@jmaxwell said: Thanks, that makes sense. Are there any email clients that help to generate aliases on the go?
what I use is a self hosted version of addy.io for a domain that I use for aliases only, there is a browser extension that can automatically create aliases for sites and keeps note on what site it is used for etc, there is even a BitWarden link for it to generate a new email for sites when you make accounts.
then I use namecrane as the stmp relay for this alias service that then gets sent to another domain hosted on namecrane where all my emails get stored.
addy.io will automatically hide you main email address when replying to emails etc
@jmaxwell said:
Thanks, that makes sense. Are there any email clients that help to generate aliases on the go? Manageable from webmail with a few clicks, but it would be good to have such a feature. I tried eM Client on iOS, and it has a create alias option, but it seems to create only locally, and sending or receiving doesn’t work.
I had to create my own script that takes inputs from my Telegram bot and passes it to my Virtualmin website panel to create/list/delete aliases for my domains. It's easy to do on cPanel as well using a simple script, but I am not aware of any client that is able to do it since it needs to be done from the backend by editing the server's main processor...
Mobile ActiveSync now supports 2FA, just use your IMAP or MAPI/EWS password! we've also enabled Calendar & Contact syncing. iPhone users will need to go to Settings > Accounts, click your Exchange account, and enable Contacts and Calendars in the sync list. Remote Global Address List searching will be implemented once Smartermail adds backend support.
did you enable send from catch-all in eM Client?
Some improvements went out tonight
Settings > Accounts
, click yourExchange
account, and enableContacts
andCalendars
in the sync list. Remote Global Address List searching will be implemented once Smartermail adds backend support.Enjoy!
Francisco
Wait there are erections in here and I missed them?
