1389390392394395423
  • skorousskorous OGSenpai
    @VirMach said: Extra IPv4 not possible by default for everyone due to limited quantities available in the specific block used for dedicated servers. This is a block we have on a 3-5 year lease with transit. Other blocks are month to month. I wanted to avoid lots of renumberings so dedicated servers are specifically going to use this block. We could add another block for these specifically, but then I'd still have to charge for it so it does increase the cost by around 10% still. Right now an extra IP would be optional. Well actually right now this is just an idea and based on the feedback I received, I probably won't do it.
    FWIW, if I hadn't just picked up a dedi I'd have been interested at 8gig and/or 16gig. One the plus side most of my stuff is behind a proxy anyway so lack of v4 isn't devastating. One the negative is that almost everything I'm doing is for myself or a couple people so I'm rarely cpu bound. Makes it hard to justify when I currently have 12 threads I'm still only barely using.
    @virmach is the SSD32G a thing yet?
    Can you let me know what you're talking about again specifically? I just mean the exact pricing/post that I made about it, I can't find it since I talk too much.
    Just curious, would the plan somehow psychologically looked more attractive if it had less cores? Everything else the same, including the price.
    I have a question to everyone who wants Virtfusion. If I released the same exact plan, and the only difference is whether it's on Virtfusion or SolusVM, would you actually pick the Virtfusion plan?
    So just imagine you're looking at these plans right now, and you see:
    • $126 on Virtfusion, $99 on SolusVM
    • $42 on Virtfusion, $33 on SolusVM
  • edited July 22
    Cheaper the better, always for me.
    Sure V is much sleek, but not that great to warrant more $$$$
  • imokimok OG
    edited July 22
    SolusVM is not that bad. I mean, we have used it for a long time... A little bit longer won't matter 😛
    Why are providers still using SolusVM? It's garbage! Move to Virtfusion tomorrow! Viva Virtfusion!
    Edit: Wait, why did I think 33 + 4 = 42? Anyway, I'm not rich but we need to improve. Still, I'm going with Virtfusion.
    Thanked by (2)localhost VirMach
  • @VirMach said:
    @ricANNArdo said:
    Seems like my server in LAXA019 is down per my uptime service.
    Confirmed, hands request put in. Server is not responding at all.
    What is the current progress of the LAXA019 node?
    Emails sent out, current ETA on Wednesday (48~ hours.) Requires hardware swap.
    Thanked by (2)Wonder_Woman toor
    I would prefer Virfusion,but cheaper SolusVM is better. :p
    4C/6C with the rest same spec should be okay. And if 2X same spec for bigger plan with similar 2X price for me also acceptable.
    MY/SG & Worldwide Latency Test V3 : http://www.mywebping.com (27 February 2021 Updated)
    MY-Unifi Home SmokePing: http://smokeping.mywebping.com/smokeping/
    @msatt said:
    @VirMach said: In Europe I can do it for $720. That's the actual power cost difference. Plus like $100 setup fee.
    EDIT-- okay technically power isn't the only thing and bandwidth/space is about the same. But power is the main thing for these servers. So probably closer to $500 instead of $88.
    Wow - That is ludicrous, I am sure our energy is not ~ 6 x more expensive. Even so, I appreciate the offer and understand why the answer is NO to Europe :'(
    BTW this was not meant as a criticism - I fully believe what you are saying.
    As far as Solus / Virt - Once my server is up and running, I don't care what you are using. So my choice would be to always go for the lower priced.
    Thanked by (2)VirMach ZA_capetown
  • JabJab Senpai
    @VirMach said: So just imagine you're looking at these plans right now, and you see:
    $126 on Virtfusion with IPv6 and revDNS, $99 on SolusVM without IPv6
    $42 on Virtfusion with IPv6 and revDNS, $33 on SolusVM without IPv6
    There, fixed this for you.
    where this cost from,isn't one VF license just cost 18$ a month?
    Virtfuuuuuuuuuuuuuuuuuuuuuuusion
    An interesting question ... I'm honestly not sure ( working under the assumption that I didn't know that more cores were originally available of course ). I'm going to say no but admit that the engineer in me is attracted to the efficiency. Plus it would have ruled out one of my use cases since the software requires 4c/16g and actually checks.
    Thanked by (1)VirMach
    Let me know what plan you would purchase for $99, try to be realistic.
    Now assume we're not getting $2000 worth of RAM to add to that server, just a typical amount that'd make sense for the processing power of one server, and divide it out. An unlimited license for one server sadly doesn't mean we get to divide by infinity.
  • edited July 22
    99$ per year for Limited promotion like 4-6C Dedicated Xeon/12-16G DDR3-4 /150-200G Raid SSD(I mean some kind of Redundant) looks attractive to me.
    To be clear,I have a vps(non-vds) with another host by year end 2024 limited sale (8v AMD Core/16G/180G/Virtfusion in SG for around 140USD per year)
  • I'm interested, but I may already have too many VirMach servers... if that's possible. I could be convinced :)
  • Wow, I used a single drive in a server and now it's starting to fail. But hey, the other nodes running on RAID have perfectly healthy drives.
    Not a Virmach machine, though.
  • I make backups of the entire virtual machines.
    I also back up the website files to two locations.
    But this server, running on a single drive, could not take the backups due to a drive failure for the last 5 days, and the other two backup servers were not configured properly.
    Anyway, I managed to copy all the files from the failed machine. Fortunately, the websites were not affected.
    Keep an eye on your backups.
    Thanked by (2)Wonder_Woman localhost
    what if all 4 people on the server agree to use proxmox VE to spilt😁
    Thanked by (1)imok
  • Good point. What's the problem with PVE? It's free but I don't know hosts that use them.
  • It seems I need to start using my Virmach server
    @taizi said: what if all 4 people on the server agree to use proxmox VE to spilt😁
    I was going to try to use Proxmox for the virtual dedicated idea. I guess we could scrap the "dedicated" portion of that idea and still try to use it and find out why other hosts don't use it. But let me maybe launch the location first, I should stop distracting myself.
    This is doable. It might be a little cheaper if you don't mind.
  • @VirMach NYCB037 down since last month, do you have any idea?
    I'm aware. It's fully dead and every option requires more coordination/planning than usual, so unfortunately I keep postponing and losing track of time. The original "plan" at the time was to email everyone, telling them to check network status page for scheduled date where I'd drive in with a replacement server/parts, and it was going to happen right after I wrapped things up in "a couple days" here, and I believe that was around 4th of July. The "plan" changed a day or two after that, then it changed again, and again, to the point where I didn't even bother sending out notifications because I knew it'd change (and I was going to instead respond to tickets individually but I did a terrible job with that as well.)
    Something almost happened last week, then it didn't. It'll be rectified eventually with appropriate service extensions, that's all I can really say. I do apologize.
  • https://virmach.com/about-us/
    Would love to see the new updates here @VirMach
    Pretty good going you've had since 2014.
    I think it'd be probably in the lowest priority to update it.
  • It’s been 10 years and 2 months since I registered my Virmach account. (VPSCraft for Minecraft) B)
  • Oh no, PBS down
  • Yeah it's back.
  • Viva virbot
    @VirMach
    Going strong
    One day I hope it drops dedicated servers too
    edited July 28
    AMSD018 Looks like the disk has gone walkies....
    Swap went read only, reboot
    Boot failed: could not read the boot disk
    Edit - another server in AMSD018 is working so just a VM issue.
