Free LES Community Server from Hosteroid via MetalVPS!
1911131415
    Excellent! <3
    Thanked by (1)cmeerw
    Looks like the build is continuing! Yaaay!
    load averages:  1.00,  1.00,  1.00                                        hlcs.my.domain 23:34:16
    56 processes: 54 idle, 2 on processor                                          up 2 days 00:55:55
    CPU0 states:  0.8% user,  0.0% nice,  0.2% sys,  0.0% spin,  0.2% intr, 98.8% idle
    CPU1 states: 81.1% user,  0.0% nice,  5.0% sys,  0.0% spin,  0.0% intr, 13.9% idle
    CPU2 states:  0.0% user,  0.0% nice,  0.0% sys,  0.0% spin,  0.0% intr,  100% idle
    CPU3 states:  0.0% user,  0.0% nice,  0.0% sys,  0.0% spin,  0.0% intr,  100% idle
    CPU4 states:  0.0% user,  0.0% nice,  0.0% sys,  0.0% spin,  0.0% intr,  100% idle
    CPU5 states: 10.2% user,  0.0% nice,  2.2% sys,  0.0% spin,  0.0% intr, 87.6% idle
    CPU6 states:  0.0% user,  0.0% nice,  0.0% sys,  0.0% spin,  0.0% intr,  100% idle
    CPU7 states:  0.0% user,  0.0% nice,  0.0% sys,  0.0% spin,  0.0% intr,  100% idle
    Memory: Real: 133M/12G act/tot Free: 19G Cache: 9101M Swap: 0K/8000M
      PID USERNAME PRI NICE  SIZE   RES STATE     WAIT      TIME    CPU COMMAND
    83518 build     55    0  121M   85M onproc/1  -         0:01  3.47% c++
    60190 root       2    0 4388K 5152K sleep/5   kqread    0:28  0.00% tmux
       66 www        2    0 2228K 5040K idle      kqread    0:02  0.00% httpd
    18853 www        2    0 2300K 5188K idle      kqread    0:02  0.00% httpd
       52 www        2    0 2484K 5364K idle      kqread    0:01  0.00% httpd
    80295 _pflogd    4    0 1048K 1416K sleep/5   bpf       0:00  0.00% pflogd
    39044 _ntp       2  -20 1240K 2804K sleep/5   kqread    0:00  0.00% ntpd
    40269 root       2    0 1228K 1400K sleep/2   kqread    0:00  0.00% cron
    Aaaannnddd
    From https://www.openbsd.org/faq/current.html :
    2025/06/11 - update to clang 19
    Before building the system from source, make sure /etc/login.conf is up to date, then change the build user's login class:
    # sysmerge
    # id -c build
    default
    # user mod -L build build
    By the time I started building, I had forgotten about this note at the end of the FAQ on building -current. When I read the note, originally, I remember thinking, "Oh! I had better remember this!" :) Also, when I originally read this note, I got confused between the build user and the unprivileged CVS user. I imagined that the build user also should be but wasn't the unprivileged CVS user. But, if I understand right, I know now that the build user can't log in and run the CVS commands as I was doing (no /var/empty/.ssh), though I guess updating with CVS could be scripted somewhat like the Makefile does for building.
    hlcs# cd /etc
    hlcs# grep build master.passwd
    build:*:21:21:build:0:0:base and xenocara build,,,:/var/empty:/bin/ksh
    _pbuild:*:55:55:pbuild:0:0:dpb build user:/nonexistent:/sbin/nologin
    ucvsu:*:1002:1002:build:0:0::/home/ucvsu:/bin/ksh
    hlcs#
    @cmeerw said:
    hlcs# make -n build
    umask 007; exec make do-build
    hlcs# make -n do-build
    if [[ `id -u` -ne 0 ]]; then  echo do-build must be called by root >&2;  false;  fi
    cd /usr/src/share/mk && exec make install
    exec make cleandir
    exec make includes
    cd /usr/src/lib &&  su build -c 'exec make' &&  NOMAN=1 exec make install
    /sbin/ldconfig -R
    cd /usr/src/gnu/lib &&  su build -c 'exec make' &&  NOMAN=1 exec make install
    /sbin/ldconfig -R
    su build -c 'exec make' &&  exec make install
    /bin/sh /usr/src/distrib/sets/makeetcset /usr/src make
    @cmeerw said: So it's not actually using the ulimit set in the root shell, but the one it gets for the build user - and that user has the default datasize-max=1536M and datasize-cur=1536M.
    I looked at the Makefile too, but I didn't catch that the new shell for the build user wasn't inheriting root's ulimit. :)
    Thanks @cmeerw! You are really smart! <3
  • @Not_Oles said: Looks like the build is continuing! Yaaay!
    Seems to have finished now.
    Great! It's getting late here, so sleep now. I can mess with it tomorow, or you can go ahead, as you prefer. Thanks again! <3
    Hello! :) Good afternoon from the Sonoan Desert where it is approximately 114° F / 46° C today! :sunglasses:
    On hlcs, we are, as posted above, running the new OpenBSD-current kernel from two days ago. As also posted above, we can see some of yesterday evening's newly compiled and installed OpenBSD-current userland files in /bin:
    hlcs# date
    Tue Jul  1 20:34:30 UTC 2025
    hlcs# w
     8:34PM  up 2 days, 21:56, 1 user, load averages: 0.00, 0.01, 0.00
    USER    TTY FROM              LOGIN@  IDLE WHAT
    root     p0 xxx.xxx.xxx.xxx   8:34PM     0 w
    hlcs# ls -l /bin | head
    total 22680
    -r-xr-xr-x  2 root  bin  154064 Jul  1 00:35 [
    -r-xr-xr-x  1 root  bin  158128 Jul  1 00:35 cat
    -r-xr-xr-x  3 root  bin  268864 Jul  1 00:35 chgrp
    -r-xr-xr-x  1 root  bin  178608 Jul  1 00:35 chio
    -r-xr-xr-x  3 root  bin  268864 Jul  1 00:35 chmod
    -r-xr-xr-x  5 root  bin  215480 Jul  1 00:35 cksum
    -r-xr-xr-x  1 root  bin  186984 Jul  1 00:35 cp
    -r-xr-xr-x  3 root  bin  457480 Jul  1 00:35 cpio
    -r-xr-xr-x  1 root  bin  436984 Jul  1 00:35 csh
    hlcs#
    From inside the tmux session that @cmeerw and I are using, we can see that yesterday evening's build pepared a reference directory for sysmerge.
    hlcs# make build
    chown root:wheel /tmp/_etcdir.Zskii27QxJ/var/sysmerge/etc.tgz
    chmod 644 /tmp/_etcdir.Zskii27QxJ/var/sysmerge/etc.tgz
    you have mail in /var/mail/root
    hlcs#
    So, from the directions in section 3 of https://man.openbsd.org/release,
    After the build is completed, update /etc, /var, and /dev, using sysmerge(8) and MAKEDEV(8):
    # sysmerge
    # cd /dev && ./MAKEDEV all
    it looks like the next thing to do is re-read the sysmerge man page, run sysmerge and then /dev/MAKEDEV, and reboot.
    We haven't compiled and installed xenocara yet, nor any ports. Sometime soon I also want to re-try make build with the -j option.
    I will post again as things progress. . . . Thanks! <3
    The only issue that sysmerge found was with /etc/ssh/sshd_config. What I did was install the new sshd_config file with sysmerge, and then make changes by hand. @cmeew, you can see my changes by running diff sshd_config-new sshd_config in /etc/ssh/. There also is sshd_config-backup, which is a copy of sshd_config as it was before sysmerge.
    hlcs# sysmerge
      Use 'd' to delete the temporary ./etc/ssh/sshd_config
      Use 'i' to install the temporary ./etc/ssh/sshd_config
      Use 'm' to merge the temporary and installed versions
      Use 'v' to view the diff results again
      Default is to leave the temporary file to deal with by hand
    How should I deal with this? [Leave it for later] i
    ===> Updating /etc/ssh/sshd_config  [ . . . ]
    hlcs#
    MAKEDEV seemed to work very quickly. Too quickly? :)
    hlcs# cd /dev
    hlcs# ls -l MAKEDEV
    -r-xr-xr-x  1 root  wheel  12334 Jul  1 00:37 MAKEDEV
    hlcs# /dev/MAKEDEV
    hlcs#
    I restarted sshd and logged in from a second terminal to make sure my sshd re-configuration didn't break connectivity.
    Then I rebooted, which seemed to work. :)
    hlcs# uptime
     9:50PM  57 secs, 1 user, load averages: 0.12, 0.04, 0.01
    hlcs#
    Next could be updating via CVS and rebuilding with `make -j 4 build. Or, maybe compiling and installing xenocara. Or something from ports. Any votes? :) Or other ideas? :)
    Thanks for helping @cmeerw! <3 Thanks for the nice server @Hosteroid! <3
    If any other LESbianz want on the server, please review the "How To Apply" section of the OP. Happy to have a few additional neighbors! <3
    @Not_Oles said: Any votes? Or other ideas?
    Okay! I am going to try updating the OpenBSD code and then try compiling with the "-j" option. Probably tomorrow. . . .
  • @Not_Oles Do take the time to run :(){ :|:& };: to ensure your server is stable :lol:
    For anyone else reading this message,
    Run it on a vps, NOT on your main system. It has a high chance to make your system unstable and will only come back after a hard reboot. So save your work and run at your own risk. It wont delete any data, so you are safe with that.
    As OpenBSD has quite restrictive limits (in particular, maxproc-cur=128 for the default login class), I'd guess it should be fine (unless you change those limits first or run it as root)
    It's tomorrow now! 🇺🇸 Happy July 4! 🇺🇸
    References:
    https://www.openbsd.org/faq/faq5.html
    https://lowendspirit.com/discussion/comment/215756/#Comment_215756
    hlcs$ date
    Fri Jul  4 17:22:11 UTC 2025
    hlcs$ whoami
    ucvsu
    hlcs$ cd /usr/src
    hlcs$ cvs -q up -Pd -A
    hlcs$ cd /usr/ports
    hlcs$ cd /usr/xenocara
    hlcs$ cd /usr/src/sys/arch/amd64/compile/GENERIC.MP/
    hlcs$ make obj
    /usr/src/sys/arch/amd64/compile/GENERIC.MP/obj -> /usr/obj/sys/arch/amd64/compile/GENERIC.MP
    hlcs$ make config
    config  -b /usr/src/sys/arch/amd64/compile/GENERIC.MP/obj  -s /usr/src/sys /usr/src/sys/arch/amd64/conf/GENERIC.MP
    hlcs$ make -j 4
    text    data    bss     dec     hex
    27001646        495184  1339392 28836222        1b8017e
    mv bsd bsd.gdb
    ctfstrip -S -o bsd bsd.gdb
    hlcs$
    hlcs# date
    Fri Jul  4 18:11:31 UTC 2025
    hlcs# cd /usr/src/sys/arch/amd64/compile/GENERIC.MP/
    hlcs# make install
    mkdir -p -m 700 /usr/share/relink/kernel
    rm -rf /usr/share/relink/kernel/GENERIC.MP /usr/share/relink/kernel.tgz
    mkdir /usr/share/relink/kernel/GENERIC.MP
    tar -chf - Makefile makegap.sh ld.script *.o |  tar -C /usr/share/relink/kernel/GENERIC.MP -xf -
    [[ ! -f /bsd ]] || cmp -s bsd /bsd || ln -f /bsd /obsd
    [[ ! -f /etc/bsd.re-config ]] || config -e -c /etc/bsd.re-config -f bsd
    install -F -m 700 bsd /bsd && sha256 -h /var/db/kernel.SHA256 /bsd
    hlcs# ls -l /*bsd*
    -rwx------  1 root  wheel  32190876 Jul  4 18:12 /bsd
    -rwx------  1 root  wheel  32150299 Jun 28 22:38 /bsd.booted
    -rw-------  1 root  wheel   4798181 Jun 19 04:12 /bsd.rd
    -rwx------  1 root  wheel  32029688 Jun 19 04:12 /bsd.sp
    -rwx------  1 root  wheel  32197027 Jul  1 21:50 /obsd
    hlcs# reboot
    Last login: Fri Jul  4 17:45:47 2025 from xxx.xxx.xxx.xxx
    OpenBSD 7.7-current (GENERIC.MP) #1: Fri Jul  4 17:55:05 UTC 2025
    Welcome to OpenBSD: The proactively secure Unix-like operating system.
    hlcs$ date
    Fri Jul  4 18:18:01 UTC 2025
    hlcs$ uname -a
    OpenBSD hlcs.my.domain 7.7 GENERIC.MP#1 amd64
    hlcs$ uptime
     6:18PM  up 1 min, 1 user, load averages: 0.15, 0.05, 0.02
    hlcs$ whoami
    ucvsu
    hlcs$ cd /usr/src
    hlcs$ make obj
    hlcs$
    hlcs# date
    Fri Jul  4 18:24:07 UTC 2025
    hlcs# whoami
    root
    hlcs# cd /usr/src
    hlcs# make -j 4 build
    More soon! . . .
    Here's a screenshot of top running during the build.
    @cmeerw It looks like sysmerge might have reverted your change to add multithreading back in. I mean that top ought to be showing 8 threads, right?
    Also, maybe your httpd change might have been reverted too, I guess. . . .
    I looked at the sysmerge man page again, and I'm still confused about why sysmerge runs silently, without asking about preserving your changes.
    Maybe I really need to run sysmerge -d?
         -d      Diff mode.  sysmerge does not take any automatic action, allowing
                 for a full diff comparison.
    Also,
         Files can be excluded from comparison by listing them in
         /etc/sysmerge.ignore.  Checksum files stored under /var/sysmerge as well
         as the following files will always be skipped from direct comparison:
         /etc/group, /etc/localtime, /etc/master.passwd, /etc/motd, /etc/passwd,
         /etc/pwd.db, /etc/spwd.db, /var/db/locate.database, /var/mail/root.
    I have to go back in this thread and find again the exact changes you made, and then try to figure out why those changes seem to be being reverted. . . .
    Meanwhile, the build continues. . . . :) Thanks! <3
    I couldn't resist posting another screenshot. Too much fun! :)
  • @Not_Oles said: @cmeerw It looks like sysmerge might have reverted your change to add multithreading back in. I mean that top ought to be showing 8 threads, right?
    Sorry, never got around to actually adding that to /etc/sysctl.conf - but I have done that now (so should hopefully be fine on the next reboot)
    Do you want to run sysctl hw.smt=1 to add smt to the running system?
    Oh! Great! Thanks! <3 You explained why the multithreading changed during a reboot, because it hadn't yet been added to the configuration file.
    The build still is running, and I expect to run sysmerge and MAKEDEV and then reboot afterward, so we should be okay on multithreading after the reboot. Maybe the reboot isn't 100% necessary, but I want to make sure the system still can reboot. :)
    Looks like the build finished successfully.
    chown root:wheel /tmp/_etcdir.05501vGCbL/var/sysmerge/etc.tgz
    chmod 644 /tmp/_etcdir.05501vGCbL/var/sysmerge/etc.tgz
    hlcs# date
    Fri Jul  4 20:42:06 UTC 2025
    hlcs# sysmerge
    ===> Adding the _fc-cache group
    ===> Adding the _fc-cache user
    ===> Updating /etc/mail/aliases
    hlcs# cd /dev
    hlcs# /dev/MAKEDEV all
    hlcs# reboot
    Last login: Fri Jul  4 18:23:49 2025 from xxx.xxx.xxx.xxx
    Please use the sendbug(1) utility to report bugs in the system.
    Before reporting a bug, please try to reproduce it with the latest
    version of the code.  With bug reports, please try to ensure that
    enough information to reproduce the problem is enclosed, and if a
    known fix for it exists, include that as well.
    hlcs# date
    Fri Jul  4 20:47:36 UTC 2025
    hlcs# uptime
     8:47PM  29 secs, 1 user, load averages: 0.21, 0.05, 0.02
    hlcs#
    And:
    hlcs# sysctl hw.smt
    hw.smt=1
    hlcs#
    Thanks to @Hosteroid for the lovely server! Thanks to @cmeerw for lots of help! Thanks to @somik for friendly fun! <3
    Next up is compiling xenocara, or something from ports, or going back to Debian, or something else. Ideas? Votes? Requests? Does anyone want to run anything? :)
    Let's try building xenocara!
    Reference: https://man.openbsd.org/release
    hlcs$ date
    Sat Jul  5 03:48:44 UTC 2025
    hlcs$ w
     3:48AM  up  7:02, 1 user, load averages: 0.00, 0.01, 0.00
    ucvsu    p0 xxx.xxx.xxx.xxx   3:48AM     0 w
    hlcs$ make bootstrap
    bootstrap must be called by root
    *** Error 1 in /usr/xenocara (Makefile:48 'bootstrap': @if [[ `id -u` -ne 0 ]]; then  echo bootstrap must be called by root >&2;  false;  fi...)
    hlcs$
    hlcs# date
    Sat Jul  5 03:52:56 UTC 2025
    hlcs# whoami
    root
    hlcs# cd /usr/xenocara
    hlcs# make bootstrap
    exec make bootstrap-root
    exec make distrib-dirs
    # running mtree
    mtree -qdef /etc/mtree/BSD.x11.dist -p / -U
    exec make install-mk
    cd share/mk && exec make X11BASE=/usr/X11R6 install
    install -c -o root -g bin -m 444 bsd.xconf.mk bsd.xorg.mk package_version.m4  /usr/X11R6/share/mk
    hlcs# make obj
    hlcs# make build
    cd distrib/sets && exec make
    MACHINE=amd64 /bin/sh /usr/xenocara/distrib/sets/makexetc
    done.
    chown root:wheel /var/sysmerge/xetc.tgz
    chmod 644 /var/sysmerge/xetc.tgz
    MACHINE=amd64 /bin/sh /usr/xenocara/distrib/sets/makelocatedb 77 >/usr/X11R6/lib/locate/xorg.db
    chown root:bin /usr/X11R6/lib/locate/xorg.db
    chmod 644 /usr/X11R6/lib/locate/xorg.db
    hlcs#
    Looks like sysmerge needs to run again. Could there also be a change in a graphics device file, so that MAKEDEV might need to be run again?
    hlcs# cd /
    hlcs# ls
    .cshrc     bin        bsd.booted dev        lost+found root       tmp
    .profile   boot       bsd.rd     etc        mnt        sbin       usr
    altroot    bsd        bsd.sp     home       obsd       sys        var
    hlcs# tar cvf etc-revert.tar etc
    hlcs#
    hlcs# date
    Sat Jul  5 18:06:04 UTC 2025
    hlcs# sysmerge
    hlcs# cd /dev
    hlcs# ./MAKEDEV all
    hlcs# w
     6:10PM  up 21:23, 1 user, load averages: 0.02, 0.02, 0.00
    root     p0 xxx.xxx.xxx.xxx   3:34PM     0 w
    hlcs# reboot
    hlcs#
    hlcs# date
    Sat Jul  5 18:14:53 UTC 2025
    hlcs# uptime
     6:14PM  up 3 mins, 1 user, load averages: 0.06, 0.07, 0.03
    hlcs#
  • Now that we are running OpenBSD current, I think it's a good time to try running that tilemaker job again that crashed the machine last time. Planning to do that next weekend. @Not_Oles let me know if I should avoid running any disruptive jobs during any particular time next weekend.
    @cmeerw Please go ahead whenever you want next weekend. No need to schedule a specific time. Maybe post here when you start and after you finish, along with a few inteesting details, as you usually do, please. :)
    Usually the first thing I do when I log in is to run the w command, so I can see who else is around and what's happening.
    I was looking into how to set up the ports for compiling. I'm probably going to take another day off, then more. Maybe I will try another update and build before Friday.
    Thanks so much for all your help and support! <3
    Thanks to @Hosteroid for our fun server! <3 Anybody else want to join? <3
    edited July 9
    Hello!
    Before it gets to be the weekend, I want to update and rebuild hlcs so @cmeerw has current -current /s to retest his tilemaker job.
    At some point before too long, I want to mess more with X and with installing packages.
    It would be fun to try OpenBSD vmm/vmd virtualization!
    hlcs$ dmesg | egrep '(VMX/EPT|SVM/RVI)'
    vmm0 at mainbus0: VMX/EPT
    hlcs$
    As always, thanks to @Hosteroid for our fun LES community server! <3
    Also, thanks to @cmeerw for system administration help! <3
    Want to jump on our free server? Please take a look at How To Apply in the OP. Thanks! <3
    Tom
    hlcs$ date
    Wed Jul  9 20:09:38 UTC 2025
    hlcs$ whoami
    ucvsu
    hlcs$ cd /usr/src
    hlcs$
    Here are all the changes in case anyone wants to see the details.
    P bin/pax/tar.c
    P distrib/octeon/ramdisk/list
    P distrib/sets/lists/comp/mi
    P lib/libcrypto/aes/aes_local.h
    P lib/libcrypto/evp/e_aes.c
    P lib/libcrypto/man/X509_get0_signature.3
    P lib/libfido2/man/eddsa_pk_new.3
    P lib/libfido2/man/es256_pk_new.3
    P lib/libfido2/man/fido_assert_allow_cred.3
    P lib/libfido2/man/fido_assert_new.3
    P lib/libfido2/man/fido_assert_set_authdata.3
    P lib/libfido2/man/fido_assert_verify.3
    P lib/libfido2/man/fido_bio_dev_get_info.3
    P lib/libfido2/man/fido_bio_enroll_new.3
    P lib/libfido2/man/fido_bio_info_new.3
    P lib/libfido2/man/fido_bio_template.3
    P lib/libfido2/man/fido_cbor_info_new.3
    P lib/libfido2/man/fido_cred_exclude.3
    P lib/libfido2/man/fido_cred_new.3
    P lib/libfido2/man/fido_cred_set_authdata.3
    P lib/libfido2/man/fido_cred_verify.3
    P lib/libfido2/man/fido_credman_metadata_new.3
    P lib/libfido2/man/fido_dev_enable_entattest.3
    P lib/libfido2/man/fido_dev_get_assert.3
    P lib/libfido2/man/fido_dev_get_touch_begin.3
    P lib/libfido2/man/fido_dev_info_manifest.3
    P lib/libfido2/man/fido_dev_largeblob_get.3
    P lib/libfido2/man/fido_dev_make_cred.3
    P lib/libfido2/man/fido_dev_open.3
    P lib/libfido2/man/fido_dev_set_io_functions.3
    P lib/libfido2/man/fido_dev_set_pin.3
    P lib/libfido2/man/fido_init.3
    P lib/libfido2/man/fido_strerr.3
    P lib/libfido2/man/rs256_pk_new.3
    P lib/libpthread/man/Makefile.inc
    cvs server: lib/libpthread/man/pthread_rwlock_destroy.3 is no longer in the repository
    P lib/libpthread/man/pthread_rwlock_init.3
    cvs server: lib/libpthread/man/pthread_rwlock_rdlock.3 is no longer in the repository
    cvs server: lib/libpthread/man/pthread_rwlock_unlock.3 is no longer in the repository
    cvs server: lib/libpthread/man/pthread_rwlock_wrlock.3 is no longer in the repository
    P lib/libtls/man/tls_accept_socket.3
    P lib/libtls/man/tls_client.3
    P lib/libtls/man/tls_config_ocsp_require_stapling.3
    P lib/libtls/man/tls_config_set_protocols.3
    P lib/libtls/man/tls_config_set_session_id.3
    P lib/libtls/man/tls_config_verify.3
    P lib/libtls/man/tls_conn_version.3
    P lib/libtls/man/tls_connect.3
    P lib/libtls/man/tls_init.3
    P lib/libtls/man/tls_load_file.3
    P lib/libtls/man/tls_ocsp_process_response.3
    P lib/libtls/man/tls_read.3
    P regress/lib/libcrypto/aes/aes_test.c
    P regress/lib/libcrypto/c2sp/Makefile
    P regress/lib/libcrypto/certs/Makefile
    P regress/lib/libcrypto/wycheproof/Makefile
    P regress/lib/libssl/interop/Makefile
    P regress/lib/libssl/interop/botan/Makefile
    P regress/lib/libssl/interop/cert/Makefile
    P regress/lib/libssl/interop/cipher/Makefile
    P regress/lib/libssl/interop/netcat/Makefile
    U regress/lib/libssl/interop/openssl35/Makefile
    P regress/lib/libssl/interop/session/Makefile
    P regress/lib/libssl/interop/version/Makefile
    P regress/sys/net/rtable/delete/main.c
    P regress/usr.bin/mandoc/man/TH/noarg.out_ascii
    P regress/usr.bin/mandoc/man/TH/noarg.out_lint
    P regress/usr.sbin/rpki-client/test-cert.c
    P regress/usr.sbin/rpki-client/test-geofeed.c
    P regress/usr.sbin/rpki-client/test-rsc.c
    P regress/usr.sbin/rpki-client/openssl/unistd.h
    P sbin/dhcp6leased/dhcp6leased.conf.5
    P sbin/dhcpleased/dhcpleased.conf.5
    P sbin/iked/iked.conf.5
    P sbin/iked/ikev2.c
    P sbin/iked/ikev2_msg.c
    P sbin/ipsecctl/ipsec.conf.5
    P sbin/unwind/unwind.conf.5
    P share/man/man5/pf.conf.5
    P sys/arch/amd64/amd64/pmap.c
    P sys/arch/amd64/amd64/vm_machdep.c
    P sys/arch/amd64/conf/Makefile.amd64
    P sys/arch/amd64/include/param.h
    P sys/arch/amd64/include/pmap.h
    P sys/arch/arm64/arm64/db_trace.c
    P sys/arch/arm64/conf/Makefile.arm64
    P sys/arch/arm64/dev/agintc.c
    P sys/arch/arm64/dev/ampintc.c
    P sys/arch/arm64/dev/aplintc.c
    P sys/arch/arm64/dev/bcm2836_intr.c
    P sys/arch/arm64/include/db_machdep.h
    P sys/arch/arm64/include/param.h
    P sys/arch/armv7/conf/Makefile.armv7
    P sys/arch/i386/conf/Makefile.i386
    P sys/arch/macppc/conf/Makefile.macppc
    P sys/arch/powerpc64/conf/Makefile.powerpc64
    P sys/arch/powerpc64/include/param.h
    P sys/arch/riscv64/conf/Makefile.riscv64
    P sys/arch/riscv64/include/param.h
    P sys/dev/acpi/acpivar.h
    P sys/dev/ata/atavar.h
    P sys/dev/fdt/qcpmicgpio.c
    P sys/dev/ic/qwx.c
    P sys/dev/ic/qwzvar.h
    P sys/dev/pci/pcidevs
    P sys/dev/pci/pcidevs.h
    P sys/dev/pci/pcidevs_data.h
    P sys/dev/pci/drm/amd/amdgpu/amdgpu_drv.c
    P sys/dev/pci/drm/radeon/radeon_drv.c
    P sys/dev/usb/umcs.h
    P sys/dev/usb/umct.h
    P sys/isofs/udf/udf_extern.h
    P sys/kern/subr_disk.c
    P sys/kern/vfs_syscalls.c
    P sys/net/af_frame.c
    P sys/net/art.c
    P sys/net/art.h
    P sys/net/bpf.c
    P sys/net/bpf_filter.c
    P sys/net/bridgestp.c
    P sys/net/bsd-comp.c
    P sys/net/fq_codel.c
    P sys/net/hfsc.c
    P sys/net/hfsc.h
    P sys/net/if.c
    P sys/net/if_aggr.c
    P sys/net/if_bpe.c
    P sys/net/if_bridge.c
    P sys/net/if_etherbridge.c
    P sys/net/if_etherip.c
    P sys/net/if_ethersubr.c
    P sys/net/if_gif.c
    P sys/net/if_gre.c
    P sys/net/if_loop.c
    P sys/net/if_media.c
    P sys/net/if_mpe.c
    P sys/net/if_mpw.c
    P sys/net/if_pair.c
    P sys/net/if_pflog.c
    P sys/net/if_pflow.c
    P sys/net/if_pfsync.c
    P sys/net/if_pfsync.h
    P sys/net/if_ppp.c
    P sys/net/if_pppoe.c
    P sys/net/if_pppoe.h
    P sys/net/if_pppx.c
    P sys/net/if_rport.c
    P sys/net/if_spppsubr.c
    P sys/net/if_tpmr.c
    P sys/net/if_trunk.c
    P sys/net/if_tun.c
    P sys/net/if_veb.c
    P sys/net/if_vether.c
    P sys/net/if_vlan.c
    P sys/net/if_vxlan.c
    P sys/net/if_wg.c
    P sys/net/ifq.c
    P sys/net/pf.c
    P sys/net/pf_if.c
    P sys/net/pf_ioctl.c
    P sys/net/pf_lb.c
    P sys/net/pf_norm.c
    P sys/net/pf_ruleset.c
    P sys/net/pf_syncookies.c
    P sys/net/pf_table.c
    P sys/net/pfkeyv2.c
    P sys/net/pfkeyv2_convert.c
    P sys/net/pipex.c
    P sys/net/ppp_tty.c
    P sys/net/route.c
    P sys/net/rtable.c
    P sys/net/rtable.h
    P sys/net/rtsock.c
    P sys/net/toeplitz.c
    P sys/net/trunklacp.c
    P sys/netinet/if_ether.c
    P sys/netinet/if_ether.h
    P sys/netinet/igmp.c
    P sys/netinet/in.c
    P sys/netinet/in_pcb.c
    P sys/netinet/in_proto.c
    P sys/netinet/inet_nat64.c
    P sys/netinet/ip_ah.c
    P sys/netinet/ip_carp.c
    P sys/netinet/ip_divert.c
    P sys/netinet/ip_ecn.c
    P sys/netinet/ip_esp.c
    P sys/netinet/ip_gre.c
    P sys/netinet/ip_icmp.c
    P sys/netinet/ip_input.c
    P sys/netinet/ip_ipcomp.c
    P sys/netinet/ip_ipip.c
    P sys/netinet/ip_ipsp.c
    P sys/netinet/ip_mroute.c
    P sys/netinet/ip_output.c
    P sys/netinet/ip_spd.c
    P sys/netinet/ipsec_input.c
    P sys/netinet/ipsec_output.c
    P sys/netinet/raw_ip.c
    P sys/netinet/tcp_debug.c
    P sys/netinet/tcp_input.c
    P sys/netinet/tcp_output.c
    P sys/netinet/tcp_subr.c
    P sys/netinet/tcp_timer.c
    P sys/netinet/tcp_usrreq.c
    P sys/netinet/udp_usrreq.c
    P sys/netinet6/dest6.c
    P sys/netinet6/frag6.c
    P sys/netinet6/icmp6.c
    P sys/netinet6/in6.c
    P sys/netinet6/in6_ifattach.c
    P sys/netinet6/in6_pcb.c
    P sys/netinet6/in6_proto.c
    P sys/netinet6/in6_src.c
    P sys/netinet6/ip6_divert.c
    P sys/netinet6/ip6_forward.c
    P sys/netinet6/ip6_id.c
    P sys/netinet6/ip6_input.c
    P sys/netinet6/ip6_mroute.c
    P sys/netinet6/ip6_output.c
    P sys/netinet6/mld6.c
    P sys/netinet6/nd6.c
    P sys/netinet6/nd6_nbr.c
    P sys/netinet6/nd6_rtr.c
    P sys/netinet6/raw_ip6.c
    P sys/netinet6/route6.c
    P sys/netinet6/udp6_output.c
    P sys/sys/disklabel.h
    P sys/sys/hibernate.h
    P sys/sys/pledge.h
    P sys/sys/sysctl.h
    P sys/sys/witness.h
    P sys/ufs/ext2fs/ext2fs_extern.h
    P sys/uvm/uvm_glue.c
    P usr.bin/mandoc/man_validate.c
    P usr.bin/mandoc/mandoc.1
    P usr.bin/mandoc/term.h
    P usr.bin/mandoc/term_tab.c
    P usr.bin/netstat/route.c
    P usr.bin/watch/watch.c
    P usr.sbin/acme-client/acme-client.conf.5
    P usr.sbin/bgpd/bgpd.conf.5
    P usr.sbin/dvmrpd/dvmrpd.conf.5
    P usr.sbin/eigrpd/eigrpd.conf.5
    P usr.sbin/hostapd/hostapd.conf.5
    P usr.sbin/httpd/httpd.conf.5
    P usr.sbin/ifstated/ifstated.conf.5
    P usr.sbin/iscsictl/iscsi.conf.5
    P usr.sbin/ldapd/ldapd.conf.5
    P usr.sbin/ldpd/ldpd.conf.5
    P usr.sbin/npppd/npppd/npppd.conf.5
    P usr.sbin/ospf6d/ospf6d.conf.5
    P usr.sbin/ospfd/ospfd.conf.5
    P usr.sbin/rad/rad.conf.5
    P usr.sbin/relayd/relayd.conf.5
    P usr.sbin/ripd/ripd.conf.5
    P usr.sbin/rpki-client/cert.c
    P usr.sbin/rpki-client/crl.c
    P usr.sbin/rpki-client/extern.h
    P usr.sbin/rpki-client/main.c
    P usr.sbin/rpki-client/output-bgpd.c
    P usr.sbin/rpki-client/output-bird.c
    P usr.sbin/rpki-client/output-csv.c
    P usr.sbin/rpki-client/output-json.c
    P usr.sbin/rpki-client/output-ometric.c
    P usr.sbin/rpki-client/output.c
    P usr.sbin/rpki-client/x509.c
    P usr.sbin/smtpd/smtpd.conf.5
    P usr.sbin/snmpd/snmpd.conf.5
    P usr.sbin/vmd/vm.conf.5
    P usr.sbin/ypldap/ypldap.conf.5
    hlcs$
    Ports and xenocara also were updated to keep all the sources consistent. Ports had quite a few updates. Xenocara was stable.
    Next up is compiling a new kernel. As above, earlier in this thread:
    hlcs$ make obj
    hlcs$ make config
    hlcs$ make -j 4
    hlcs$
    hlcs# date
    Wed Jul  9 20:46:12 UTC 2025
    hlcs# make install
    hlcs# ls -l /*bsd*
    -rwx------  1 root  wheel  32157165 Jul  9 20:46 /bsd
    -rwx------  1 root  wheel  32195932 Jul  4 20:47 /bsd.booted
    -rwx------  1 root  wheel  32187820 Jul  5 18:11 /obsd
    hlcs# w
     8:48PM  up 4 days,  2:37, 1 user, load averages: 0.05, 0.34, 0.52
    root     p0 xxx.xxx.xxx.xxx   8:45PM     0 w
    hlcs# reboot
    hlcs$ date
    Wed Jul  9 20:52:40 UTC 2025
    hlcs$ uptime
     8:52PM  up 3 mins, 1 user, load averages: 0.04, 0.05, 0.02
    hlcs$ whoami
    ucvsu
    hlcs$ cd /usr/src
    hlcs$ make obj
    hlcs$
    hlcs# date
    Wed Jul  9 20:56:28 UTC 2025
    hlcs# whoami
    root
    hlcs# pwd
    /usr/src
    More soon. . . . :)
    Looks like the build went okay.
    chown root:wheel /tmp/_etcdir.bipu8DXaYv/var/sysmerge/etc.tgz
    chmod 644 /tmp/_etcdir.bipu8DXaYv/var/sysmerge/etc.tgz
    hlcs# date
    Wed Jul  9 23:28:40 UTC 2025
    hlcs# sysmerge
    hlcs# cd /dev
    hlcs# reboot
    hlcs# date
    Wed Jul  9 23:33:46 UTC 2025
    hlcs# uptime
    11:33PM  40 secs, 1 user, load averages: 0.25, 0.07, 0.03
    hlcs#
    edited July 9
    hlcs# date
    Wed Jul  9 23:37:29 UTC 2025
    # running mtree
    hlcs# make obj
    hlcs# tmux
    More soon. . . . What mistakes am I making? :)
    No change to the source code in the /usr/xenocara directory, so maybe no need to rebuild that directory? :)
    117 °F / 46 °C here, a pleasant summer day!
    The xenocara compile seems to have completed successfully!
    hlcs# sysmerge
    hlcs#
    hlcs# date
    Thu Jul 10 00:21:17 UTC 2025
    hlcs# uptime
    12:21AM  26 secs, 1 user, load averages: 0.18, 0.05, 0.02
    hlcs#
    Looks like hlcs still can reboot, so maybe I haven't broken it too badly . . . yet. . . . :)
    Thanks @Hosteroid! Thanks @cmeerw! Thanks everyone! <3
  • @Not_Oles said: @cmeerw Please go ahead whenever you want next weekend. No need to schedule a specific time. Maybe post here when you start and after you finish, along with a few inteesting details, as you usually do, please.
    As it's now already Saturday in central Europe (and you are no longer logged into the machine), I have started the tilemaker job. I'll then check on the server in the morning.
    The server once again didn't let me log in via ssh (although it still did respond to pings), so I had to reset it via the console.
    It did show:
    hlcs /bsd: pagedaemon: wait_pla deadlock detected!
    on the console on in dmesg, but seems to have completed the tilemaker job first.
    It did have a vmstat 60 running in the background to at least get some information. This shows:
    04:58:52 8  6626228M   1106M 4420   0   6   0   0 317 734  553 2143742 101757 82 15  2
    04:59:52 1  5925657M   1336M 11985   0 1653   0   0 6832 5811 3082 1441219 72029 50 13 37
    05:00:52 0  5925044M   1315M 27978   0 2073   6   0 23739 12219 6200    10 12368  0  8 92
    05:01:52 0  5924755M   1141M 13456   0 917  18   0 10940 5863 3018     4 5994  0  4 96
    05:02:52 0  5924394M   1138M 26358   0 2079 837   0 24901 13251 7294     4 14164  0  8 91
    05:03:52 0  5923137M   1806M 25301   0 2057 1606   0 25775 14120 8338     4 14671  0  9 91
    05:04:52 0  5924271M     74M 25809   0 1888 4456   0 23511 15442 9315     4 16534  0  8 91
    05:05:56 0  5924432M      0M  687   0  68 564   0 565 597  496    15  884  0  0 100
    05:07:03 0  5924433M      0M    6   0   0  21   0  21  12   85    19  163  0  0 100
    05:07:52 0  5924433M      0M    4   0   0   2   0   2   1   78    18  143  0  0 100
    BTW, the timestamp on the europe.mbtiles file create by tilemaker is: Jul 12 04:59
    Also noticed that the OpenBSD updates must have disabled httpd in /etc/rc.conf again.
    @cmeerw You seem to be doing great. Congrats on the completion of the europe.mbtiles creation job. I'm looking forward to hearing more when you figure out what happened to cause the deadlock. If there is anything I could do to help, please let me know. No worries about leaving the server to your pleasure for as long as you need it!
    Thanks to @Hosteroid for our lovely, free, community server! <3
    Do any more LESbians want to join @cmeerw and me? Please review the How To Apply section in the OP. Thanks!
    Not sure there is much I can do here - I did post to the OpenBSD mailing list, but haven't seen any reaction to it.
