cmeew Your ssh public key is included, so you should be able to login as ucvsu if you wish.
    I haven't done any doas configuration. If you want anything, please let me know, or just do it and let me know.
    @babywhale You haven't been active, so I commented out your key from /root/.ssh/authorized_keys and /home/ucvsu/.ssh/authorized_keys. But any time you want access restored, please ask, and I will restore your access right away. Thanks for all your help with everything! <3 Especially BashVM! <3
    I made ssh keys for ucvsu, even though making ssh keys also wasn't in the plan! :star: No password for these keys. @cmeerw if you want a password added, please let me know.
    Next up is to try CVS! :)
    Thanks to @Hosteroid for our fun, community server! <3 Thanks to @cmeerw for admin skills! <3 Thanks to any of you guys who want to join -- please review the How To Apply section of the OP! <3
    Best!
    Tom
  • I have no idea whats going on here anymore... and the messages are too long to be worth the time to read. Summarize?
    @somik
    Intel E3 dedi dual booted with Debian and OpenBSD-current. An unprivileged Concurrent Version System (CVS) user presently is being added to facilitate downloading and re-compiling the OpenBSD system from source code.
    The server is kindly donated by @Hosteroid. <3 @cmeerw is helping with system administration. <3
    If you want to use the server for something, kindly let us know. It's free for awesome LESbians like you! <3
  • Naa, I'm good. I am playing with the E5 server running proxmox I have at home. Was wondering what's going on since I saw a lot of messages flying around here. I did see messages about openbsd being installed/booted, but did not think it was being dual booted with debian.
    Made the additional needed directories:
    hlcs# cd /usr
    hlcs# mkdir -p ports xenocara
    hlcs# chgrp wsrc ports/ xenocara/
    hlcs# chmod 775 ports/ xenocara/
    hlcs# ls -l
    total 136
    drwxrwxr-x   2 root   wsrc    512 Jun 28 15:37 ports
    drwxrwxr-x   2 root   wsrc    512 Jun 28 15:37 xenocara
    hlcs#
    Maybe the sources now are present on hlcs!
    To me, it's really nice to have the sources immediately at hand, just a cd away! Thanks to the OpenBSD developers! <3
    hlcs$ cvs -qd [email protected]:/cvs checkout -P src
      [ . . . ] # The fun is in here, but there is too much to post! :)
    hlcs$ ls src/
    CVS            bin            games          lib            sbin           usr.bin
    Makefile       distrib        gnu            libexec        share          usr.sbin
    Makefile.cross etc            include        regress        sys
    hlcs$ cvs -qd [email protected]:/cvs checkout -P xenocara
    hlcs$ ls xenocara/
    3RDPARTY  MODULES   README.md data      distrib   driver    font      proto     util
    CVS       Makefile  app       dist      doc       etc       lib       share     xserver
    hlcs$ cvs -qd [email protected]:/cvs checkout -P ports
    hlcs$ ls ports
    CVS            books          education      japanese       multimedia     sysutils
    Makefile       cad            emulators      java           net            telephony
    README         chinese        fonts          korean         news           tests
    archivers      comms          games          lang           plan9          textproc
    astro          converters     geo            mail           print          wayland
    audio          databases      graphics       math           productivity   www
    benchmarks     devel          infrastructure meta           security       x11
    biology        editors        inputmethods   misc           shells
    hlcs$
    Thanks to @Hosteroid for the nice community server! <3 Thanks to @cmeerw for sysadmin help! <3
    Anybody want to hop on? Try OpenBSD's web server? Add AI? Something else? Something more? Something MOARRRRRR? Please review the How To Apply section of the OP. Thanks!
    Next up is compiling! Unless I still am missing something? <3
    edited June 28
    Compiling our new OpenBSD-current kernel!
    Checking for updates.
    hlcs$ cd /usr/src
    hlcs$ cvs -q up -Pd -A
    hlcs$
    Compiling the new kernel first, as recommended in https://man.openbsd.org/release.8.
    hlcs$ cd sys/arch/amd64/compile/GENERIC.MP/
    hlcs$ make obj
    /usr/src/sys/arch/amd64/compile/GENERIC.MP/obj -> /usr/obj/sys/arch/amd64/compile/GENERIC.MP
    hlcs$ make config
    config  -b /usr/src/sys/arch/amd64/compile/GENERIC.MP/obj  -s /usr/src/sys /usr/src/sys/arch/amd64/conf/GENERIC.MP
    hlcs$ make -j 4
    ld -T ld.script -X --warn-common -nopie -o bsd ${SYSTEM_HEAD} vers.o ${OBJS}
    text    data    bss     dec     hex
    27006746        495936  1343488 28846170        1b8285a
    mv bsd bsd.gdb
    ctfstrip -S -o bsd bsd.gdb
    hlcs$ echo $?
    0
    hlcs$
    Installing and rebooting.
    hlcs# cd /usr/src/sys/arch/amd64/compile/GENERIC.MP
    hlcs# make install
    mkdir -p -m 700 /usr/share/relink/kernel
    rm -rf /usr/share/relink/kernel/GENERIC.MP /usr/share/relink/kernel.tgz
    mkdir /usr/share/relink/kernel/GENERIC.MP
    tar -chf - Makefile makegap.sh ld.script *.o |  tar -C /usr/share/relink/kernel/GENERIC.MP -xf -
    [[ ! -f /bsd ]] || cmp -s bsd /bsd || ln -f /bsd /obsd
    [[ ! -f /etc/bsd.re-config ]] || config -e -c /etc/bsd.re-config -f bsd
    install -F -m 700 bsd /bsd && sha256 -h /var/db/kernel.SHA256 /bsd
    hlcs# echo $?
    0
    hlcs# date; ls -l /*bsd
    Sat Jun 28 22:35:53 UTC 2025
    -rwx------  1 root  wheel  32179683 Jun 28 22:34 /bsd
    -rwx------  1 root  wheel  32141799 Jun 19 15:39 /obsd
    hlcs# reboot
    Here we are, up again. :)
    hlcs$ date; uptime; uname -a
    Sat Jun 28 22:40:19 UTC 2025
    10:40PM  up 2 mins, 1 user, load averages: 0.15, 0.08, 0.03
    OpenBSD hlcs.my.domain 7.7 GENERIC.MP#0 amd64
    hlcs$
    Thanks @Hosteroid! Thanks @cmeerw! Thanks OpenBSD! Thanks LES! <3 <3 <3 <3
    Next is compiling and installing our new userland, sysmerge, makedev, and rebooting. . . .
    Compiling our new OpenBSD userland!
    hlcs$ who am i
    ucvsu    ttyp0    Jun 28 22:39   (xxx.xxx.xxx.xxx)
    hlcs$ cd /usr/src
    hlcs$ make obj
    hlcs$ make -j 4 build
    umask 007; exec make do-build
    do-build must be called by root
    *** Error 1 in . (Makefile:84 'do-build': @if [[ `id -u` -ne 0 ]]; then  echo do-build must be called by root >&2;  false;  fi)
    *** Error 2 in /usr/src (Makefile:74 'build')
    hlcs$
    hlcs# make -j 4 build
    ./llvm/llvm/lib/Target/AMDGPU/R600.td
    /usr/src/gnu/usr.bin/clang/include/llvm/AMDGPU/obj/../../../llvm-tblgen/llvm-tblgen -gen-callingconv  -I/usr/src/gnu/usr.bin/clang/include/llvm/AMDGPU/../../../../../llvm/llvm/include -I/usr/src/gnu/usr.bin/clang/include/llvm/AMDGPU/../../../../../llvm/llvm/lib/Target/AMDGPU  -o R600GenCallingConv.inc /usr/src/gnu/usr.bin/clang/include/llvm/AMDGPU/../../../../../llvm/llvm/lib/Target/AMDGPU/R600.td
    *** Signal 6 in target 'AMDGPUGenAsmMatcher.inc'
    LLVM ERROR: out of memory
    Allocation failed
    *** Signal SIGABRT in gnu/usr.bin/clang/include/llvm/AMDGPU (Makefile:100 'AMDGPUGenGlobalISel.inc')
    *** Signal SIGABRT (Makefile:51 'AMDGPUGenAsmMatcher.inc')
    *** Error 2 in gnu/usr.bin/clang (<bsd.subdir.mk>:48 'all')
    *** Error 2 in gnu/usr.bin (<bsd.subdir.mk>:48 'all')
    *** Error 2 in gnu (<bsd.subdir.mk>:48 'all')
    *** Error 2 in . (<bsd.subdir.mk>:48 'all')
    *** Error 2 in . (Makefile:97 'do-build')
    hlcs#
    I wonder how much memory is needed?
    Could it be that simply restarting the compile (keeping -j 4) might work the second time around? (BTW, I know we have 8 threads. I just used 4 not to be greedy, so @cmeerw would have compute power if needed.)
    What I did was restart the compile single threaded (make without the -j option), and the compile proceeded.
    I will post again as the compile proceeds or when it completes. Thanks! <3
    edited June 29
    Okay, similar error:
    ===> gnu/usr.bin/clang/include/llvm/AMDGPU
    asm-matcher  -I/usr/src/gnu/usr.bin/clang/include/llvm/AMDGPU/../../../../../llvm/llvm/include -I/usr/src/gnu/usr.bin/clang/include/llvm/AMDGPU/../../../../../llvm/llvm/lib/Target/AMDGPU  -o AMDGPUGenAsmMatcher.inc /usr/src/gnu/usr.bin/clang/include/llvm/AMDGPU/../../../../../llvm/llvm/lib/Target/AMDGPU/AMDGPU.td
    Allocation failed
    *** Signal SIGABRT in gnu/usr.bin/clang/include/llvm/AMDGPU (Makefile:51 'AMDGPUGenAsmMatcher.inc')
    *** Error 2 in gnu/usr.bin/clang (<bsd.subdir.mk>:48 'all': @for entry in include/llvm/Config libLLVMSupport libLLVMTableGen llvm-min-tblgen...)
    *** Error 2 in gnu/usr.bin (<bsd.subdir.mk>:48 'all': @for entry in clang cvs binutils binutils-2.17 perl texinfo; do  set -e; if test -d /u...)
    *** Error 2 in gnu (<bsd.subdir.mk>:48 'all': @for entry in lib usr.bin usr.sbin; do  set -e; if test -d /usr/src/gnu/${entry}.amd64; then  ...)
    *** Error 2 in . (<bsd.subdir.mk>:48 'all': @for entry in lib include bin libexec sbin usr.bin usr.sbin share games gnu sys; do  set -e; if ...)
    hlcs#
    More soon. It's getting late here, so sleep for now. @cmeerw If you want to play with this, maybe look inside the tmux session that root has running. If not, that's okay too. I guess it's not impossible that there might be a new commit which fixes this? I haven't checked yet. I remember you making some per process limit changes. I have to look at that again. Of course, all ideas always appreciated. Thanks! <3
  • @Not_Oles said: LLVM ERROR: out of memory
    Could be another case where the ulimit needs to be adjusted?
    I have done ulimit -d 25165824 in that tmux session and done another make build
    BTW, to get all 8 threads, sysctl hw.smt=1 is needed (probably need to add that to /etc/sysctl.conf...)
    Hi @cmeew! Thanks for your help! I woke up to:
    /usr/src/gnu/usr.bin/clang/include/llvm/AMDGPU/obj/../../../llvm-tblgen/llvm-tblgen -gen-asm-matcher  -I/usr/src/gnu/usr.bin/clang/include/llvm/AMDGPU/../../../../../llvm/llvm/include -I/usr/src/gnu/usr.bin/clang/include/llvm/AMDGPU/../../../../../llvm/llvm/lib/Target/AMDGPU  -o AMDGPUGenAsmMatcher.inc /usr/src/gnu/usr.bin/clang/include/llvm/AMDGPU/../../../../../llvm/llvm/lib/Target/AMDGPU/AMDGPU.td
    Allocation failed
    hlcs#
    @cmeerw said: I have done ulimit -d 25165824 in that tmux session and done another make build
    Checking the entry for ulimit in the ksh man page, it says, "limits may not be increased once they are set."
    The man page also says,
    -d n
    Impose a size limit of n kilobytes on the size of the data area.
    Is 25165824 kilobytes not enough? What about exiting tmux and starting another tmux session to get around the shell's inability to increase limits, and then trying ulimit -d 32425444 or maybe ulimit -d unlimited?
    For convenient reference, here are all the soft and hard limits from inside the current tmux session:
    hlcs# ulimit -a
    time(cpu-seconds)    unlimited
    file(blocks)         unlimited
    coredump(blocks)     unlimited
    data(kbytes)         25165824
    stack(kbytes)        8192
    lockedmem(kbytes)    87381
    memory(kbytes)       32425444
    nofiles(descriptors) 128
    processes            1310
    hlcs# ulimit -aH
    stack(kbytes)        32768
    lockedmem(kbytes)    262144
    memory(kbytes)       32430652
    nofiles(descriptors) 1024
    processes            1310
    hlcs#
    And from outside the tmux session:
    hlcs# ulimit -a
    data(kbytes)         4194304
    stack(kbytes)        8192
    processes            1310
    hlcs# ulimit -aH
    stack(kbytes)        32768
    processes            1310
    hlcs#
    Physical hardware limit (bytes):
    hlcs# sysctl hw.physmem
    hw.physmem=34292264960
    hlcs#
    Thanks! <3
  • Just tried running that command in a normal shell, and that seems to work. BTW, /usr/bin/time -l reports
           31.70 real        29.59 user         2.05 sys
       1519720  maximum resident set size
          3500  average shared memory size
       1166415  average unshared data size
           354  average unshared stack size
        416053  minor page faults
             1  major page faults
             0  swaps
             0  block input operations
          1349  block output operations
             0  messages sent
             0  messages received
             0  signals received
            18  voluntary context switches
           188  involuntary context switches
    So that's well below the original 4 GB limit.
    edited June 29
    @cmeew FWIW, the build doesn't seem to work for me with 4 threads:
    hlcs# date
    Sun Jun 29 19:56:07 UTC 2025
    hlcs# cd /usr/src
    Target/AMDGPU  -o AMDGPUGenPreLegalizeGICombiner.inc /usr/src/gnu/usr.bin/clang/include/llvm/AMDGPU/../../../../../llvm/llvm/lib/Target/AMDGPU/AMDGPUGISel.td
    Allocation failed
    hlcs#
    Or with one thread (and /usr/bin/time -l):
    hlcs# /usr/bin/time -l make build
    Allocation failed
         2451.30 real      1663.10 user       540.88 sys
       1506160  maximum resident set size
         64664  average shared memory size
         38558  average unshared data size
           112  average unshared stack size
     159380599  minor page faults
        316406  major page faults
             0  swaps
          8590  block input operations
        446758  block output operations
             0  messages sent
            20  messages received
         78391  signals received
       1382205  voluntary context switches
          7150  involuntary context switches
    hlcs#
    What am I missing? Thanks! <3
    edited June 30
    Trying, without tmux,
    hlcs# date
    Mon Jun 30 00:46:13 UTC 2025
    hlcs# w
    12:46AM  up 1 day,  2:08, 1 user, load averages: 0.05, 0.03, 0.00
    USER    TTY FROM              LOGIN@  IDLE WHAT
    root     p0 xxx.xxx.xxx.xxx  12:46AM     0 w
    hlcs# cd /usr/src
    hlcs# ulimit -d 25165824
    I will post again to let you know what happens. . . . Thanks! <3
    Nope! :)
    Allocation failed
         2451.85 real      1663.40 user       540.36 sys
       1506228  maximum resident set size
         64701  average shared memory size
         38481  average unshared data size
     159430126  minor page faults
        316512  major page faults
             0  swaps
        446750  block output operations
             0  messages sent
         78392  signals received
       1377363  voluntary context switches
          7186  involuntary context switches
    hlcs#
  • edited June 30
    @Not_Oles said: What am I missing? Thanks!
    Sorry, I meant that just running that llvm-tblgen from the command line worked (but it doesn't seem to work when being run using make) - and I have no idea either why we are seeing that difference.
    Just having a look at what make build actually does:
    hlcs# make -n build
    hlcs# make -n do-build
    cd /usr/src/share/mk && exec make install
    exec make cleandir
    exec make includes
    cd /usr/src/lib &&  su build -c 'exec make' &&  NOMAN=1 exec make install
    /sbin/ldconfig -R
    cd /usr/src/gnu/lib &&  su build -c 'exec make' &&  NOMAN=1 exec make install
    /sbin/ldconfig -R
    su build -c 'exec make' &&  exec make install
    /bin/sh /usr/src/distrib/sets/makeetcset /usr/src make
    So it's not actually using the ulimit set in the root shell, but the one it gets for the build user - and that user has the default datasize-max=1536M and datasize-cur=1536M.
    There is an entry for build in /etc/login.conf:
    # Building LLVM in base requires higher limits
    build:\
            :datasize-max=1843M:\
            :datasize-cur=1843M:\
            :tc=default:
    But the build user doesn't use that login class:
    build:*:21:21::0:0:base and xenocara build:/var/empty:/bin/ksh
    @cmeerw Okay, that's all right! Thanks for taking a little dive into OpenBSD with me! <3
    Do you want to stick with the present OpenBSD / Debian dual boot install?
    Might there be something else that you want to run on hlcs?
    Any other LESbians want to try? It's free! Please review "How To Apply" in the OP.
    Thanks to @Hosteroid for our fun Community server! <3
  • @cmeerw said: But the build user doesn't use that login class:
    I have set the login class for the build user to build now and restarted a make build
    @Not_Oles said: Do you want to stick with the present OpenBSD / Debian dual boot install?
    At least we should get the OpenBSD build done before switching to anything else.
